How to install and Use sosreport on Ubuntu 18.04 LTS
SOS is a free and open-source data collection tool that can be used to collect system configuration details and diagnostic information from a Unix-like operating system. It works by collecting system configuration and logs information and archive it into a single file. It is generally used for technical support engineers to find what’s the problem in the system.
In this tutorial, we will learn how to use SOS on Ubuntu 18.04 server.
  • A root password is setup to your server.
Generate Sosreport
By default, SOS tool is available in the Ubuntu 18.04 server. So you don’t need to install it to your server.
To collect your system configuration details and other diagnostic information, just run the following command:
sosreport
Output:
sosreport (version 3.5)
This command will collect system configuration and diagnostic
information from this Ubuntu system. An archive containing the collected
information will be generated in /tmp/sos.91hh07wb.
For more information on Ubuntu visit:
http://www.ubuntu.com/
The generated archive may contain data considered sensitive and its
content should be reviewed by the originating organization before being
passed to any third party.
No changes will be made to system configuration.
Press ENTER to continue, or CTRL-C to quit.
Please enter your first initial and last name [ubuntu1804]:
Please enter the case id that you are generating this report for []:
Setting up archive ...
Setting up plugins ...
Running plugins. Please wait ...
Running 61/61: xfs...
Creating compressed archive...
Your sosreport has been generated and saved in:
/tmp/sosreport-ubuntu1804-20190130103134.tar.xz
The checksum is: 180c9e539b00c626d84fc055df5fb864
Please send this file to your support representative.
The above command will collect system configuration and diagnostic information from this system and store it in /tmp directory.
You can also generate sosreport and save it to another location by running the following command:
sosreport --tmp-dir /opt
By default, sosreport is compressed in xz type. To compress sosreport in gzip with the following command:
sosreport --compression-type gzip
Generate sosreport for specific plugins
By default, sosreport comes with lots of plugins. You can list out all the plugins with the following command:
sosreport -l
The following plugins are currently enabled:
acpid ACPI daemon information
apache Apache http daemon
apparmor Apparmor mandatory access control
apport Apport crash reporting tool
apt APT - advanced packaging tool
ata ATA and IDE information
block Block device information
boot Bootloader information
btrfs Btrfs filesystem
cgroups Control groups subsystem
cron Cron job scheduler
crypto System crypto services information
date Basic system time information
dbus D-Bus message bus
devicemapper device-mapper framework
devices devices specific commands
dpkg Debian Package Management
filesys Local file systems
hardware General hardware information
host Host information
i18n Internationalization
iscsi iSCSI initiator
java Java runtime
kernel Linux kernel
last login information
libraries Dynamic shared libraries
libvirt libvirt virtualization API
logrotate LogRotate service
logs System logs
lvm2 LVM2 volume manager
lxd LXD is a containers hypervisor.
md MD RAID subsystem
memory Memory configuration and use
multipath Device-mapper multipath tools
mysql MySQL and MariaDB RDBMS
networking network and device configuration
openssl openssl related information for Debian distributions
pam Pluggable Authentication Modules
pci PCI devices
perl Perl runtime
procenv Process environment
process process information
processor CPU information
release Linux release information
scsi SCSI devices
services System services
snappy Snap packages
soundcard Sound devices
ssh Secure shell service
system core system information
systemd System management daemon
sysvipc SysV IPC
ubuntu Ubuntu specific information
udev udev dynamic device management
usb USB devices
wireless Wireless
x11 X windowing system
xfs XFS filesystem
The following plugins are currently disabled:
activemq inactive ActiveMQ message broker
anacron inactive Anacron job scheduling service
ansible inactive Ansible configuration management
auditd inactive Audit daemon information
autofs inactive Autofs on-demand automounter
azure inactive Microsoft Azure client
canonical_livepatch inactive Canonical Livepatch Service
ceph inactive CEPH distributed storage
ceph_ansible inactive CEPH distributed storage - Ansible installer
clear_containers inactive Intel(R) Clear Containers configuration
cobbler inactive
collectd inactive Collectd config collector
conntrackd inactive conntrackd - netfilter connection tracking user-space daemon
corosync inactive Corosync cluster engine
ctdb inactive Samba Clustered TDB
cups inactive CUPS IPP print service
dhcp inactive DHCP daemon
dlm inactive DLM (Distributed lock manager)
dmraid inactive dmraid software RAID
docker inactive Docker containers
dovecot inactive dovecot server related information for Debian based distribution
elastic inactive ElasticSearch service
gdm inactive GNOME display manager
gfs2 inactive GFS2 (Global Filesystem 2)
grub inactive GRUB bootloader
grub2 inactive GRUB2 bootloader
haproxy inactive HAProxy load balancer
hpasm inactive HP Advanced Server Management
infiniband inactive Infiniband data
ipmitool inactive IpmiTool hardware information.
