How to Install i-doit Asset Management Tool on Ubuntu 20.04 LTS
I-doit is an open-source asset management tool that can be used to manage the entire IT system. It is based on a complete open source configuration management and database that allows you to keep track of software and hardware assets and their relations. With i-doit, you can document entire IT systems and their changes, display vital information and ensure stable and efficient operation of IT networks.
It offers a wide range of features including, Asset Management, Infrastructure Planning, Ticket System, Cable Management, Inventory, SAN, IP Address Management, Cluster, Patch Management and many more.
In this tutorial, we will be going to explain how to install I-doit Asset Management System on Ubuntu 20.04.
  • A server running Ubuntu 20.04 with minimum 2GB of RAM.
Install LAMP Server
First, you will need to install the Apache web server, MariaDB database server, PHP and other required PHP extensions in your system. You can install all of them with the following command:
apt-get install apache2 mariadb-server libapache2-mod-php7.4 php7.4-bcmath php7.4-cli php7.4-common php7.4-curl php7.4-gd php7.4-json php7.4-ldap php7.4-mbstring php7.4-mysql php7.4-opcache php7.4-pgsql php7.4-soap php7.4-xml php7.4-zip php7.4-imagick php7.4-memcached unzip wget curl memcached moreutils -y
Once all the packages are installed, create a new php.ini file for I-doit with desired values:
nano /etc/php/7.4/mods-available/i-doit.ini
allow_url_fopen = Yes
file_uploads = On
magic_quotes_gpc = Off
max_execution_time = 300
max_file_uploads = 42
max_input_time = 60
max_input_vars = 10000
memory_limit = 256M
post_max_size = 128M
register_argc_argv = On
register_globals = Off
short_open_tag = On
upload_max_filesize = 128M
display_errors = Off
display_startup_errors = Off
error_reporting = E_ALL & ~E_DEPRECATED & ~E_STRICT
log_errors = On
default_charset = "UTF-8"
default_socket_timeout = 60
date.timezone = Asia/Kolkata
session.gc_maxlifetime = 604800
session.cookie_lifetime = 0
mysqli.default_socket = /var/run/mysqld/mysqld.sock
Save and close the file when you are finished. Then, apply the configuration and enable the memcached module with the following command:
phpenmod i-doit
phpenmod memcached
Next, restart the Apache service to apply the changes:
systemctl restart apache2
Configure MariaDB for Better Performance
Next, you will need to configure MariaDB server for better performance. You can do it by creating new configuration file:
nano /etc/mysql/mariadb.conf.d/99-i-doit.cnf
[mysqld] innodb_buffer_pool_size = 1G
innodb_buffer_pool_instances = 1
innodb_log_file_size = 512M
innodb_sort_buffer_size = 64M
sort_buffer_size = 262144 # default
join_buffer_size = 262144 # default
max_allowed_packet = 128M
max_heap_table_size = 32M
query_cache_min_res_unit = 4096
query_cache_type = 1
query_cache_limit = 5M
query_cache_size = 80M
tmp_table_size = 32M
max_connections = 200
innodb_file_per_table = 1
innodb_thread_concurrency = 0
innodb_flush_log_at_trx_commit = 1
innodb_flush_method = O_DIRECT
innodb_lru_scan_depth = 2048
table_definition_cache = 1024
table_open_cache = 2048
innodb_stats_on_metadata = 0
sql-mode = ""
Save and close the file when you are finished. Then, log in to MariaDB shell with the following command:
mysql
Once login, change the MariaDB authentication plugin to mysql_native_password with the following command:
MariaDB [(none)]> SET GLOBAL innodb_fast_shutdown = 0;
MariaDB [(none)]> UPDATE mysql.user SET plugin = 'mysql_native_password' WHERE User = 'root';
MariaDB [(none)]> EXIT;
Finally, restart the MariaDB service to apply the changes:
systemctl restart mariadb
Download I-doit
First, you will need to download the latest version of I-doit from the Sourceforge website. You can use wget command to download it:
wget https://excellmedia.dl.sourceforge.net/project/i-doit/i-doit/1.14/idoit-open-1.14.zip
Once downloaded, unzip the downloaded file to the Apache web root directory with the following command:
unzip idoit-open-1.14.2.zip -d /var/www/html/idoit
Next, change the ownership to the www-data user and set proper permissions with the following command:
chown -R www-data:www-data /var/www/html/idoit/
chmod -R 775 /var/www/html/idoit/
Configure Apache Web Server
Next, create the Apache virtual host configuration file for I-doit.
