How to Install Elastic Stack (Elasticsearch, Logstash and Kibana) on CentOS 8
Elasticsearch is an open-source search engine based on Lucene, developed in Java. It provides a distributed and multitenant full-text search engine with an HTTP Dashboard web-interface (Kibana). The data is queried, retrieved and stored with a JSON document scheme. Elasticsearch is a scalable search engine that can be used to search for all kinds of text documents, including log files. Elasticsearch is the heart of the ‘Elastic Stack’ or ELK Stack.
Logstash is an open-source tool for managing events and logs. It provides real-time pipelining for data collections. Logstash will collect your log data, convert the data into JSON documents, and store them in Elasticsearch.
Kibana is an open-source data visualization tool for Elasticsearch. Kibana provides a pretty dashboard web interface. It allows you to manage and visualize data from Elasticsearch. It’s not just beautiful, but also powerful.
In this tutorial, we will show you step-by-step installing and configuring the ‘Elastic Stack’ on the CentOS 8 server. We will install and setup the Elasticsearch, Logstash, and Kibana. And then set up the Beats ‘filebeat’ on clients Ubuntu and CentOS system.
  • CentOS 8 64 bit with 4GB of RAM – elk-master
  • CentOS 8 64 bit with 1 GB of RAM – client01
  • Ubuntu 18.04 64 bit with 1GB of RAM – client02
What we will do:
  • Add Elastic Repository to the CentOS 8 Server
  • Install and Configure Elasticsearch
  • Install and Configure Kibana Dashboard
  • Setup Nginx as a Reverse Proxy for Kibana
  • Install and Configure Logstash
  • Install and Configure Filebeat
  • Testing
Step 1 – Add Elastic Repository
Firstly, we’re going to add the Elasticsearc key and repository to the CentOS 8 server. With the elasticsearch repository provided by the elastic.co, we’re able to install elastic products including the Elasticsearch, Logstash, Kibana, and Beats.
Add the elastic key to the system using the following command.
rpm --import https://artifacts.elastic.co/GPG-KEY-elasticsearch
After that, go to the ‘/etc/yum.repos.d’ directory and create a new repository file ‘elasticsearch.repo’.
cd /etc/yum.repos.d/
vim elasticsearch.repo
Paste the elasticsearch repository below.
[elasticsearch-7.x]name=Elasticsearch repository for 7.x packages
baseurl=https://artifacts.elastic.co/packages/7.x/yum
gpgcheck=1
gpgkey=https://artifacts.elastic.co/GPG-KEY-elasticsearch
enabled=1
autorefresh=1
type=rpm-md
Save and close.
Now check all available repository on the system using the dnf command below.
dnf repolist
And you will get the elasticsearch repository that has been added to the CentOS 8 server.
Get repository list with dnf command
As a result, you can install Elastic products such as Elasticsearch, Logstash, and Kibana, etc.
Step 2 – Install and Configure Elasticsearch
In this step, we’re going to install and configure the Elasticsearch.
Install the Elasticsearch package using the dnf command below.
sudo dnf install elasticsearch -y
Once the installation is complete, go to the ‘/etc/elasticsearch’ directory and edit the configuration file ‘elasticsearch.yml’ using vim editor.
cd /etc/elasticsearch/
vim elasticsearch.yml
Uncomment the following lines and change the value for each line as below.
network.host: 127.0.0.1
http.port: 9200
Save and close.
Optionally:
You can tune the elasticsearch by editing the JVM configuration file ‘jvm.options’ and set up the heap size based on how much memory you have.
Edit the JVM configuration ‘jvm.options’ using vim editor.
vim jvm.options
Change the min/max heap size via the Xms and Xmx configuration as below.
-Xms512m
-Xmx512m
Save and close.
Next, reload the systemd manager configuration and add the elasticsearch service to the boot time.
sudo systemctl daemon-reload
sudo systemctl enable elasticsearch
Then start the elasticsearch service.
sudo systemctl start elasticsearch
Configure and start elasticssearch
As a result, the elasticsearch is up and running behind the local IP address ‘127.0.0.1’ with the default port ‘9200’ on CentOS 8 server.
You can check the elasticsearch using the curl command below.
curl -XGET 'http://127.0.0.1:9200/?pretty'
And below is the result that you will get.
Test cobbection to Elasticsearch
Step 3 – Install and Configure Kibana Dashboard
After installing the elasticsearch, we’re going to install and configure the Kibana Dashboard on CentOS 8 server.
