Hướng dẫn cài đặt Rancher trên Ubuntu 22.04
Rancher is a free, open-source, and multi-cluster orchestration platform that allows organizations to deploy containers in a production environment. It allows you to streamline cluster deployment on bare metal, private clouds, public clouds, or vSphere and secure them using global security policies. Using this container management platform, you can deploy, manage and run Kubernetes everywhere.
Features of RancherEzoic
  • Cross-host networking
  • Container load balancing
  • Persistent Storage Services
  • Service discovery
  • Service upgrades
  • Resource management
  • Multi-tenancy & user management
  • Multi Orchestration Engines
This tutorial will show you how to install the Rancher Kubernetes container management platform on Ubuntu 22.04.
  • Minimum 4 GB of RAM.
Before starting, it is a good idea to update and upgrade all system packages to the latest version. You can update all of them by running the following command:
apt update
apt upgrade
Install Docker CE
First, you will need to install the Docker CE on your server. By default, the latest version of Docker CE is available in the Ubuntu 22.04 default repository. You can install it with the following command:
apt install docker.io -y
Once the Docker CE is installed, verify the Docker version using the following command:
docker version
Client:
 Version:           20.10.12
 API version:       1.41
 Go version:        go1.17.3
 Git commit:        20.10.12-0ubuntu4
 Built:             Mon Mar  7 17:10:06 2022
 OS/Arch:           linux/amd64
 Context:           default
 Experimental:      true
Server:
 Engine:
  Version:          20.10.12
  API version:      1.41 (minimum version 1.12)
  Built:            Mon Mar  7 15:57:50 2022
  Experimental:     false
 containerd:
  Version:          1.5.9-0ubuntu3
  GitCommit:
 runc:
  Version:          1.1.0-0ubuntu1
  GitCommit:
 docker-init:
  Version:          0.19.0
  GitCommit:
Manage Docker Services
By default, the Docker service is managed by systemd. You can manage it easily using the systemctl command.
To start the Docker service and enable it to start at system reboot, run the following command:
systemctl start docker
systemctl enable docker
You can also check the status of the Docker with the following command:
systemctl status docker
     Active: active (running) since Sun 2022-07-24 05:09:45 UTC; 24s ago
TriggeredBy: ? docker.socket
       Docs: https://docs.docker.com
   Main PID: 115654 (dockerd)
      Tasks: 7
     Memory: 30.5M
        CPU: 356ms
             ??115654 /usr/bin/dockerd -H fd:// --containerd=/run/containerd/containerd.sock
Jul 24 05:09:45 ubuntu dockerd[115654]: time="2022-07-24T05:09:45.440732558Z" level=info msg="scheme \"unix\" not registered, fallback to def>
Jul 24 05:09:45 ubuntu dockerd[115654]: time="2022-07-24T05:09:45.440869430Z" level=info msg="ccResolverWrapper: sending update to cc: {[{uni>
Jul 24 05:09:45 ubuntu dockerd[115654]: time="2022-07-24T05:09:45.440999011Z" level=info msg="ClientConn switching balancer to \"pick_first\">
Jul 24 05:09:45 ubuntu dockerd[115654]: time="2022-07-24T05:09:45.493588262Z" level=info msg="Loading containers: start."
Jul 24 05:09:45 ubuntu dockerd[115654]: time="2022-07-24T05:09:45.728082693Z" level=info msg="Default bridge (docker0) is assigned with an IP>
Jul 24 05:09:45 ubuntu dockerd[115654]: time="2022-07-24T05:09:45.888415790Z" level=info msg="Loading containers: done."
Jul 24 05:09:45 ubuntu dockerd[115654]: time="2022-07-24T05:09:45.919227724Z" level=info msg="Docker daemon" commit=20.10.12-0ubuntu4 graphdr>
Jul 24 05:09:45 ubuntu dockerd[115654]: time="2022-07-24T05:09:45.919727905Z" level=info msg="Daemon has completed initialization"
Jul 24 05:09:45 ubuntu systemd[1]: Started Docker Application Container Engine.