nano /etc/apache2/sites-available/idoit.conf
ServerName idoit.linuxbuz.com
DirectoryIndex index.php
DocumentRoot /var/www/html/idoit
<Directory /var/www/html/idoit>
Require all granted
LogLevel warn
Save and close the file when you are finished. Then, enable the virtual host and Apache rewrite module with the following command:
a2ensite idoit
a2enmod rewrite
Secure I-doit with Let’s Encrypt SSL
In order to secure your I-doit website with Let’s Encrypt SSL, you will need to install the Certbot client package in your server. You can install it with the following command:
apt-get install python3-certbot-apache -y
Once installed, run the following command to secure your website with Let’s Encrypt SSL:
certbot --apache -d idoit.linuxbuz.com
You will need to provide your valid email address and accept the term of service as shown below:
cancel): [email protected]
(A)gree/(C)ancel: A
(Y)es/(N)o: Y
Obtaining a new certificate
http-01 challenge for idoit.linuxbuz.com
Enabled Apache rewrite module
Waiting for verification...
Cleaning up challenges
Created an SSL vhost at /etc/apache2/sites-available/idoit-le-ssl.conf
Enabled Apache socache_shmcb module
Enabled Apache ssl module
Deploying Certificate to VirtualHost /etc/apache2/sites-available/idoit-le-ssl.conf
Enabling available site: /etc/apache2/sites-available/idoit-le-ssl.conf
Next, select whether or not to redirect HTTP traffic to HTTPS as shown below:
Type 2 and hit Enter to install the Let’s Encrypt SSL for your website:
Redirecting vhost in /etc/apache2/sites-enabled/idoit.conf to ssl vhost in /etc/apache2/sites-available/idoit-le-ssl.conf
Congratulations! You have successfully enabled https://idoit.linuxbuz.com
https://www.ssllabs.com/ssltest/analyze.html?d=idoit.linuxbuz.com
IMPORTANT NOTES:
/etc/letsencrypt/live/idoit.linuxbuz.com/fullchain.pem
/etc/letsencrypt/live/idoit.linuxbuz.com/privkey.pem
Your cert will expire on 2020-10-17. To obtain a new or tweaked
Access I-doit Web Interface
Now, open your web browser and access the I-doit using the URL https://idoit.linuxbuz.com. You should see the system check screen:
System Check
Make sure all required packages are installed. Then, click on the Next button. You should see the directory configuration screen:
Directory Configuration
Provide your desired filemanager directory path and click on the Next button. You should see the database configuration screen:
Database configuration
Provide your desired database information and click on the Next button. You should see the admin user configuration screen:
Admin credentials
Provide your admin username, password and click on the Next button. You should see the configuration preview screen:
Final configuration check
Click on the Next button to start the installation. Once the installation has been finished, you should see the following screen:
Installation progress
Click on the Next button. You should see the I-doit login screen:
i-doit login
Provide your admin username, password and click on the Login button. You should see the I-doit dashboard in the following screen:
I-Doit Asset Management Tool
Congratulations! you have successfully installed I-doit Asset Management System on Ubuntu 20.04 with Let’s Encrypt SSL. You can now manage your hardware and software assets through a web browser. Feel free to ask me if you have any questions.