Install the Kibana dashboard using the dnf command below.
sudo dnf install kibana
Once the installation is complete, go to the ‘/etc/kibana’ directory and edit the configuration file ‘kibana.yml’.
cd /etc/kibana/
vim kibana.yml
Uncomment and change some lines configuration as below.
server.port: 5601
server.host: "127.0.0.1"
elasticsearch.url: "http://127.0.0.1:9200"
Save and close.
Next, add the kibana service to the system boot and start the kibana service.
sudo systemctl enable kibana
sudo systemctl start kibana
Install Kibana Dashboard
The Kibana service is up and running on the CentOS 8 server, check it using the following commands.
systemctl status kibana
netstat -plntu
Check status of Kibana service
As a result, the Kibana service is up and running default TCP port ‘5601’.
Step 4 – Setup Nginx as a Reverse Proxy for Kibana
In this step, we’re going to install the Nginx web server and set up it as a reverse proxy for the Kibana Dashboard.
Install Nginx and httpd-tools using the dnf command below.
sudo dnf install nginx httpd-tools
Once the installation is complete, go to the ‘/etc/nginx/conf.d’ directory and create a new configuration file ‘kibana.conf’.
cd /etc/nginx/conf.d/
vim kibana.conf
Paste the following configuration.
    server_name elk.hakase-labs.io;
    auth_basic "Restricted Access";
    auth_basic_user_file /etc/nginx/.kibana-user;
        proxy_pass http://127.0.0.1:5601;
        proxy_http_version 1.1;
        proxy_set_header Connection 'upgrade';
        proxy_set_header Host $host;
        proxy_cache_bypass $http_upgrade;
Save and close.
Next, we need to create the basic authentication for securing the Kibana access. Change the ‘hakase’ user with your own and run the htpasspwd command as below.
sudo htpasswd -c /etc/nginx/.kibana-user hakase
TYPE YOUR PASSWORD
Type your password and test the nginx configuration.
nginx -t
Make sure there is no error.
Now add the nginx service to the system boot and start the nginx service.
systemctl enable nginx
systemctl start nginx
Configure Nginx as reverse proxy
As a result, the Nginx installation and configuration as a reverse proxy for Kibana Dashboard have been completed.
Step 5 – Install and Configure Logstash
In this step, we’re going to install and configure the logstash the log shipper. We will install logstash, setup the input beats, setup the syslog filtering using the logstash plugin called ‘grok’, and then set up the output to elasticsearch.
Install logstash using the dnf command below.
sudo dnf install logstash
Once the installation is complete, go to the ‘/etc/logstash’ directory and edit the JVM configuration file ‘jvm.options’ using vim editor.
cd /etc/logstash/
vim jvm.options
-Xms512m
-Xmx512m
Save and close.
Next, go to the ‘/etc/logstash/conf.d’ directory and create the configuration file for beats input called ‘input-beat.conf’.
cd /etc/logstash/conf.d/
vim input-beat.conf
input {
  beats {
    port => 5044
Save and close.
Now create ‘syslog-filter.conf’ configuration file.
vim syslog-filter.conf
filter {
  if [type] == "syslog" {
    grok {
      match => { "message" => "%{SYSLOGTIMESTAMP:syslog_timestamp} %{SYSLOGHOST:syslog_hostname} %{DATA:syslog_program}(?:[%{POSINT:syslog_pid}])?: %{GREEDYDATA:syslog_message}" }
      add_field => [ "received_at", "%{@timestamp}" ]      add_field => [ "received_from", "%{host}" ]    }
    date {
      match => [ "syslog_timestamp", "MMM  d HH:mm:ss", "MMM dd HH:mm:ss" ]    }
Save and close.
And then create the output configuration for elasticsearch ‘output-elasticsearch.conf’.
vim output-elasticsearch.conf
output {
  elasticsearch { hosts => ["127.0.0.1:9200"]    hosts => "127.0.0.1:9200"
    manage_template => false
    index => "%{[@metadata][beat]}-%{+YYYY.MM.dd}"
    document_type => "%{[@metadata][type]}"
Save and close.
Next, add the logstash service to the system boot and start the logstash service.
systemctl enable logstash
systemctl start logstash
Configure Logstash
The logstash service is up and running, check using the following commands.
systemctl status logstash
netstat -plntu
Check logstash status
As a result, the logstash log shipper is up and running on the CentOS 8 server with the default TCP port ‘5044’. And the basic Elastic Stack installation has been completed, and we’re ready to ship and monitor our logs to the Elastic (ELK Stack) server.