iprconfig inactive IBM Power RAID storage adapter configuration information
ipsec inactive Internet protocol security
ipvs inactive Linux IP virtual server
iscsitarget inactive iSCSI target
juju inactive Juju orchestration tool
kata_containers inactive Kata Containers configuration
kdump inactive Kdump crash dumps
kimchi inactive kimchi-related information
krb5 inactive Kerberos authentication
kvm inactive Kernel virtual machine
landscape inactive Ubuntu Landscape client
ldap inactive LDAP configuration
lightdm inactive Light Display Manager
lilo inactive Lilo bootloader
lstopo inactive lstopo / machine topology/numa node information
maas inactive Ubuntu Metal-As-A-Service
memcached inactive memcached distributed memory caching system
mongodb inactive MongoDB document database
mpt inactive LSI Message Passing Technology
named inactive BIND named server
networkmanager inactive NetworkManager service configuration
nfs inactive Network file system information
nfsganesha inactive NFS-Ganesha file server information
nis inactive Network information service
nodejs inactive Ubuntu/Debian require nodejs-legacy package in order to
have a node executable
npm inactive Get info about available npm modules
nscd inactive Name service caching daemon
nss inactive Network Security Services configuration
ntp inactive Network time protocol
numa inactive NUMA state and configuration
nvme inactive Collect config and system information about NVMe devices
omsa inactive Dell OpenManage Server Administrator (OMSA)
opencl inactive OpenCL
opengl inactive OpenGL
openstack_ansible inactive OpenStack-Ansible sos plugin.
openstack_ceilometer inactive Openstack Ceilometer
openstack_cinder inactive OpenStack cinder
openstack_glance inactive OpenStack Glance
openstack_heat inactive OpenStack Heat
openstack_horizon inactive OpenStack Horizon
openstack_ironic inactive OpenStack Ironic
openstack_keystone inactive OpenStack Keystone
openstack_manila inactive OpenStackManila related information for Debian based distributions.
openstack_neutron inactive OpenStack Networking
openstack_nova inactive OpenStack Nova
openstack_octavia inactive Openstack Octavia
openstack_sahara inactive OpenStackSahara related information for Debian based distributions.
openstack_swift inactive OpenStack Swift
openstack_trove inactive OpenStack Trove
openswan inactive Openswan IPsec
openvswitch inactive OpenVSwitch networking
os_net_config inactive OpenStack Net Config
ovn_central inactive OVN Northd
ovn_host inactive OVN Controller
pacemaker inactive Pacemaker high-availability cluster resource manager
pcp inactive Performance Co-Pilot data
postfix inactive Postfix smtp server
postgresql inactive PostgreSQL RDBMS
powerpc inactive IBM Power systems
ppp inactive Point-to-point protocol
acct inactive Process accounting information
ptp inactive Precision time protocol
puppet inactive Puppet service
pxe inactive PXE service
python inactive Python runtime
rabbitmq inactive RabbitMQ messaging service
radius inactive RADIUS service information
s390 inactive IBM S/390
salt inactive Salt
saltmaster inactive Salt Master
samba inactive Samba Windows interoperability
sar inactive System Activity Reporter
sas3ircu inactive SAS-3 Integrated RAID adapter information
sendmail inactive sendmail service
snmp inactive Simple network management protocol
squid inactive Squid caching proxy
sssd inactive System security service daemon
storageconsole inactive Red Hat Storage Console
sunrpc inactive Sun RPC service
systemtap inactive SystemTap dynamic instrumentation
targetcli inactive TargetCLI TCM/LIO configuration
teamd inactive Network interface teaming
unity inactive Unity
upstart inactive Upstart init system
virsh inactive client for libvirt virtualization API
vulkan inactive Vulkan
xinetd inactive xinetd information
zfs inactive ZFS filesystem
The following plugin options are available:
apache.log off gathers all apache logs
boot.all-images off collect lsinitrd for all images
filesys.lsof off gathers information on all open files
filesys.dumpe2fs off dump filesystem information
filesys.frag off filesystem fragmentation status
kernel.with-timer off gather /proc/timer* statistics
libraries.ldconfigv off collect verbose ldconfig output
lvm2.lvmdump off collect an lvmdump tarball
lvm2.lvmdump-am off attempt to collect an lvmdump with advanced options and raw metadata collection
mysql.dbuser mysql username for database dumps
mysql.dbpass off password for database dumps (password visible in process listings)
mysql.dbdump off collect a database dump
networking.traceroute off collect a traceroute to www.example.com
process.lsof-threads off gathers threads' open file info if supported
services.servicestatus off get a status of all running services
Profiles: boot, container, debug, desktop, hardware, identity, java,
kernel, memory, network, openshift, packagemanager, perl,
security, services, storage, sysmgmt, system, virt,
webserver
20 profiles, 58 plugins
If you want to generate sosreport only for specific plugins like apache, run the following command:
sosreport -o apache --batch
information will be generated in /tmp/sos.uwazci0o.
