How to Connect to MySQL Using PHP
To access and add content to a MySQL database, you must first establish a connection between the database and a PHP script.
In this tutorial, learn how to use MySQLi Extension and PHP Data Objects to connect to MySQL. Traditional legacy mysql_ functions are deprecated and we will not cover them in this guide.
header image how to connect to mysql using php
  • Special CREATE privileges
  • A MySQL Database
  • A MySQLi or PDO extension
2 Ways to Connect to MySQL database using PHP
There are two popular ways to connect to a MySQL database using PHP:
  1. With PHP’s MySQLi Extension
  2. With PHP Data Objects (PDO)
The guide also includes explanations for the credentials used in the PHP scripts and potential errors you may come across using MySQLi and PDO.
Option 1: Connect to MySQL with MySQL Improved extension
MySQLi is an extension that only supports MySQL databases. It allows access to new functionalities found in MySQL systems (version 4.1. and above), providing both an object-oriented and procedural interface. It supports server-side prepared statements, but not client-side prepared statements.
The MySQLi extension is included PHP version 5 and newer.
The PHP script for connecting to a MySQL database using the MySQLi procedural approach is the following:
<?php
$servername = "localhost";
$database = "database";
$username = "username";
$password = "password";
// Create connection
$conn = mysqli_connect($servername, $username, $password, $database);
// Check connection
if ($conn->connect_error) {
die("Connection failed: " . $conn->connect_error);
echo “Connected successfully”;
mysqli_close($conn);
Credentials Explained
The first part of the script is four variables (server name, database, username, and password) and their respective values. These values should correspond to your connection details.
examples of database variables
Next is the main PHP function mysqli_connect(). It establishes a connection with the specified database.
Configuration file with the main php function to connect to MySQL.
Following is an “if statement.” It is the part of the code that shows whether the connection was established. When the connection fails, it gives the message Connection failed. The die function prints the message and then exits out of the script.
example of connection failed die function
If the connection is successful, it displays “Connected successfully.”
connected successfully to MySQL message
When the script ends, the connection with the database also closes. If you want to end the code manually, use the mysqli_close function.
message for script ended and connection to database closed
Option 2: Connect To MySQL With PDO
PHP Data Objects (PDO) is an extension that serves as an interface for connecting to databases. Unlike MySQLi, it can perform any database functions and is not limited to MySQL. It allows flexibility among databases and is more general than MySQL. PDO supports both server and client-side prepared statements.
Note: PDO will not run on PHP versions older than 5.0 and is included in PHP 5.1.
The PHP code for connecting to a MySQL database through the PDO extension is:
<?php
$charset = "utf8mb4";
try {
$dsn = "mysql:host=$servername;dbname=$database;charset=$charset";
$pdo = new PDO($dsn, $username, $password);
$pdo->setAttribute(PDO::ATTR_ERRMODE, PDO::ERRMODE_EXCEPTION);
echo “Connection Okay”;
return $pdo
catch (PDOException $e)
echo “Connection failed: ”. $e->getMessage();
Credentials Syntax
First, we have five variables (server name, database, username, password, and charset) and their values. These values should correspond to your connection details.
The server name will be localhost. If connected to an online server, type in the server name of that server.
The variable charset tells the database in which encoding it will be receiving and sending data. The recommended standard is utf8mb4.
example for database syntax variables server name, database, username, password, and charset
Try and Catch Blocks
PDO’s great asset is that it has an exception class to take care of any potential problems in database queries. It solves these problems by incorporating try and catch blocks.
If a problem arises while trying to connect, it stops running and attempts to catch and solve the issue. Catch blocks can be set to show error messages or run an alternative code.
example of error message for catch blocks
The first parameter in the try and catch block is DSN, which stands for data(base) source name. It is crucial as it defines the type and name of the database, along with any other additional information.
In this example, we are using a MySQL database. However, PDO supports various types of databases. If you have a different database, replace that part of the syntax (mysql) with the database you are using.
example of mysql host connecting
Next is the PDO variable. This variable is going to establish a connection to the database. It has three parameters:
  1. The data source name (dsn)
  2. The username for your database
  3. The password for your database
example of username and password new pdo
Following is the setAttribute method adding two parameters to the PDO:
  1. PDO::ATTR_ERRMODE
  2. PDO::ERRMODE_EXCEPTION
This method instructs the PDO to run an exception in case a query fails.
example of pdo running an exception
Add the echo “Connection Okay.” to confirm a connection is established.
message for echo connection ok
Return the PDO variable to connect to the database.
example of pdo variable for database connection
After returning the PDO variable, define the PDOException in the catch block by instructing it to display a message when the connection fails.
example of displaying a message when connection fails
Potential Errors with MySQLi and PDO
Incorrect Password
The password in the PHP code needs to correspond with the one in the database. If the two do not match, a connection with the database cannot be established. You will receive an error message saying the connection has failed.
Possible solutions:
  1. Check the database details to ensure the password is correct.
  2. Ensure there is a user assigned to the database.
Unable to Connect to MySQL Server
PHP may not be able to connect to the MySQL server if the server name is not recognized. Make sure that the server name is set to localhost.
In case of other errors, make sure to consult the error_log file to help when trying to solve any issues. The file is located in the same folder where the script is running.
This guide detailed two ways to connect to a MySQL database using PHP.
Both MySQLi and PDO have their advantages. However, bear in mind that MySQLi is only used for MySQL databases. Therefore, if you want to change to another database, you will have to rewrite the entire code. On the other hand, PDO works with 12 different databases, which makes the migration much easier.