Step 6 – Install Filebeat on Client
In this step, we’re going to show you how to set up the filebeat on the Ubuntu and CentOS system. We will install a filebeat and configure to ship logs from both servers to the Logstash on the elastic server.
– Install Filebeat on CentOS 8
Add the elasticsearch key to the CentOS 8 system using the following command.
Now go to the ‘/etc/yum.repos.d’ directory and create the ‘elasticsearch.repo’ file using vim editor.
gpgcheck=1
enabled=1
autorefresh=1
type=rpm-md
Save and close.
Now install the filebeat using the dnf command below.
sudo dnf install filebeat
Wait for the filebeat installation finished.
Install Filebeat
– Install Filebeat on Ubuntu 18.04
Firstly, install the apt-transport-https packages.
sudo apt install apt-transport-https
After that, add the elasticsearch key and repository using the following commands.
wget -qO - https://artifacts.elastic.co/GPG-KEY-elasticsearch | sudo apt-key add -
echo "deb https://artifacts.elastic.co/packages/7.x/apt stable main" | sudo tee -a /etc/apt/sources.list.d/elastic-7.x.list
Now update all repositories and install filebeat to the ubuntu system using the apt command below.
sudo apt install filebeat
Install apz https transport
– Configure Filebeat
The filebeat configuration located at the ‘/etc/filebeat’ directory. Go to the filebeat directory and edit the ‘filebeat.yml’ configuration file.
cd /etc/filebeat/
vim filebeat.yml
Now disable the default elasticsearch output as below.
#output.elasticsearch:
  # Array of hosts to connect to.
  #  hosts: ["127.0.0.1:9200"]
Then enable the logstash output and specify the logstash host IP address.
output.logstash:
  # The Logstash hosts
  hosts: ["10.5.5.25:5044"]
Save and close.
Next, we need to enable filebeat modules. Run the filebeat command below to get the list of filebeat modules.
filebeat modules list
Enable the ‘system’ module using the following command.
filebeat modules enable system
The filebeat system module has been enabled with the configuration file ‘modules.d/system.yml’.
Edit the system module configuration using vim editor.
cd /etc/filebeat/
vim modules.d/system.yml
Uncomment the path of the syslog file and the ssh authorization file.
For the CentOS system:
  # Syslog
  syslog:
    enabled: true
    var.paths: ["/var/log/messages"]
  # Authorization logs
  auth:
    enabled: true
    var.paths: ["/var/log/secure"]
For the Ubuntu system:
  # Syslog
  syslog:
    enabled: true
    var.paths: ["/var/log/syslog"]
  auth:
    enabled: true
    var.paths: ["/var/log/auth.log"]
Save and close.
Now add the filebeat service to the system boot and start the service.
systemctl enable filebeat
systemctl start filebeat
The filebeat service is up and running, you can check using the following command.
systemctl status filebeat
And you will be shown the result as below.
Below is the result from the CentOS 8 server.
result from CentOS server
And below is from the Ubuntu Server 18.04.
Result from Ubuntu 18.04 server
As a result, the connection between filebeat and the logstash service on the elastic stack server IP address ‘10.5.5.12’ has been established.
Step 7 – Testing
Open your web browser and type the Elastic Stack installation domain name on the address bar.
http://elk.hakase-labs.io/
Now log in to the Kibana Dashboard using the basic authentication account that you’ve created.
Kibana Login
And you will get the Kibana Dashboard as below.
Kibana Dashboard
Now connect to the elasticsearch index data that automatically created after the filebeat connected to the logstash. Click on the ‘Connect to your Elasticsearch index‘ link.
Create the ‘filebeat-*‘ index pattern and click the ‘Next step‘ button.
Create Filebeat Index Pattern
For the filter name, choose the ‘@timestamp‘ filter and click the ‘Create index pattern‘.
Choose Filter name
And the ‘filebeat-*‘ index pattern has been created, click the ‘Discover‘ menu on the left.
Filebeat in Discover menu
And you will get the log data from filebeat clients as below.
Logs for CentOS 8 system.
Logs of the CentOS 8 system
Log for the Ubuntu system.
Logs of the Ubuntu System
As a result, the log data that defined on the filebeat system module has been shipped to the elastic stack server.
And the Elastic Stack installation and configuration on CentOS 8 has been completed successfully.
Reference