Running 1/1: apache...
/tmp/sosreport-ubuntu1804-20190130103821.tar.xz
The checksum is: 27dea53416ae1fae56ad4448a5cf6189
The above command will generate sosreport for apache and save it in the /tmp/sosreport-ubuntu1804-20190130103821.tar.xz file.
You can extract the file with the following command:
tar -xvf /tmp/sosreport-ubuntu1804-20190130103821.tar.xz
Now, change the directory to the sosreport-ubuntu1804-20190130103821 with the following command:
cd sosreport-ubuntu1804-20190130103821
Next, run the following command to list out all the files generated by sosreport:
tree
Output:
??? etc
?   ??? apache2
?   ??? apache2.conf
?   ??? conf-available
?   ?   ??? charset.conf
?   ?   ??? javascript-common.conf
?   ?   ??? localized-error-pages.conf
?   ?   ??? other-vhosts-access-log.conf
?   ?   ??? security.conf
?   ?   ??? serve-cgi-bin.conf
?   ??? conf-enabled
?   ?   ??? charset.conf -> ../conf-available/charset.conf
?   ?   ??? localized-error-pages.conf -> ../conf-available/localized-error-pages.conf
?   ?   ??? other-vhosts-access-log.conf -> ../conf-available/other-vhosts-access-log.conf
?   ?   ??? security.conf -> ../conf-available/security.conf
?   ?   ??? serve-cgi-bin.conf -> ../conf-available/serve-cgi-bin.conf
?   ??? envvars
?   ??? magic
?   ??? mods-available
?   ?   ??? access_compat.load
?   ?   ??? actions.conf
?   ?   ??? actions.load
?   ?   ??? alias.conf
?   ?   ??? alias.load
?   ?   ??? allowmethods.load
?   ?   ??? asis.load
?   ?   ??? auth_basic.load
?   ?   ??? auth_digest.load
?   ?   ??? auth_form.load
?   ?   ??? authn_anon.load
?   ?   ??? authn_core.load
?   ?   ??? authn_dbd.load
?   ?   ??? authn_dbm.load
?   ?   ??? authn_file.load
?   ?   ??? authn_socache.load
?   ?   ??? authnz_fcgi.load
?   ?   ??? authnz_ldap.load
?   ?   ??? authz_core.load
?   ?   ??? authz_dbd.load
?   ?   ??? authz_dbm.load
?   ?   ??? authz_groupfile.load
?   ?   ??? authz_host.load
?   ?   ??? authz_owner.load
?   ?   ??? authz_user.load
?   ?   ??? autoindex.conf
?   ?   ??? autoindex.load
?   ?   ??? buffer.load
?   ?   ??? cache_disk.conf
?   ?   ??? cache_disk.load
?   ?   ??? cache.load
?   ?   ??? cache_socache.load
?   ?   ??? cern_meta.load
?   ?   ??? cgid.conf
?   ?   ??? cgid.load
?   ?   ??? cgi.load
?   ?   ??? charset_lite.load
?   ?   ??? data.load
?   ?   ??? dav_fs.conf
?   ?   ??? dav_fs.load
?   ?   ??? dav.load
?   ?   ??? dav_lock.load
?   ?   ??? dbd.load
?   ?   ??? deflate.conf
?   ?   ??? deflate.load
?   ?   ??? dialup.load
?   ?   ??? dir.conf
?   ?   ??? dir.load
?   ?   ??? dump_io.load
?   ?   ??? echo.load
?   ?   ??? env.load
?   ?   ??? expires.load
?   ?   ??? ext_filter.load
?   ?   ??? file_cache.load
?   ?   ??? filter.load
?   ?   ??? headers.load
?   ?   ??? heartbeat.load
?   ?   ??? heartmonitor.load
?   ?   ??? http2.load
?   ?   ??? ident.load
?   ?   ??? imagemap.load
?   ?   ??? include.load
?   ?   ??? info.conf
?   ?   ??? info.load
?   ?   ??? lbmethod_bybusyness.load
?   ?   ??? lbmethod_byrequests.load
?   ?   ??? lbmethod_bytraffic.load
?   ?   ??? lbmethod_heartbeat.load
