How to Install Cachet Status Page System on Ubuntu 18.04 LTS
Cachet is a beautiful and powerful open source status page system written in PHP that allows you to better communicate downtime and system outages to your customers, teams, and shareholders. The application provides you with many features, the most notable among them are: a powerful JSON API, incident reports, metrics, markdown support for incident messages, subscriber notifications via email, two-factor authentication. In this tutorial, we will install Cachet status page system by utilizing PHP, Nginx, MySQL, and Composer on Ubuntu 18.04 LTS.
  • PHP version 7.1 or greater
  • HTTP server with PHP support (eg: Nginx, Apache, Caddy)
  • Composer
  • supported database: MySQL, PostgreSQL or SQLite
  • Git
  • An Ubuntu 18.04 LTS operating system.
Initial steps
Check your Ubuntu version:
lsb_release -ds
# Ubuntu 18.04.1 LTS
Set up the timezone:
sudo dpkg-reconfigure tzdata
Install some essential packages that are necessary for basic administration of Ubuntu operating system:
sudo apt install -y curl wget vim git unzip socat bash-completion
Step 1 – Install PHP
sudo apt install -y php7.2 php7.2-cli php7.2-fpm php7.2-common php7.2-xml php7.2-gd php7.2-zip php7.2-mbstring php7.2-mysql php7.2-pgsql php7.2-sqlite3 php7.2-opcache php-apcu
php -m
ctype
curl
exif
fileinfo
Check PHP version:
php --version
# PHP 7.2.10-0ubuntu0.18.04.1 (cli) (built: Sep 13 2018 13:45:02) ( NTS )
# with Zend OPcache v7.2.10-0ubuntu0.18.04.1, Copyright (c) 1999-2018, by Zend Technologies
PHP-FPM service is automatically started and enabled on reboot on Ubuntu 18.04 system, so there is no need to start and enable it manually. We can move on to the next step, which is the database installation and setup.
Step 2 – Install MySQL and create a database for Cachet
Cachet supports MySQL, MariaDB, PostgreSQL and SQLite databases. In this tutorial, we will use MySQL as the database server.
Install MySQL database server:
sudo apt install -y mysql-server
Check MySQL version:
mysql --version
# mysql  Ver 14.14 Distrib 5.7.25, for Linux (x86_64) using  EditLine wrapper
Run mysql_secure installation script to improve MySQL security and set the password for MySQL root user:
Answer each of the questions:
Would you like to setup VALIDATE PASSWORD plugin? N
Re-enter new password: your_secure_password
Connect to MySQL shell as the root user:
sudo mysql -u root -p
# Enter password
Create an empty MySQL database and user for Cachet and remember the credentials:
mysql> CREATE DATABASE dbname;
mysql> GRANT ALL ON dbname.* TO 'username' IDENTIFIED BY 'password';
mysql> FLUSH PRIVILEGES;
Exit from MySQL:
mysql> exit
Replace dbname, username and password with your own names.
Step 3 – Install Acme.sh client and obtain Let’s Encrypt certificate (optional)
Securing your website with HTTPS is not necessary, but it is a good practice to secure your site traffic. In order to obtain TLS certificate from Let’s Encrypt we will use acme.sh client. Acme.sh is a pure UNIX shell software for obtaining TLS certificates from Let’s Encrypt with zero dependencies.
Download and install acme.sh:
sudo su - root
cd acme.sh
./acme.sh --install --accountemail [email protected]
source ~/.bashrc
cd ~
Check acme.sh version:
acme.sh --version
# v2.8.0
Obtain RSA and ECC/ECDSA certificates for your domain/hostname:
# RSA 2048
# ECDSA
If you want fake certificates for testing you can add the --staging flag to the above commands.
  • For RSA: /home/username/example.com directory.
  • For ECC/ECDSA: /home/username/example.com_ecc directory.
acme.sh --list
Create a directory to store your certs. We will use the /etc/letsencrypt directory.
# RSA
# ECC/ECDSA
All the certificates will be automatically renewed every 60 days.
After obtaining certs exit form root user and return back to normal sudo user:
exit
Step 4 – Install and configure NGINX
Cachet can work fine with many web servers. In this tutorial, we selected Nginx. If you prefer Apache web server over Nginx, visit https://docs.cachethq.io/docs/installing-cachet#section-running-cachet-on-apache to learn more.
Install Nginx:
sudo apt install -y nginx
Check Nginx version:
sudo nginx -v
# nginx version: nginx/1.14.0 (Ubuntu)
Configure Nginx for Cachet by running:
sudo vim /etc/nginx/sites-available/cachet.conf
  listen [::]:80;
listen 443 ssl;
listen [::]:443 ssl;
  server_name status.example.com;
  root /var/www/cachet/public;
  index index.php;
  ssl_certificate /etc/letsencrypt/status.example.com/fullchain.cer;
  ssl_certificate_key /etc/letsencrypt/status.example.com/status.example.com.key;
  ssl_certificate /etc/letsencrypt/status.example.com_ecc/fullchain.cer;
  ssl_certificate_key /etc/letsencrypt/status.example.com_ecc/status.example.com.key;
    try_files $uri /index.php$is_args$args;
  location ~ .php$ {
    include fastcgi_params;
    fastcgi_index index.php;
    fastcgi_keep_conn on;
Activate the new cachet.conf configuration by linking the file to the sites-enabled directory:
sudo ln -s /etc/nginx/sites-available/cachet.conf /etc/nginx/sites-enabled/
Test NGINX configuration:
sudo nginx -t
Reload Nginx:
Step 5 – Install Composer
Install Composer, the PHP dependency manager globally:
php -r "if (hash_file('sha384', 'composer-setup.php') === '48e3236262b34d30969dca3c37281b3b4bbe3221bda826ac6a9a62d6444cdb0dcd0615698a5cbe587c3f0fe57a54d8f5') { echo 'Installer verified'; } else { echo 'Installer corrupt'; unlink('composer-setup.php'); } echo PHP_EOL;"
php composer-setup.php
Check Composer version:
composer --version
# Composer version 1.8.3 2019-01-30 08:31:33
Step 6 – Install Cachet
Create a document root directory where Cachet should reside in:
sudo mkdir -p /var/www/cachet
Change ownership of the /var/www/cachet directory to {jour_user}:
sudo chown -R {your_user}:{your_user} /var/www/cachet
NOTE: Replace {jour_user} with your initially created non-root user username.
cd /var/www/cachet
Download the Cachet source code with Git:
git clone -b 2.4 --single-branch https://github.com/cachethq/Cachet.git .
Copy .env.example to .env file and configure database and APP_URL settings in .env file:
cp .env.example .env
vim .env
Install Cachet dependencies with Composer:
composer install --no-dev -o
Set up the application key by running:
php artisan key:generate
Install Cachet:
php artisan cachet:install
Change ownership of the /var/www/cachet directory to www-data:
sudo chown -R www-data:www-data /var/www/cachet
Open your site in a web browser and follow the instructions on the screen to finish Cachet installation.
Step 7 – Complete the Cachet setup
Select cache and session drivers and configure mail options:
Finish the cachet setup
Configure general site settings like site name, site domain, timezone and language:
Cachet general settings
Create an administrative user account:
Add an admin account
After that, you should get a message that Cachet has been configured successfully. You can open Cachet dashboard by pressing “Go to dashboard” button:
Cachet has been successfully installed
Cachet installation and setup has been completed.
To access Cachet dashboard append /dashboard to your website URL.
Cachet Dashboard
