How to Install Angular CLI on CentOS 8
Angular is a popular open-source application development framework. It is highly extensible and used for developing mobile and web applications using TypeScript/JavaScript. It is designed for building small to large-scale applications from scratch. It provides an Angular CLI utility to create, manage, build and test Angular applications..
In this post, we will show you how to install Angular (CLI) on CentOS 8.
- A server running CentOS 8.
Install Node.js
In order to install Angular, Node.js must be installed in your server. If not installed, you can install it with the following command:
curl -sL https://rpm.nodesource.com/setup_14.x | bash -
dnf install nodejs -y
Once the installation is completed, verify the installed version of Node.js with the following command:
node --version
Output:
v14.16.1
You can also verify the NPM version using the following command:
npm --version
Output:
6.14.12
Install Angular/CLI
Now, you can install the Angular/CLI by running the following command:
npm install -g @angular/cli
Once installed, verify the installed version of Angular/CLI with the following command:
ng --version
_ _ ____ _ ___
/ _ __ __ _ _ _| | __ _ _ __ / ___| | |_ _|
/ ? | '_ / _` | | | | |/ _` | '__| | | | | | |
/ ___ | | | | (_| | |_| | | (_| | | | |___| |___ | |
/_/ __| |_|__, |__,_|_|__,_|_| ____|_____|___|
|___/
Angular CLI: 11.2.7
Node: 14.16.1
OS: linux x64
Angular:
Ivy Workspace:
Package Version
@angular-devkit/architect 0.1102.7 (cli-only)
@angular-devkit/core 11.2.7 (cli-only)
@angular-devkit/schematics 11.2.7 (cli-only)
@schematics/angular 11.2.7 (cli-only)
@schematics/update 0.1102.7 (cli-only)
Create an Application with Angular
Angular/CLI provides an easier way to create and deploy an application in a production and local environment.
To create a new application named hello-world, run the following command:
ng new hello-world
Once the application is created, change the directory to hello-world and launch the application wiht the following command:
cd hello-world
ng serve
** Angular Live Development Server is listening on localhost:4200, open your browser on http://localhost:4200/ **
? Compiled successfully.
? Browser application bundle generation complete.
Initial Chunk Files | Names | Size
styles.css | styles | 119 bytes
4 unchanged chunks
Build at: 2021-04-07T05:56:55.420Z - Hash: 7af40beb75c73ecdc1c9 - Time: 523ms
As you can see, your application is started and listening on port 4200 on the locahost.
Press CTRL+C to stop the application.
If you want to launch your application on a specific IP address or port, run the following command:
ng serve --host 0.0.0.0 --port 3000
vendor.js | vendor | 2.69 MB
polyfills.js | polyfills | 128.74 kB
main.js | main | 56.94 kB
runtime.js | runtime | 6.15 kB
| Initial Total | 2.87 MB
Build at: 2021-04-07T05:58:19.494Z - Hash: d50a7bd2c684713d3b6b - Time: 11348ms
** Angular Live Development Server is listening on 0.0.0.0:3000, open your browser on http://localhost:3000/ **
Access Angular Application
At this point, your Angular application is started and listening on port 3000 on all network interfaces. You can now access it using the URL http://your-server-ip:3000. You should see your application in the following page:
Congratulations! you have successfully installed Angular on CentOS 8. You can now start building your first application with Angular and deploy it on the production environment.
