How to add and remove Cronjobs from Linux EC2 instances on AWS using shell scripts
Manual operations lead to human errors. Adding and removing Cronjobs frequently can be a very time-consuming task. In this article, we will create Shell scripts that automate the addition and deletion of Cronjobs from Ubuntu EC2 instances on AWS. To perform these operations you will need access to the EC2 instance. The user you will use needs to have sudo access so that the user can switch to root and perform addition and deletion of Cronjobs.
Let’s get started.
- Basic understanding of Shell scripts and Cronjobs.
- EC2 Instance with the user having sudo access (Click here to learn to create an EC2 instance if you don’t have one or if you want to learn )
What will we do
- Create a shell script to add Cronjobs.
- Execute the Shell script to add a Cronjob.
- Create a shell script to remove Cronjobs.
- Execute the Shell script to remove the Cronjob.
Create a file on your local Linux System and add the following code to it. You can also find the code on my Github repo on the following link.
Github Link: https://github.com/shivalkarrahul/DevOps/blob/master/aws/shell-scripts/aws-ec2-add-remove-cron-job/add-cronjob.sh
File: add-cronjob.sh
#!/bin/bash
helpFunction()
echo ""
printf "33[1;32mUsage: $0 -K <internal.pem> -U <internal-user> -I <internal-ip> -a <cron-to-be-added>"
echo ""
echo -e "t-K ".pem key of the server on which a cron job has to be added""
echo -e "t-U UserName of the server on which a cron job has to be added"
echo -e "t-I IP of the server on which a cron job has to be added"
echo -e "t-a Name of the cron to be added (in double quotes)"
echo "Add a new Cron Job"
echo "e.g."
echo "./add-cronjob.sh -K /Users/cloudcover/Documents/Rahul/access/rahuls.pem -U ubuntu -I ec2-35-180-234-158.eu-west-3.compute.amazonaws.com -a "0 5 * * 1 testCronJob""
echo -e "33[0m" #reset color
exit 1 # Exit script after printing help
while getopts "I:K:U:a:" opt
do
case "$opt" in
K ) internalServerPemKey="$OPTARG" ;;
U ) internalServerUser="$OPTARG" ;;
I ) internalServerIP="$OPTARG" ;;
a ) addCron="$OPTARG" ;;
? ) helpFunction ;; # Print helpFunction in case parameter is non-existent
esac
done
echo "******************"
#echo $listCronJobs
# Print helpFunction in case parameters are empty
if [ -z "$internalServerIP" ] || [ -z "$internalServerPemKey" ] || [ -z "$internalServerUser" ] || [ -z "$addCron" ]
then
printf "33[1;31m"
echo "Some or all of the parameters are empty";
helpFunction
fi
# Begin script in case all parameters are correct
printf "33[1;33m------------------------------------------------------------------Before ssh"
echo ".pem key of the server on which a new user has be created : $internalServerPemKey"
echo "UserName of the server on which a new user has be created : $internalServerUser"
echo "IP of the server on which a new user has be created : $internalServerIP"
echo "Name of the cron to be added : $addCron"
printf "33[1;31mLogging into: "$internalServerPemKey" "$internalServerUser"@"$internalServerIP"33[0mn"
ssh -i "$internalServerPemKey" "$internalServerUser"@"$internalServerIP" << HERE
printf "33[1;33m------------------------------------------------------------------After ssh"
#echo "Executing connect_prod_cron_new.sh"
#sh connect_prod_cron_new.sh
#sleep 2
echo "after ssh"
echo "IP Of the Server:"
hostname -I
echo "Hostname of the Server:"
hostname
echo "Changing user to root"
sudo su <><> EOF
echo "User Switched To;"
whoami
printf "33[1;33m------------------------------------------------------------------List of Cron Jobs Before Addition"
crontab -l | cat -n
if [ -n "$addCron" ]
then
echo "Inside addCron"
crontab -l >crontab.tmp
printf '%sn' "$addCron" >>crontab.tmp
crontab crontab.tmp && rm -f crontab.tmp
fi
printf "33[1;33m------------------------------------------------------------------Updated List of Cron Jobs"
crontab -l | cat -n
printf "33[1;31mExiting from ---> "$internalServerPemKey" "$internalServerUser"@"$internalServerIP"33[0mn"
#echo "Existing user ---> $userName"
EOF
HERE
Before you create a new Cronjob, check if the EC2 instance has any existing Cronjobs
Login to the EC2 instance and check existing Cronjobs
ssh -i ~/Downloads/howtoforge-test.pem [email protected]
List the Cronjobs
crontab -l
Go to your local Linux machine and add a Cronjob on Ubuntu 18.04 EC2 instance using the following command. This will create a Cronjob that will be triggered every minute and write the current date to a file. You can change the Cronjob as per your requirement.
