Mục Lục
GitBucket is an open-source Git web platform powered by Scala. It provides a Github-like user interface features such as Git repository hosting via HTTP and SSH, issues, wiki, repository viewer, and pull requests. It comes with a rich set of features. Some of them are listed below:
- Intuitive UI
- Support for GitLFS
- Support Public and Private Git repositories
- Activity timeline and email notifications
- API compatibility with GitHub
- Account and group management
In this tutorial, we will explain how to install GitBucket with Nginx on Ubuntu 20.04.
- A server running Ubuntu 20.04 with 2 GB of RAM.
- A valid domain name pointed with your server.
Install Java
GitBucket is based on Java so you will need to install it in your system. You can install it with the following command:
apt-get install default-jdk -y
Once installed, verify the Java version using the following command:
java -version
openjdk version "11.0.7" 2020-04-14
OpenJDK Runtime Environment (build 11.0.7+10-post-Ubuntu-3ubuntu1)
OpenJDK 64-Bit Server VM (build 11.0.7+10-post-Ubuntu-3ubuntu1, mixed mode, sharing)
Install and Configure GitBucket
Before starting, it is a good idea to create separate user and group to run GitBucket. You can create a new group and user named gitbucket with the following command:
groupadd -g 555 gitbucket
useradd -g gitbucket --no-user-group --home-dir /opt/gitbucket --no-create-home --shell /usr/sbin/nologin --system --uid 555 gitbucket
Next, create a new directory for GitBucket with the following command:
mkdir /opt/gitbucket
Next, download the latest version of the GitBucket inside the GitBucket directory:
cd /opt/gitbucket
wget https://github.com/gitbucket/gitbucket/releases/download/4.33.0/gitbucket.war
Next, change the ownership of the GitBucket directory:
chown -R gitbucket:gitbucket /opt/gitbucket
GitBucket comes with an embedded H2 database. You can create a new database configuration file with the following command:
nano /opt/gitbucket/database.conf
db {
url = "jdbc:h2:${DatabaseHome};MVCC=true"
user = "sa"
password = "sa"
Create Systemd Service File for GitBucket
Next, you will need to create a systemd service file to manage the GitBucket service. You can create it using the following command:
nano /etc/systemd/system/gitbucket.service
# GitBucket Service
[Unit]
Description=Manage Java service
[Service]
WorkingDirectory=/opt/gitbucket
ExecStart=/usr/bin/java -Xms128m -Xmx256m -jar gitbucket.war
User=gitbucket
Group=gitbucket
Type=simple
Restart=on-failure
RestartSec=10
[Install]
WantedBy=multi-user.target
Save and close the file when you are finished. Then, reload the systemd daemon using the following command:
systemctl daemon-reload
Next, start the GitBucket service and enable it to start after system reboot with the following command:
systemctl start gitbucket
systemctl enable gitbucket
Next, verify the status of the GitBucket service with the following command:
systemctl status gitbucket
? gitbucket.service - Manage Java service
Loaded: loaded (/etc/systemd/system/gitbucket.service; enabled; vendor preset: enabled)
Active: active (running) since Thu 2020-05-14 02:27:13 UTC; 10s ago
Main PID: 93029 (java)
Tasks: 36 (limit: 2282)
Memory: 324.9M
CGroup: /system.slice/gitbucket.service
??93029 /usr/bin/java -Xms128m -Xmx256m -jar gitbucket.war
May 14 02:27:19 ubuntu2004 java[93029]: 2020-05-14 02:27:19.868:INFO:oejs.session:main: DefaultSessionIdManager workerName=node0
May 14 02:27:19 ubuntu2004 java[93029]: 2020-05-14 02:27:19.868:INFO:oejs.session:main: No SessionScavenger set, using defaults
May 14 02:27:19 ubuntu2004 java[93029]: 2020-05-14 02:27:19.875:INFO:oejs.session:main: node0 Scavenging every 600000ms
May 14 02:27:20 ubuntu2004 java[93029]: 02:27:20.261 [main] INFO com.zaxxer.hikari.HikariDataSource - HikariPool-1 - Starting...
