Docker on Raspberry Pi – Installation Guide
Docker is a tool for creating, deploying, and running applications in containers. The software is popular among developers as it speeds up the development process and does not use a lot of resources.
Docker containers are lightweight, especially compared to virtual machines. This feature is especially valuable if you are a Raspberry Pi user.
If you need help installing Docker on your Raspberry Pi, read our step-by-step guide on how to install Docker on Raspberry Pi.
Tutorial on how to install Docker on Raspebby Pi.
  • Raspberry Pi with a running Raspbian OS
  • Raspbian Stretch (Lite)
  • SSH connection enabled
How to Install Docker on Raspberry Pi
To install Docker on your Raspberry Pi, you need to go through the following steps:
  1. Update and upgrade your system.
  2. Download the installation script and install the package.
  3. Allow a non-root user to execute Docker commands.
  4. Verify installation by checking the Docker version.
  5. Test the setup by running a “hello-world” container.
Step 1: Update and Upgrade
Start by updating and upgrading the system. This ensures you install the latest version of the software.
Open a terminal window and run the command:
sudo apt-get update && sudo apt-get upgrade
Updating and upgrading Raspbian repositories before installation of Docker on Raspberry Pi.
Note: To avoid security and performance issues make sure to update Raspberry Pi frequently.
Step 2: Download the Convenience Script and Install Docker on Raspberry Pi
Move on to downloading the installation script with:
curl -fsSL https://get.docker.com -o get-docker.sh
Execute the script using the command:
sudo sh get-docker.sh
This installs the required packages for your Raspbian Linux distribution.
How to download convenience script to install Docker on Raspberry Pi.
The output will tell you which version of Docker is now running on your system.
Information on Docker version running on your Raspberry Pi.
Step 3: Add a Non-Root User to the Docker Group
By default, only users who have administrative privileges (root users) can run containers. If you are not logged in as the root, one option is to use the sudo prefix.
However, you could also add your non-root user to the Docker group which will allow it to execute docker commands.
The syntax for adding users to the Docker group is:
sudo usermod -aG docker [user_name]
To add the Pi user (the default user in Raspbian), use the command:
sudo usermod -aG docker Pi
There is no specific output if the process is successful. For the changes to take place, you need to log out and then back in.
Step 4: Check Docker Version and Info
Check the version of Docker on your Raspberry Pi by typing:
docker version
The output will display the Docker version along with some additional information.
For system-wide information (including the kernel version, number of containers and images, and more extended description) run:
docker info
Step 5: Run Hello World Container
The best way to test whether Docker has been set up correctly is to run the Hello World container.
To do so, type in the following command:
docker run hello-world
The software will contact the Docker daemon, pull the “hello-world” image, and create a new container based on that image.
Once it goes through all the steps, the output should inform you that your installation appears to be working correctly.
Verifying if Docker installation is running correctly on your Raspberry Pi.
Note: Try out creating containers on your own and get acquainted with some of the best practices for managing Docker containers.
Managing Docker on Raspberry Pi
In the following section, learn more about Docker images on Raspberry Pi, and how to upgrade or uninstall Docker on Raspberry Pi.
Raspberry Pi Docker Images
Opposed to most other Linux distributions, Raspberry Pi is based on ARM architecture. Hence, not all Docker images will work on your Raspberry Pi.
In fact, all Docker images that are not specifically designed for ARM devices will not work. Running docker-apps designed for x86/x64 and i386 architecture on your Raspberry Pi will return an error.
Remember that when searching for images to pull from Docker Hub. Apply the Architectures filter to search for supported apps.
For custom solutions, the best thing to do would be to run a container based on an official image and then modify it and commit the changes to a new image.
How to Upgrade Docker on Raspberry Pi?
There is no need to re-run the convenience script to upgrade Docker. Furthermore, running the convenience script again might cause issues if it attempts to repositories that have been added already.
Upgrade Docker using the package manager with the command:
How to Uninstall Docker on Your Raspberry Pi?
Although you used a convenience script for installation, you can simply remove docker using the package manager:
sudo apt-get purge docker-ce
Uninstall docker on raspberry pi using the purge command.
Note: Depending on the version of software, you may need to use an additional command to completely remove Docker: sudo apt-get purge docker-ce-cli.
To delete leftover images, containers, volumes and other related data, run the following command:
sudo rm -rf /var/lib/docker
Edited configuration files must be deleted manually.
You are now set to use Docker on your Raspberry Pi and develop isolated and lightweight applications using containers.