?   ?   ??? ldap.conf
?   ?   ??? ldap.load
?   ?   ??? log_debug.load
?   ?   ??? log_forensic.load
?   ?   ??? lua.load
?   ?   ??? macro.load
?   ?   ??? mime.conf
?   ?   ??? mime.load
?   ?   ??? mime_magic.conf
?   ?   ??? mime_magic.load
?   ?   ??? mpm_event.conf
?   ?   ??? mpm_event.load
?   ?   ??? mpm_prefork.conf
?   ?   ??? mpm_prefork.load
?   ?   ??? mpm_worker.conf
?   ?   ??? mpm_worker.load
?   ?   ??? negotiation.conf
?   ?   ??? negotiation.load
?   ?   ??? proxy_ajp.load
?   ?   ??? proxy_balancer.conf
?   ?   ??? proxy_balancer.load
?   ?   ??? proxy.conf
?   ?   ??? proxy_connect.load
?   ?   ??? proxy_express.load
?   ?   ??? proxy_fcgi.load
?   ?   ??? proxy_fdpass.load
?   ?   ??? proxy_ftp.conf
?   ?   ??? proxy_ftp.load
?   ?   ??? proxy_hcheck.load
?   ?   ??? proxy_html.conf
?   ?   ??? proxy_html.load
?   ?   ??? proxy_http2.load
?   ?   ??? proxy_http.load
?   ?   ??? proxy.load
?   ?   ??? proxy_scgi.load
?   ?   ??? proxy_wstunnel.load
?   ?   ??? ratelimit.load
?   ?   ??? reflector.load
?   ?   ??? remoteip.load
?   ?   ??? reqtimeout.conf
?   ?   ??? reqtimeout.load
?   ?   ??? request.load
?   ?   ??? rewrite.load
?   ?   ??? sed.load
?   ?   ??? session_cookie.load
?   ?   ??? session_crypto.load
?   ?   ??? session_dbd.load
?   ?   ??? session.load
?   ?   ??? setenvif.conf
?   ?   ??? setenvif.load
?   ?   ??? slotmem_plain.load
?   ?   ??? slotmem_shm.load
?   ?   ??? socache_dbm.load
?   ?   ??? socache_memcache.load
?   ?   ??? socache_shmcb.load
?   ?   ??? speling.load
?   ?   ??? ssl.conf
?   ?   ??? ssl.load
?   ?   ??? status.conf
?   ?   ??? status.load
?   ?   ??? substitute.load
?   ?   ??? suexec.load
?   ?   ??? unique_id.load
?   ?   ??? userdir.conf
?   ?   ??? userdir.load
?   ?   ??? usertrack.load
?   ?   ??? vhost_alias.load
?   ?   ??? xml2enc.load
?   ??? mods-enabled
?   ?   ??? access_compat.load -> ../mods-available/access_compat.load
?   ?   ??? alias.conf -> ../mods-available/alias.conf
?   ?   ??? alias.load -> ../mods-available/alias.load
?   ?   ??? auth_basic.load -> ../mods-available/auth_basic.load
?   ?   ??? authn_core.load -> ../mods-available/authn_core.load
?   ?   ??? authn_file.load -> ../mods-available/authn_file.load
?   ?   ??? authz_core.load -> ../mods-available/authz_core.load
?   ?   ??? authz_host.load -> ../mods-available/authz_host.load
?   ?   ??? authz_user.load -> ../mods-available/authz_user.load
?   ?   ??? autoindex.conf -> ../mods-available/autoindex.conf
?   ?   ??? autoindex.load -> ../mods-available/autoindex.load
?   ?   ??? deflate.conf -> ../mods-available/deflate.conf
?   ?   ??? deflate.load -> ../mods-available/deflate.load
?   ?   ??? dir.conf -> ../mods-available/dir.conf
?   ?   ??? dir.load -> ../mods-available/dir.load
?   ?   ??? env.load -> ../mods-available/env.load
?   ?   ??? filter.load -> ../mods-available/filter.load
?   ?   ??? mime.conf -> ../mods-available/mime.conf
?   ?   ??? mime.load -> ../mods-available/mime.load
?   ?   ??? mpm_event.conf -> ../mods-available/mpm_event.conf
