How to Install Askbot with Nginx and Secure with Let’s Encrypt on CentOS 8
Askbot is a free, open-source, and highly-customizable question and answer forum software written in Python and Django. It is simple, lightweight, and very similar to other forum software StackOverflow and YahooAnswers. Askbot provides a ton of features including, Tags and categories, Email notifications, karma-based system, voting, content moderation and many more.
In this tutorial, we will show you how to install Askbot forum software on CentOS 8 with Let’s Encrypt SSL.
- A server running CentOS 8.
- A root password is setup on your server.
Install Required Dependencies
Before starting, you will need to install some required dependencies in your system.
First, install the “Development Tools” with the following command:
dnf group install 'Development Tools'
Next, install EPEL repository and other Python dependencies with the following command:
dnf install epel-release -y
dnf install python2-pip python2-devel python2-six -y
Once all the required packages are installed, you can proceed to the next step.
Install and Configure PostgreSQL
Askbot uses PostgreSQL to store their data. So you will need to install it in your system. You can install it with the following command:
dnf install postgresql-server postgresql-devel postgresql-contrib -y
Once installed, initialize the database with the following command:
postgresql-setup initdb
WARNING: using obsoleted argument syntax, try --help
WARNING: arguments transformed to: postgresql-setup --initdb --unit postgresql
* Initializing database in '/var/lib/pgsql/data'
* Initialized, logs are in /var/lib/pgsql/initdb_postgresql.log
Next, start the PostgreSQL service and enable it to start after system reboot with the following command:
systemctl start postgresql
systemctl enable postgresql
Next, log in to the PostgreSQL shell with the following command:
su - postgres
[postgres@centos8 ~]$ psql
Output:
psql (10.6)
Type "help" for help.
postgres=#
Next, create a database and user for Askbot with the following command:
postgres=# create database askbot;
postgres=# create user askbot with password 'password';
Next, grant all the privileges to the askbot with the following command:
postgres=# grant all privileges on database askbot to askbot;
Finally, exit from the PostgreSQL shell with the following command:
postgres=# q
Next, you will need to configure local user authentication for PostgreSQL. You can do it by editing pg_hba.conf file:
nano /var/lib/pgsql/data/pg_hba.conf
Replace peer with md5 in the following lines:
local all all md5
host all all 127.0.0.1/32 md5
host all all ::1/128 md5
Save and close the file when you are finished. Then, restart the PostgreSQL service to apply the changes:
systemctl restart postgresql
Install and Configure Askbot
Before installing Askbot, you will need to create a user for Askbot. You can create a new Askbot user and set a password with the following command:
useradd -m -s /bin/bash askbot
passwd askbot
Next, add the Askbot user to the wheel group for sudo command access:
usermod -a -G wheel askbot
Next, install python virtualenv package with the following command:
pip2 install virtualenv six
Once installed, change the user to the askbot and create a new virtual environment for Askbot with the following command:
su - askbot
virtualenv askbot
created virtual environment CPython2.7.16.final.0-64 in 663ms
creator CPython2Posix(dest=/home/askbot/askbot, clear=False, global=False)
seeder FromAppData(download=False, pip=latest, setuptools=latest, wheel=latest, via=copy, app_data_dir=/tmp/tmp9YFr7B/seed-app-data/v1)
activators PythonActivator,CShellActivator,FishActivator,PowerShellActivator,BashActivator
Next, change the directory to askbot and activate the virtual environment with the following command:
cd askbot
source bin/activate
Output:
(askbot) [askbot@centos8 askbot]$
Next, install Askbot and other required dependencies with the following command:
pip2 install six==1.10.0
pip2 install askbot psycopg2
Next, create a new directory for your application, change the directory to your application and setup the Askbot with the following command:
mkdir myapp
cd myapp
askbot-setup
Deploying Askbot - Django Q&A forum application
Problems installing? -> please email [email protected]
To CANCEL - hit Ctr-C at any time
Enter directory path (absolute or relative) to deploy
askbot. To choose current directory - enter "."
Type “.” and hit Enter to continue. You should see the following output:
Please select database engine:
1 - for postgresql, 2 - for sqlite, 3 - for mysql, 4 - oracle
type 1/2/3/4: 1
Type 1 to select a postgresql database engine and hit Enter to continue. You should see the following output:
Please enter database name (required)
> askbot
Please enter database user (required)
> askbot
Please enter database password (required)
> password
Provide your Askbot database details and hit Enter. Once the installation has been finished, you should see the following output:
Copying files:
* __init__.py
* manage.py
* urls.py
* django.wsgi
Creating settings file
settings file created
copying directories: * doc
* cron
* upfiles
Done. Please find further instructions at http://askbot.org/doc/
Next, generate Askbot Django static files and database with the following command:
python manage.py collectstatic
python manage.py syncdb
Provide your desired admin username, email and password as shown below:
You have installed Django's auth system, and don't have any superusers defined.