May 14 02:27:20 ubuntu2004 java[93029]: 02:27:20.691 [main] INFO com.zaxxer.hikari.HikariDataSource - HikariPool-1 - Start completed.
May 14 02:27:20 ubuntu2004 java[93029]: 02:27:20.697 [main] WARN slick.util.AsyncExecutor - Having maxConnection > maxThreads can result in d>
May 14 02:27:20 ubuntu2004 java[93029]: 02:27:20.721 [main] INFO g.core.servlet.InitializeListener - Check version
May 14 02:27:20 ubuntu2004 java[93029]: 02:27:20.721 [main] INFO g.core.servlet.InitializeListener - Start schema update
May 14 02:27:22 ubuntu2004 java[93029]: 02:27:22.156 [main] INFO l.servicelocator.ServiceLocator - Can not use class liquibase.parser.core.ya>
May 14 02:27:22 ubuntu2004 java[93029]: 02:27:22.161 [main] INFO l.servicelocator.ServiceLocator - Can not use class liquibase.parser.core.js>
At this point, GitBucket is running and listening on port 8080.
Configure Nginx as a Reverse Proxy
By default, GitBucket is running on port 8080. So it is a good idea to configure Nginx as a reverse proxy for GitBucket.
First, install the Nginx web server with the following command:
apt-get install nginx -y
Next, create an Nginx virtual host configuration file for GitBucket:
nano /etc/nginx/sites-available/gitbucket
upstream gitbucket {
server 127.0.0.1:8080 weight=100 max_fails=5 fail_timeout=5;
server_name gitbucket.linuxbuz.com;
proxy_pass http://gitbucket/;
Save and close the file. Then, create a symbolic link to the sites-enabled directory:
ln -s /etc/nginx/sites-available/gitbucket /etc/nginx/sites-enabled/
Next, check the Nginx for any syntax error with the following command:
nginx -t
Finally, restart the Nginx service to implement the changes:
systemctl restart nginx
Secure GitBucket with Let’s Encrypt
Next, you will need to install the Certbot client to secure your GitBucket with Let’s Encrypt SSL.
First, add the Certbot repository using the following command:
add-apt-repository ppa:ahasenack/certbot-tlssni01-1875471
Next, update the repository and install the Certbot client with the following command:
apt-get install certbot python3-certbot-nginx -y
Next, run the following command to download and install the Let’s Encrypt SSL for your website:
certbot --nginx -d gitbucket.linuxbuz.com
You will be asked to provide your email and accept the term of service:
cancel): hitjethva@gmail.com
(A)gree/(C)ancel: A
(Y)es/(N)o: Y
Obtaining a new certificate
http-01 challenge for gitbucket.linuxbuz.com
Waiting for verification...
Cleaning up challenges
Deploying Certificate to VirtualHost /etc/nginx/sites-enabled/gitbucket
Next, select whether or not to redirect HTTP traffic to HTTPS:
Type 2 and hit Enter to finish the installation.
Redirecting all traffic on port 80 to ssl in /etc/nginx/sites-enabled/gitbucket
Congratulations! You have successfully enabled https://gitbucket.linuxbuz.com
https://www.ssllabs.com/ssltest/analyze.html?d=gitbucket.linuxbuz.com
IMPORTANT NOTES:
/etc/letsencrypt/live/gitbucket.linuxbuz.com/fullchain.pem
/etc/letsencrypt/live/gitbucket.linuxbuz.com/privkey.pem
Your cert will expire on 2020-08-12. To obtain a new or tweaked
Access GitBucket
Now, open your web browser and type the URL https://gitbucket.linuxbuz.com. You will be redirected to the following page:
Click on the Sign in button. You should see the GitBucket login page:
Provide the GitBucket default username as a root and the password as root and click on the Sign in button. You should see the GitBucket dashboard in the following page:
Next, click on the Account Settings in the top right corner to change the default root password:
Provide a new secure password and click on the Save button to update the root password.
Congratulations! you have successfully installed and secured GitBucket with Nginx as a reverse proxy on Ubuntu 20.04. You can now host your own Git repository using the GitBucket.
