How to Install Cachet Status Page System on CentOS 7
Cachet is a beautiful and powerful open source status page system written in PHP that allows you to better communicate downtime and system failures to your customers, teams, and shareholders. The application offers many features, the most important of which are: a powerful JSON API, event reports, metrics, transcription support for event messages, subscriber notifications via email, two-factor authentication. In this tutorial, we will install the Cachet status page system using PHP, Nginx, MySQL, and Composer on the CentOS 7 system.
To run Cachet on your CentOS 7 system you will need a couple of things:
- PHP version 7.1 or greater
- HTTP server with PHP support (eg: Nginx, Apache, Caddy)
- Composer
- A supported database: MySQL, PostgreSQL or SQLite
- Git
- A CentOS 7 operating system.
Initial steps
Check your CentOS version:
cat /etc/centos-release
Set up the timezone:
timedatectl list-timezones
sudo yum upgdate -y
Install some essential packages that are necessary for basic administration of the CentOS operating system:
sudo yum install -y curl wget vim git unzip socat bash-completion
Step 1 – Install PHP
Setup the Webtatic YUM repo:
sudo yum install -y php72w-cli php72w-fpm php72w-common php72w-xml php72w-gd php72w-zip php72w-mbstring php72w-mysqlnd php72w-pgsql php72w-sqlite3 php72w-opcache php72w-apcu php72w-json
php -m
ctype
curl
exif
fileinfo
Check the PHP version:
php --version
We can move on to the next step, which is the database installation and setup.
Step 2 – Install MariaDB and create a database for Cachet
Cachet supports MySQL, MariaDB, PostgreSQL and SQLite databases. In this tutorial, we will use MariaDB as the database server.
Create MariaDB 10.2 YUM repository for CentOS:
sudo vim /etc/yum.repos.d/MariaDB.repo
Copy and paste the following text into it:
# MariaDB 10.2 CentOS repository list - created 2017-12-11 23:19 UTC
# http://downloads.mariadb.org/mariadb/repositories/
[mariadb]
name=MariaDB
baseurl=https://yum.mariadb.org/10.2/centos7-amd64
gpgkey=https://yum.mariadb.org/RPM-GPG-KEY-MariaDB
gpgcheck=1
After the file is in place, install MariaDB by running:
sudo yum install -y MariaDB-server MariaDB-client
Check the MariaDB version:
mysql --version
# mysql Ver 15.1 Distrib 10.2.21-MariaDB, for Linux (x86_64) using readline 5.1
Start and enable MariaDB service:
Run mysql_secure installation script to improve MariaDB security and set the password for MariaDB root user:
Answer each of the questions:
Would you like to setup VALIDATE PASSWORD plugin? N
Re-enter new password: your_secure_password
Connect to MariaDB shell as the root user:
sudo mysql -u root -p
# Enter password
Create an empty MariaDB database and user for Cachet and remember the credentials:
MariaDB> CREATE DATABASE dbname;
MariaDB> GRANT ALL ON dbname.* TO 'username' IDENTIFIED BY 'password';
MariaDB> FLUSH PRIVILEGES;
Exit from MariaDB:
MariaDB> exit
Step 3 – Install Acme.sh client and obtain Let’s Encrypt certificate (optional)
Securing your website with HTTPS is not necessary, but it is a good practice to secure your site traffic. In order to obtain a TLS certificate from Let’s Encrypt we will use acme.sh client. Acme.sh is a pure UNIX shell software for obtaining TLS certificates from Let’s Encrypt with zero dependencies.
Download and install acme.sh:
sudo su - root
cd acme.sh
./acme.sh --install --accountemail [email protected]
source ~/.bashrc
cd ~
Check acme.sh version:
acme.sh --version
# v2.8.0
# RSA 2048
# ECDSA
If you want fake certificates for testing you can add --staging flag to the above commands.
- For RSA:
/home/username/example.comdirectory. - For ECC/ECDSA:
/home/username/example.com_eccdirectory.
acme.sh --list
Create a directory to store your certs. We will use the /etc/letsencrypt directory.
mkdir -p /etc/letsecnrypt/example.comsudo mkdir -p /etc/letsencrypt/example.com_ecc
# RSA
# ECC/ECDSA
exit
Step 4 – Install and configure NGINX
Cachet can work fine with many web servers. In this tutorial, we selected NGINX. If you prefer Apache web server over NGINX, visit https://docs.cachethq.io/docs/installing-cachet#section-running-cachet-on-apache to learn more.
Install NGINX:
sudo yum install -y nginx
Check the NGINX version:
sudo nginx -v
Start and enable NGINX service:
Configure NGINX for Cachet by running:
sudo vim /etc/nginx/conf.d/cachet.conf
listen [::]:80;
listen 443 ssl;
listen [::]:443 ssl;
server_name status.example.com;
root /var/www/cachet/public;
index index.php;
ssl_certificate /etc/letsencrypt/status.example.com/fullchain.cer;
ssl_certificate_key /etc/letsencrypt/status.example.com/status.example.com.key;
ssl_certificate /etc/letsencrypt/status.example.com_ecc/fullchain.cer;
ssl_certificate_key /etc/letsencrypt/status.example.com_ecc/status.example.com.key;
try_files $uri /index.php$is_args$args;
location ~ .php$ {
include fastcgi_params;
fastcgi_pass 127.0.0.1:9000;
fastcgi_index index.php;
fastcgi_keep_conn on;
Test NGINX configuration:
sudo nginx -t
Reload NGINX:
Step 5 – Install Composer
Install Composer, the PHP dependency manager globally:
php -r "if (hash_file('sha384', 'composer-setup.php') === '48e3236262b34d30969dca3c37281b3b4bbe3221bda826ac6a9a62d6444cdb0dcd0615698a5cbe587c3f0fe57a54d8f5') { echo 'Installer verified'; } else { echo 'Installer corrupt'; unlink('composer-setup.php'); } echo PHP_EOL;"
php composer-setup.php
Check Composer version:
composer --version
# Composer version 1.8.4 2019-02-11 10:52:10
Step 6 – Install Cachet
Create a document root directory where Cachet should reside in:
sudo mkdir -p /var/www/cachet
Change ownership of the /var/www/cachet directory to {jour_user}:
sudo chown -R {your_user}:{your_user} /var/www/cachet
NOTE: Replace {jour_user} with your initially created non-root user username.
cd /var/www/cachet
Download the Cachet source code with Git:
git clone -b 2.4 --single-branch https://github.com/cachethq/Cachet.git .
Copy .env.example to .env file and configure database and APP_URL settings in .env file:
cp .env.example .env
vim .env
Install Cachet dependencies with Composer:
composer install --no-dev -o
Set up the application key by running:
php artisan key:generate
Install Cachet:
php artisan cachet:install
Provide the appropriate ownership:
sudo chown -R nginx:nginx /var/www/cachet
Run sudo vim /etc/php-fpm.d/www.conf and set the user and group to nginx. Initially, they will be set to apache:
# user = nginx
# group = nginx
Open your site in a web browser and follow the instructions on the screen to finish Cachet installation.
Step 7 – Complete the Cachet setup
Select cache and session drivers and configure mail options:
Configure general site settings like site name, site domain, timezone and language:
Create an administrative user account:
After that, you should get a message that Cachet has been configured successfully. You can open the Cachet dashboard by pressing the “Go to dashboard” button:
Cachet installation and setup has been completed.
To access Cachet dashboard append /dashboard to your website URL.
