How to Install Gradle Build Tool on Ubuntu 18.04 LTS
Gradle is a free and open-source build tool primarily used for Java projects. Gradle helps you to automate, build and deliver software efficiently. Gradle uses Groovy object-oriented programming language instead of XML to define the project configurations. Gradle also supports many popular IDE platforms, such as Android Studio, Eclipse, IDEA, and NetBeans.
In this tutorial, we will show you how to install the Gradle Build Tool on Ubuntu 18.04 LTS.
- A root password is set up to your server.
apt-get upgrade -y
Next, install other required packages with the following command:
apt-get install wget unzip -y
Install Java
Gradle needs Java to be installed on your system. You can install the latest version of Java by running the following command:
apt-get install default-jdk -y
After installing Java, you can verify the Java with the following command:
java -version
openjdk version "11.0.4" 2019-07-16
OpenJDK Runtime Environment (build 11.0.4+11-post-Ubuntu-1ubuntu218.04.3)
OpenJDK 64-Bit Server VM (build 11.0.4+11-post-Ubuntu-1ubuntu218.04.3, mixed mode, sharing)
Install Gradle from PPA Repository
In this section, we will learn how to install Gradle from PPA Repository.
First, install all the required packages with the following command:
apt-get install apt-transport-https dirmngr wget software-properties-common -y
Next, download and import GPG key with the following command:
apt-key adv --keyserver keyserver.ubuntu.com --recv-keys D7CC6F019D06AF36
Executing: /tmp/apt-key-gpghome.XFiNpS59rU/gpg.1.sh --keyserver keyserver.ubuntu.com --recv-keys D7CC6F019D06AF36
gpg: key D7CC6F019D06AF36: public key "Launchpad PPA for Cheng-Wei Chien" imported
gpg: Total number processed: 1
gpg: imported: 1
Next, add the PPA repository with the following command:
add-apt-repository ppa:cwchien/gradle
Once the repository is added, update the repository and install Gradle by running the following commands:
apt-get install gradle -y
After installing Gradle, you can verify the Gradle installation with the following command:
gradle -v
Welcome to Gradle 5.6.3!
Here are the highlights of this release:
- Incremental Groovy compilation
- Groovy compile avoidance
- Test fixtures for Java projects
- Manage plugin versions via settings script
For more details see https://docs.gradle.org/5.6.3/release-notes.html
Gradle 5.6.3
Build time: 2019-10-18 00:28:36 UTC
Revision: bd168bbf5d152c479186a897f2cea494b7875d13
Kotlin: 1.3.41
Groovy: 2.5.4
Ant: Apache Ant(TM) version 1.9.14 compiled on March 12 2019
JVM: 11.0.4 (Ubuntu 11.0.4+11-post-Ubuntu-1ubuntu218.04.3)
OS: Linux 4.15.0-20-generic amd64
Install Gradle from Source
In this section, we will learn how to install Gradle from Source.
Download Gradle
First, change the directory to /opt and download the latest version of Gradle with the following command:
cd /opt/
wget https://services.gradle.org/distributions/gradle-5.6.4-bin.zip
Once downloaded, unzip the downloaded file with the following command:
unzip gradle-5.6.4-bin.zip
You can verify the extracted directory with the following command:
ls /opt/gradle-5.6.4
Output:
LICENSE NOTICE bin getting-started.html init.d lib media
Configure Environment Variables
Next, you will need to set up environment variables to use Gradle. TO do so, create a new file inside /etc/profile.d directory:
nano /etc/profile.d/gradle.sh
export GRADLE_HOME=/opt/gradle-5.6.4
export PATH=${GRADLE_HOME}/bin:${PATH}
Save and close the file then make the file executable with the following command:
chmod +x /etc/profile.d/gradle.sh
Next, load the environment variables with the following command:
source /etc/profile.d/gradle.sh
Verify Installation
Gradle is now installed, it’s time to verify whether Gradle is installed or not.
You can verify the Gradle installation with the following command:
gradle -v
Welcome to Gradle 5.6.4!
For more details see https://docs.gradle.org/5.6.4/release-notes.html
Gradle 5.6.4
Build time: 2019-11-01 20:42:00 UTC
Revision: dd870424f9bd8e195d614dc14bb140f43c22da98
Kotlin: 1.3.41
Groovy: 2.5.4
OS: Linux 4.15.0-65-generic amd64
Congratulations! you have successfully installed Gradle on Ubuntu 18.04 server. You can now start building Java projects with Gradle. Feel free to ask me if you have any questions.
