How to Install Akaunting with Apache and Let’s Encrypt SSL on Ubuntu 22.04
Akaunting is an open-source and self-hosted accounting software application for small businesses and freelancers. It is built using Laravel, Bootstrap, jQuery, and RESTful API. It is used for creating and managing invoices, quotes, and finances via a web browser. It provides an awesome App Store for users and developers to extend the functionality of Akaunting.
In this tutorial, I will show you how to install Akaunting accounting software with Apache and Let’s Encrypt SSL on Ubuntu 22.04.
  • Valid domain name pointed with your server IP.
Install Apache, MariaDB, and PHP
First, you will need to install Apache, MariaDB, PHP, and other PHP extensions on your server. You can install all of them by running the following command:
apt-get install apache2 mariadb-server php libapache2-mod-php php-common php-imap php-mbstring php-xmlrpc php-soap php-gd php-xml php-intl php-mysql php-cli php-bcmath php-ldap php-zip php-curl unzip curl -y
After installing all the packages, edit the PHP configuration file and change the default settings:
nano /etc/php/8.1/apache2/php.ini
Change the following lines:
memory_limit = 256M
upload_max_filesize = 16M
post_max_size = 16M
max_execution_time = 300
date.timezone = UTC
Save and close the file then restart the Apache service to apply the configuration changes:
systemctl restart apache2
Configure MariaDB Database
Akaunting uses a MariaDB/MySQL as a database backend. So you will need to create a database and user for Akaunting.
First, log in to the MariaDB with the following command:
mysql
Once logged in, create a database and user for Akaunting with the following command:
MariaDB [(none)]> CREATE DATABASE akaunting_db;
MariaDB [(none)]> CREATE USER 'akaunting_user'@'localhost' IDENTIFIED BY 'password';
Next, grant all privileges to the Akaunting database with the following command:
MariaDB [(none)]> GRANT ALL ON akaunting_db.* TO 'akaunting_user'@'localhost' IDENTIFIED BY 'password' WITH GRANT OPTION;
MariaDB [(none)]> EXIT;
Install Akaunting
First, go to the Akaunting official download page and download the latest version using the following command:
wget -O Akaunting.zip https://akaunting.com/download.php?version=latest
Once the download is completed, unzip the downloaded file to the Apache web root directory:
mkdir -p /var/www/html/akaunting
unzip Akaunting.zip -d /var/www/html/akaunting
Next, change the ownership and permission of the Akaunting directory:
chown -R www-data:www-data /var/www/html/akaunting/
chmod -R 755 /var/www/html/akaunting/
Configure Apache for Akaunting
Next, you will need to create an Apache virtual host configuration file for Akaunting. You can create it with the following command:
nano /etc/apache2/sites-available/akaunting.conf
DocumentRoot /var/www/html/akaunting
ServerName akaunting.example.com
DirectoryIndex index.html index.php
<Directory /var/www/html/akaunting/>
Options +FollowSymlinks
Require all granted
ErrorLog ${APACHE_LOG_DIR}/akaunting_error.log
CustomLog ${APACHE_LOG_DIR}/akaunting_access.log combined
Save and close the file then activate the Apache virtual host and rewrite module with the following command:
a2ensite akaunting
a2enmod rewrite
Next, restart the Apache service to apply the changes:
You can now check the status of the Apache with the following command:
systemctl status apache2
Active: active (running) since Sat 2022-11-12 13:45:47 UTC; 10s ago
Process: 16032 ExecStart=/usr/sbin/apachectl start (code=exited, status=0/SUCCESS)
Main PID: 16036 (apache2)
Tasks: 6 (limit: 464122)
Memory: 14.2M
??16036 /usr/sbin/apache2 -k start
??16037 /usr/sbin/apache2 -k start
??16038 /usr/sbin/apache2 -k start
??16039 /usr/sbin/apache2 -k start
??16040 /usr/sbin/apache2 -k start
??16041 /usr/sbin/apache2 -k start
Nov 12 13:45:47 ubuntu22041 systemd[1]: Starting The Apache HTTP Server...
Secure Akaunting with Let’s Encrypt SSL
Next, it is a good idea to secure your website with Let’s Encrypt SSL. First, install the Certbot client using the following command:
apt-get install certbot python3-certbot-apache -y
Once installed, run the following command to secure your website with Let’s Encrypt SSL:
certbot --apache -d akaunting.example.com
You will be asked to provide your email and accept the term of service as shown below:
Plugins selected: Authenticator standalone, Installer None
cancel): [email protected]
(A)gree/(C)ancel: A
(Y)es/(N)o: Y
Obtaining a new certificate
http-01 challenge for akaunting.example.com
Enabled Apache rewrite module
Waiting for verification...
Cleaning up challenges
Created an SSL vhost at /etc/apache2/sites-available/akaunting-le-ssl.conf
Enabled Apache socache_shmcb module
Enabled Apache ssl module
Deploying Certificate to VirtualHost /etc/apache2/sites-available/akaunting-le-ssl.conf
Enabling available site: /etc/apache2/sites-available/akaunting-le-ssl.conf
Next, select whether or not to redirect HTTP traffic to HTTPS as shown below:
Type 2 and hit Enter to install the Let’s Encrypt SSL for your website:
Redirecting vhost in /etc/apache2/sites-enabled/akaunting.conf to ssl vhost in /etc/apache2/sites-available/akaunting-le-ssl.conf
Congratulations! You have successfully enabled https://akaunting.example.com
https://www.ssllabs.com/ssltest/analyze.html?d=akaunting.example.com
IMPORTANT NOTES:
/etc/letsencrypt/live/akaunting.example.com/fullchain.pem
/etc/letsencrypt/live/akaunting.example.com/privkey.pem
Your cert will expire on 2023-02-12. To obtain a new or tweaked
Access Akaunting Web Interface
Now, open your web browser and access the Akaunting web interface using the URL http://akaunting.example.com. You will get the following screen:
Choose language
Select your language and click on the Next button. You will get the database configuration screen:
Database settings
Provide your database details and click on the Next button. You will get the Admin user account creation screen:
Company settings
Provide your company name, email, password and click on the Next button. You will get the Akaunting login screen:
Login
Provide your admin username, password and click on the Login button. You will get the following screen:
Company
Click on the Skip button. You will get the Currencies screen:
Currencies
Enable your currencies and click on the Next button. You will get the plugin screen:
Akaunting dashboard
Install your required modules and click on the Next button. You will get the following screen:
Create new invoice
You can now create your first invoice from the above screen.
Congratulations! you have successfully installed Akaunting with Apache and Let’s Encrypt SSL on Ubuntu 22.04 server. You can now host Akaunting software in your organization to manage your invoices, quote, and finances from anywhere. Feel free to ask me if you have any questions.