Would you like to create one now? (yes/no): yes
Username (leave blank to use 'askbot'): askbotadmin
Email address: [email protected]
Password:
Password (again):
Install and Configure uWSGI
Next, you will need to install uWSGI to your system. uWSGI is a software tool used to run Python based web applications. You can install it with the following command:
pip2 install uwsgi
After installing uWSGI, create a new directory for uWSGI with the following command:
mkdir -p /etc/uwsgi/sites
Next, create a new uWSGI configuration file as shown below:
nano /etc/uwsgi/sites/askbot.ini
Add the following lines: chdir = /home/askbot/askbot/myapp
[uwsgi]
home = /home/askbot/askbot
static-map = /m=/home/askbot/askbot/myapp/static
wsgi-file = /home/askbot/askbot/myapp/django.wsgi
master = true
processes = 5
# Askbot will running under the sock file
socket = /run/uwsgi/askbot.sock
chmod-socket = 664
uid = askbot
gid = nginx
vacuum = true
# uWSGI Log file
ogto = /var/log/uwsgi.log
Create a Systemd Service File for uWSGI
Next, you will need to create a systemd service file to manage the uWSGI service. You can create it with the following command:
nano /etc/systemd/system/uwsgi.service
[Unit]
Description=uWSGI service
ExecStart=/bin/uwsgi --emperor /etc/uwsgi/sites
Restart=always
KillSignal=SIGQUIT
Type=notify
NotifyAccess=all [Install] WantedBy=multi-user.target
Save and close the file when you are finished. Then, reload the systemd daemon with the following command:
systemctl daemon-reload
Install and Configure Nginx
Next, you will need to install and configure Nginx to serve your Askbot application.
First, install the Nginx webserver with the following command:
dnf install nginx -y
Once installed, create a new virtual host configuration file for Askbot:
nano /etc/nginx/conf.d/askbot.conf
server_name askbot.linuxbuz.com;
include uwsgi_params;
uwsgi_pass unix:/run/uwsgi/askbot.sock;
Save and close the file. Then, start the Nginx and uWSGI service and enable them to start after system reboot with the following command:
systemctl start nginx
systemctl enable nginx
systemctl start uwsgi
systemctl enable uwsgi
Secure Askbot with Let’s Encrypt SSL
Next, you will need to install the Certbot utility in your system to download and install Let’s Encrypt SSL for Askbot domain.
You can install the Certbot client with the following command:
Next, obtain and install an SSL certificate for your Askbot domain with the following command:
certbot-auto --nginx -d askbot.linuxbuz.com
The above command will first install all the required dependencies on your server. Once installed, you will be asked to provide an email address and accept the term of service as shown below:
cancel): [email protected]
(A)gree/(C)ancel: A
(Y)es/(N)o: Y
Obtaining a new certificate
http-01 challenge for askbot.linuxbuz.com
Waiting for verification...
Cleaning up challenges
Deploying Certificate to VirtualHost /etc/nginx/conf.d/askbot.conf
Next, select whether or not to redirect HTTP traffic to HTTPS as shown below:
Type 2 and hit Enter to continue. Once the installation has been finished, you should see the following output:
Redirecting all traffic on port 80 to ssl in /etc/nginx/conf.d/askbot.conf
Congratulations! You have successfully enabled https://askbot.linuxbuz.com
https://www.ssllabs.com/ssltest/analyze.html?d=askbot.linuxbuz.com
IMPORTANT NOTES:
/etc/letsencrypt/live/askbot.linuxbuz.com/fullchain.pem
/etc/letsencrypt/live/askbot.linuxbuz.com/privkey.pem
Your cert will expire on 2020-06-11. To obtain a new or tweaked
Configure Firewall and SELinux
Next, you will need to create a firewall rule to allow HTTP and HTTPS service from external networks. You can allow it with the following command:
firewall-cmd --reload
By default, SELinux is enabled in CentOS 8. It is recommended to disable it in order to work Askbot properly. You can disable it by editing the /etc/selinux/config file:
nano /etc/selinux/config
Find the following line:
SELINUX=enforcing
And, replace it with the following line:
SELINUX=disabled
Save and close the file. Then, restart your system to apply the changes:
Access Askbot
Now, open your web browser and type the URL https://askbot.linuxbuz.com. You will be redirected to the following screen:
Click on the sign in button. You should see the Askbot login page in the following screen:
Provide your Askbot admin username, password and click on the Sign in button. You should see the Askbot dashboard in the following screen:
Congratulations! you have successfully installed and configured Askbot forum on CentOS 8 and secured it with Let’s Encrypt SSL. You can now start creating a question and answer with Askbot.