Install Rancher Ubuntu 22.04
At this point, Docker is installed on your system. You can now run the following command to download and launch the Rancher container.Ezoic
docker run -d --name=rancher-server --restart=unless-stopped -p 80:80 -p 443:443 --privileged rancher/rancher:v2.4.18
Unable to find image 'rancher/rancher:v2.4.18' locally
v2.4.18: Pulling from rancher/rancher
11323ed2c653: Pull complete
b7dc5ddb9fe7: Pull complete
0372c040ea0d: Pull complete
5a7eaf28cae2: Pull complete
0d1eff5b3c25: Pull complete
041282f2e586: Pull complete
7cc8371df882: Pull complete
3150273d5f70: Pull complete
afc5be66b12f: Pull complete
178a32bc5aa3: Pull complete
54d219a8d26f: Pull complete
ea3ba9f14df5: Pull complete
a97b83c715bd: Pull complete
a895bd7633e7: Pull complete
516c02ccca88: Pull complete
dcb1f2890247: Pull complete
Digest: sha256:69a7403fb9fe5fe0e58c5a5ff94d04e2ca74d7fce6ed7f29a5c04311ba14cc79
Status: Downloaded newer image for rancher/rancher:v2.4.18
51405105eee8eed48dcaf7589ef253295275c941fc3963a2ca9e9c43d844b410
The above command will download the Rancher image from the Docker Hub registry and create a container from it. You can see the downloaded image using the following command:
docker images
And, You should see the following output:
REPOSITORY        TAG       IMAGE ID       CREATED        SIZE
rancher/rancher   v2.4.18   da1ad4a1e248   3 months ago   890MB
You can also verify the running container using the following command:
docker ps
You should see the Rancher container in the following output:
CONTAINER ID   IMAGE                     COMMAND           CREATED          STATUS          PORTS        NAMES
2d32d612b497   rancher/rancher:v2.4.18   "entrypoint.sh"   23 seconds ago   Up 21 seconds   0.0.0.0:80->80/tcp, :::80->80/tcp, 0.0.0.0:443->443/tcp, :::443->443/tcp   rancher-server
Access Rancher Web Interface
At this point, Rancher is installed and listens on port 443. You can now access it using the URL https://your-server-ip. You will be redirected to the Rancher welcome screen:
congdonglinux Rancher 1
Set your admin password and click on the Continue button. You should see the following screen:
congdonglinux Rancher 2
Define your server URL and click on the Save URL button. You should see the following screen:
congdonglinux Rancher 3
Allow collection of anonymous information and click on the Got it button. You should see the Rancher dashboard on the following screen:
congdonglinux Rancher 4
Manage Rancher Container
You can also see the Rancher logs using the following command:
docker container logs rancher-server
2022/07/24 05:13:27 [INFO] kontainerdriver azurekubernetesservice listening on address 127.0.0.1:39997
2022/07/24 05:13:27 [INFO] kontainerdriver azurekubernetesservice stopped
2022/07/24 05:13:27 [INFO] dynamic schema for kontainerdriver azurekubernetesservice updating
2022/07/24 05:14:15 [INFO] Catalog-cache removed 2 entries from disk
2022/07/24 05:14:40 [INFO] Updating TLS secret for serving-cert (count: 4): map[listener.cattle.io/cn-127.0.0.1:127.0.0.1 listener.cattle.io/cn-172.17.0.2:172.17.0.2 listener.cattle.io/cn-localhost:localhost listener.cattle.io/cn-syspass.example.com:syspass.example.com listener.cattle.io/hash:e7ccf1ee0884f026725549817c91f5797ccfd133a810b5bd9c7446e03fa9383f]
2022/07/24 05:14:40 [INFO] Active TLS secret serving-cert (ver=2125) (count 4): map[listener.cattle.io/cn-127.0.0.1:127.0.0.1 listener.cattle.io/cn-172.17.0.2:172.17.0.2 listener.cattle.io/cn-localhost:localhost listener.cattle.io/cn-syspass.example.com:syspass.example.com listener.cattle.io/hash:e7ccf1ee0884f026725549817c91f5797ccfd133a810b5bd9c7446e03fa9383f]
I0724 05:18:41.035933      22 controller.go:606] quota admission added evaluator for: preferences.management.cattle.io
2022/07/24 05:19:08 [INFO] Creating token for user user-jb9gv
time="2022-07-24 05:19:08" level=info msg="Telemetry Client v0.5.14"
time="2022-07-24 05:19:08" level=info msg="Listening on 0.0.0.0:8114"
time="2022-07-24 05:19:08" level=info msg="Collecting anonymous data from https://localhost:443/v3"
To stop the Rancher container, run the following command:
docker container stop rancher-server
To start the Rancher container, run the following command:
docker container start rancher-server
And, To pause the Rancher container, run the following command:
docker container pause rancher-server
To remove the Rancher container, run the following command:AdvertisementEzoic
docker container remove rancher-server
In this post, we explained how to install Rancher on Ubuntu 22.04. You can now import your Kubernetes clusters or create a new container from the Rancher dashboard and manage all of them from the central location. Feel free to ask me if you have any questions.