?   ?   ??? mpm_event.load -> ../mods-available/mpm_event.load
?   ?   ??? negotiation.conf -> ../mods-available/negotiation.conf
?   ?   ??? negotiation.load -> ../mods-available/negotiation.load
?   ?   ??? reqtimeout.conf -> ../mods-available/reqtimeout.conf
?   ?   ??? reqtimeout.load -> ../mods-available/reqtimeout.load
?   ?   ??? setenvif.conf -> ../mods-available/setenvif.conf
?   ?   ??? setenvif.load -> ../mods-available/setenvif.load
?   ?   ??? status.conf -> ../mods-available/status.conf
?   ?   ??? status.load -> ../mods-available/status.load
?   ??? ports.conf
?   ??? sites-available
?   ?   ??? 000-default.conf
?   ?   ??? default-ssl.conf
?   ??? sites-enabled
?   ??? 000-default.conf -> ../sites-available/000-default.conf
??? sos_commands
?   ??? apache
?   ??? apachectl_-M
??? sos_logs
?   ??? sos.log
?   ??? ui.log
??? sos_reports
?   ??? sos.html
?   ??? sos.txt
??? version.txt
12 directories, 189 files
You can also see different options available with sosreport command with the following command:
sosreport -h
Usage: sosreport [options]
Options:
-h, --help show this help message and exit
-l, --list-plugins list plugins and available plugin options
-n NOPLUGINS, --skip-plugins=NOPLUGINS
disable these plugins
--experimental enable experimental plugins
-e ENABLEPLUGINS, --enable-plugins=ENABLEPLUGINS
enable these plugins
-o ONLYPLUGINS, --only-plugins=ONLYPLUGINS
enable these plugins only
-k PLUGOPTS, --plugin-option=PLUGOPTS
plugin options in plugname.option=value format (see
-l)
--log-size=LOG_SIZE set a limit on the size of collected logs (in MiB)
-a, --alloptions enable all options for loaded plugins
--all-logs collect all available logs regardless of size
--batch batch mode - do not prompt interactively
--build preserve the temporary directory and do not package
results
-v, --verbose increase verbosity
--verify perform data verification during collection
--quiet only print fatal errors
--debug enable interactive debugging using the python debugger
--ticket-number=CASE_ID
specify ticket number
--case-id=CASE_ID specify case identifier
-p PROFILES, --profile=PROFILES
enable plugins selected by the given profiles
--list-profiles display a list of available profiles and plugins that
they include
--name=CUSTOMER_NAME specify report name
--config-file=CONFIG_FILE
specify alternate configuration file
--tmp-dir=TMP_DIR specify alternate temporary directory
--no-report disable HTML/XML reporting
-s SYSROOT, --sysroot=SYSROOT
system root directory path (default='/')
-c CHROOT, --chroot=CHROOT
chroot executed commands to SYSROOT [auto, always,
never] (default=auto)
-z COMPRESSION_TYPE, --compression-type=COMPRESSION_TYPE
compression technology to use [auto, gzip, bzip2, xz] (default=auto)
Some examples:
enable dlm plugin only and collect dlm lockdumps:
# sosreport -o dlm -k dlm.lockdump
disable memory and samba plugins, turn off rpm -Va collection:
# sosreport -n memory,samba -k rpm.rpmva=off
That’s it. I hope you have now enough knowledge about sosreport. To find more information refer to the sosreport man page.
