How to Convert CentOS 8 to CentOS Stream
If you are using CentOS 7 and plan to upgrade CentOS 7 to CentOS 8 then better avoid upgrading to CentOS 8 as CentOS 8 support ends by the end of 2021 while CentOS 7 will be supported till 2024.
Red Hat and CentOS recently announced that CentOS 8 will be converted to CentOS Stream. So if you are using CentOS 8 then it is recommended to migrate your system from CentOS 8 to CentOS Stream.
In this tutorial, we will show you how to migrate from CentOS 8 to CentOS Stream.
  • A server running CentOS 8.
Update the System
Before starting, it is a good idea to update your system to the latest version. You can update it by running the following command:
dnf update -y
Once your system is updated, restart it to apply the changes:
reboot
Once your system is restarted, verify your system version with the following command:
cat /etc/centos-release
CentOS Linux release 8.3.2011
Upgrade from CentOS 8 to CentOS Stream
First, you will need to install the CentOS Stream release package in your system. You can install it with the following command:
dnf install centos-release-stream -y
This will install CentOS Stream reposiotry to the /etc/yum.repos.d directory:
CentOS Linux 8 - AppStream 2.4 MB/s | 6.3 MB 00:02
CentOS Linux 8 - BaseOS 1.3 MB/s | 2.3 MB 00:01
Last metadata expiration check: 0:00:01 ago on Saturday 09 January 2021 03:53:01 AM EST.
Dependencies resolved.
Package Architecture Version Repository Size
Installing:
centos-release-stream x86_64 8.1-1.1911.0.7.el8 extras 11 k
Transaction Summary
Install 1 Package
Total download size: 11 k
Installed size: 6.6 k
Downloading Packages:
centos-release-stream-8.1-1.1911.0.7.el8.x86_64.rpm 195 kB/s | 11 kB 00:00
Total 9.6 kB/s | 11 kB 00:01
Running transaction check
Transaction check succeeded.
Running transaction test
Transaction test succeeded.
Running transaction
Preparing : 1/1
Installing : centos-release-stream-8.1-1.1911.0.7.el8.x86_64 1/1
Verifying : centos-release-stream-8.1-1.1911.0.7.el8.x86_64 1/1
Installed:
Complete!
Next, you will need to remove the CentOS 8 repository file from your system. You can remove all with the following command:
dnf swap centos-{linux,stream}-repos -y
Last metadata expiration check: 0:00:19 ago on Saturday 09 January 2021 03:53:29 AM EST.
Installing:
centos-stream-release noarch 8.4-1.el8 Stream-BaseOS 21 k
replacing centos-linux-release.noarch 8.3-1.2011.el8
replacing centos-release-stream.x86_64 8.1-1.1911.0.7.el8
centos-stream-repos noarch 8-2.el8 Stream-BaseOS 19 k
Removing:
centos-linux-repos noarch 8-2.el8 @BaseOS 26 k
Transaction Summary
Install 2 Packages
Remove 1 Package
Total download size: 40 k
(1/2): centos-stream-release-8.4-1.el8.noarch.rpm 116 kB/s | 21 kB 00:00
(2/2): centos-stream-repos-8-2.el8.noarch.rpm 101 kB/s | 19 kB 00:00
Total 144 kB/s | 40 kB 00:00
Running transaction
Preparing : 1/1
Running scriptlet: centos-stream-repos-8-2.el8.noarch 1/1
Installing : centos-stream-repos-8-2.el8.noarch 1/5
Installing : centos-stream-release-8.4-1.el8.noarch 2/5
Obsoleting : centos-release-stream-8.1-1.1911.0.7.el8.x86_64 3/5
Obsoleting : centos-linux-release-8.3-1.2011.el8.noarch 4/5
Erasing : centos-linux-repos-8-2.el8.noarch 5/5
Running scriptlet: centos-linux-repos-8-2.el8.noarch 5/5
Verifying : centos-stream-release-8.4-1.el8.noarch 1/5
Verifying : centos-linux-release-8.3-1.2011.el8.noarch 2/5
Verifying : centos-release-stream-8.1-1.1911.0.7.el8.x86_64 3/5
Verifying : centos-stream-repos-8-2.el8.noarch 4/5
Verifying : centos-linux-repos-8-2.el8.noarch 5/5
Installed:
centos-stream-release-8.4-1.el8.noarch centos-stream-repos-8-2.el8.noarch
Removed:
Complete!
Next, you will need to sync all the packages to the latest version. You can do it with the following command:
dnf distro-sync -y
This command will take some time to sync all packages. Once you are finished, restart your system to apply the configuration changes:
reboot
Next, verify your system with the following command:
Your system is now upgraded to the CentOS Stream as shown below:
CentOS Stream release 8
You can also verify your repository with the following command:
ls /etc/yum.repos.d/
CentOS-Stream-AppStream.repo CentOS-Stream-Debuginfo.repo CentOS-Stream-HighAvailability.repo CentOS-Stream-PowerTools.repo
CentOS-Stream-BaseOS.repo CentOS-Stream-Extras.repo CentOS-Stream-Media.repo CentOS-Stream-RealTime.repo
Congratulations! you have successfully upgrade your CentOS 8 system to CentOS Stream. Feel free to ask me if you have any questions.