./add-cronjob.sh -K ~/Downloads/howtoforge-test.pem -U ubuntu -I ec2-15-236-64-128.eu-west-3.compute.amazonaws.com -a "* * * * * /bin/date >> /tmp/cron_output"
Now, you can also go to the EC2 instance to check if the Cronjob has been added or not.
sudo -i
crontab -l
cat /tmp/cron_output
In the following screenshot, you can see that the Cronjob has been added and executed every minute.
Now, if you think you need to remove the Cronjob you added, you can easily do it using the shell script available on my Github.
Create a new file on your local system with the following code.
Github Link: https://github.com/shivalkarrahul/DevOps/blob/master/aws/shell-scripts/aws-ec2-add-remove-cron-job/remove-cronjob.sh
File: remove-cronjob.sh
#!/bin/bash
helpFunction()
echo ""
printf "33[1;32mUsage: $0 -K <internal.pem> -U <internal-user> -I <internal-ip> -l <yes/no>"
echo ""
echo -e "t-K ".pem key of the server on which a cron job has to be removed""
echo -e "t-U UserName of the server on which a cron job has to be removed"
echo -e "t-I IP of the server on which a cron job has to be removed"
echo -e "t-l List the existing Cron Jobs, provide "yes" as a parameter. Get a list first and then specify job no which needs to be removed"
echo -e "e.g."
echo "Remove a new Cron Job"
echo "./remove-cronjob.sh -K /Users/cloudcover/Documents/Rahul/access/rahuls.pem -U ubuntu -I ec2-52-47-90-247.eu-west-3.compute.amazonaws.com -l yes"
while getopts "I:K:U:l:" opt
do
case "$opt" in
l ) showListOfJobs="$OPTARG" ;;
esac
done
echo $listCronJobs
if [ -z "$internalServerIP" ] || [ -z "$internalServerPemKey" ] || [ -z "$internalServerUser" ] || [ -z "$showListOfJobs" ]
then
printf "33[1;31m"
helpFunction
fi
if [ $showListOfJobs == "yes" ] then
echo "after ssh"
hostname -I
hostname
sudo su << EOF
whoami
printf "33[1;33m------------------------------------------------------------------List of Cron Jobs Before Deletion"
crontab -l | cat -n
EOF
HERE
fi
echo "Enter Cron Job Line Number to be removed"
read lineNumber
echo "after ssh"
hostname -I
hostname
#sleep 2
sudo su << EOF
whoami
crontab -l | cat -n
crontab -l | sed -e "$lineNumber"d >crontab.tmp
crontab -l | cat -n
EOF
HERE
To remove the Cronjobs, execute the shell script. It will list all the Cronjob available on your Ubuntu 18.04 EC2 instance. You can then select the job to be deleted, the script will do the deletion for you.
./remove-cronjob.sh -K ~/Downloads/howtoforge-test.pem -U ubuntu -I ec2-15-236-64-128.eu-west-3.compute.amazonaws.com -l yes
Now, you can execute the same script again to list the Cronjob in the EC2 instance.
You can also check the Cronjob from the EC2 instance itself.
sudo -i
crontab -l
In this article, we saw Shell scripts to add and remove Cronjobs from Ubuntu EC2 instance. This will help to automate the manual task of adding or removing Cronjobs and also avoid potential human errors that can come due to manual operations.
