Bare Metal Cloud Portal Quick Start Guide
The phoenixNAP Bare Metal Cloud offers unrestricted hardware-level access to compute and storage resources. With the intuitive UI, the Bare Metal Cloud portal allows for near-instant server deployment without compromises.
This quick start guide takes you through all the BMC Portal sections where you can buy and manage BMC servers and Kubernetes Klusters, create and manage storage, networks, and IPs, view billing reports, and more.
Follow the links throughout the article to learn more about a specific Bare Metal Cloud feature within the Portal.
BMC portal quick start guide.
How to Access BMC Portal
To log in to the Bare Metal Cloud portal, navigate to https://bmc.phoenixnap.com and enter your credentials.
BMC portal login page
Once you log in, you are taken to the Servers page.
Servers
This section serves as the landing page after you log in. If you do not have a server yet, the Deploy New Server button appears.
BMC portal Home page with the deploy button.
Otherwise, the Servers table shows the list of deployed BMC servers and the columns with relevant location, billing, status, and configuration details. The IP address column shows a public IP address of a server if available. Otherwise, a private IP is shown.
Server list page in the BMC portal
1. Use the instant search bar to refine the search if you have many server instances.
2. The Deploy New Server button takes you to the server creation page.
3. The Buy Bandwidth Package button takes you to the bandwidth order page. The button is visible only if you do not have a bandwidth package on the locations where reserved instances are deployed.
4. Use the bulk action button to perform multiple actions on the selected servers.
5. The Manage column contains the Actions menu with various server functions.
Click the column names to sort the servers.
Deploy New Server
To create a new Bare Metal Cloud server, select the Deploy New Server button from the Servers page.
When the form loads, follow the steps below to create a new server.
Note: For more details, visit the How to Deploy a Bare Metal Cloud Server guide.
1. Select a location where to deploy your new BMC server.
BMC Portal select location for the server.
2. Choose a billing model:
  • Hourly. Billed by the hour. Suitable for short-term projects, instant test environments, etc.
  • Reservation. Reserve a server for a longer period and ensure resource availability. Longer reservations bring larger discounts. Auto-renew is turned on by default for one-month reservations.
Note: Read our BMC billing models guide to learn more about the available billing methods.
3. Select a server from the pool of single or dual CPU instances. Use the tabs to refine the list. If a server is not available for the selected data center, click Available Locations to choose an alternative location. Use the toggle to show all immediately available instances.
4. Choose an operating system. Windows Server editions and Netris are charged extra. Click Next.
Note: When you choose a Linux-based OS, the Cloud Init feature is available on the Instance Details page. Refer to our Cloud Init article to learn how to add user-data to the cloud-init configuration.
5. Enter a unique hostname and description. No spaces are allowed.
6. (Optional) The Remote Desktop and other remote access options appear if you previously selected Windows, ESXi, or Proxmox. The admin/root password appears once you click the Deploy New Server button at the end of the process. Copy the credentials and store them safely.
If you chose to deploy Netris Softgate, the section with Softgate configuration appears.
Read our How to Access BMC Windows Server and the Remote Console guides to learn more about accessing your servers.
7. Select a Public SSH Key from the list in the first field if you added one previously. Otherwise, use the + Add a new Public SSH Key button to add a key in the dedicated field. You must add at least one public SSH key to enable access to your server.
BMC portal add public SSH key field.
Read How to Enable SSH on ESXi if you chose VMware ESXi OS for your server.
8. Assign or purchase public IP allocation for the server if you to access it using public networks.
9. Optionally, select a public or private network to which you want to add the server. Skip the network steps if you do not want to add a server to another network.
Select a private or public network when deploying a server.
10. The gateway step appears if you assigned a server to another network. Enter the gateway IP address from one of the specified IP ranges or leave the field blank for the BMC default gateway IP.
11. Review the configuration and select Deploy New Server using any of the two buttons. If you allowed remote access to your server, the pop-up window with credentials appears.
The server creation process takes from one to fifteen minutes, depending on the OS you selected. Follow the status on the Server page.
Note: The default maximum number of server instances in use for new BMC accounts is five. Please contact Sales if you need additional resources.
Server Manage Actions
Once you deploy your server, it appears on the server list.
To view the available actions, locate the row for your server and click Actions in the Manage column.
BMC view server actions options
View Server Details
The View Details link takes you to the Server Details page. Clicking a hostname shows the same page. The Actions button is also available here, so you do not need to navigate back to the server list.
All the information about your server is in the Instance Details and Network & IP Settings tabs.
Instance Details
The server configuration details are on this screen. Note the server ID if you want to use the BMC API.
Server details page with server configuration section.
The billing part shows the pricing for your server without tax. The Additional Details section at the bottom of the page shows the description you entered during server deployment.
Billing section in the instance details page.
This tab contains all networking-related details, such as bandwidth and public IP allocations.
Server details page with networking information
Scroll down to view the Public Networks & IPs section to view the IP addresses assigned to your server. Use one of the listed public IP addresses for remote access.
At the bottom of the page is the Private Networks & IPs section where you can see all relevant details.
Server details page with private and public network information
Clicking a network name takes you to the network details page.
Launch Console
To load the web-based remote console, select the Launch Console option under the Actions menu for the server you want to connect to.
Click the Launch Console button to launch the console in a new window.
Confirmation message when connecting to a BMC server using the Remote Console feature.
Note: Make sure to disable the pop-up blocker for https://bmc.phoenixnap.com to load the web console.
For Linux-based servers, you must create a user with a password to access the server using the remote console. Refer to the BMC Remote Console guide to learn how to use this functionality.
Power Off Server
To cut power to the server, select Power Off under the Actions menu. Save your work before you proceed.
Confirm by clicking the Power Off Server button.
Confirmation message when powering off a BMC server
Note: Please save any unsaved work to prevent data corruption. The billing is active for powered-off servers.
Reboot Server
To close all processes and restart the server, select Reboot under the Actions menu. Save your work before you proceed.
Confirmation meesage when rebooting a server
The status shows “Rebooting Server” until the server boots back up.
Shut Down Server
To perform an OS-level shutdown without cutting the power to the server, select Shut Down under the Actions menu.
Confirm the selection by clicking the Shut Down Server button.
The billing continues to be active when you shut down the server.
Change Billing
To change the billing model for your server, select the Change Billing option under the Actions menu. You can only upgrade to a longer-term reservation.
For 12-month periods and longer, you must agree to the MSA.
BMC change billing model for a server
Click Confirm when you are ready to change the billing model.
Delete Server
To remove a BMC server from your account, select Delete under the Actions menu. As a safety measure, you must enter the hostname before clicking the Delete Server button.
This action cannot be undone, and you will lose all your data and settings. Select if you want to keep the public IP allocation for servers that have them.
Note: Deleting a server only stops billing for hourly-based instances. If you have a reserved instance, billing remains active until the expiration date. If you keep the public IP block, you will be charged even if it is not assigned to an instance.
Solutions
The Solutions tab lets you create and manage Kubernetes clusters. The Rancher integration with Bare Metal Cloud brings all the standard Rancher options to your server.
Navigate to the Solutions section to start working on your Kubernetes environment.
The Create Kubernetes Cluster button on the Solutions page of the BMC Portal.
Click the Create Kubernetes Cluster button to get started. The process is seamless and intuitive. Refer to our guide to learn how to create a Rancher-controlled Kubernetes management cluster.
Read how to set up a Rancher management cluster with a workload cluster if you want to deploy a workload cluster directly from the portal.
To create, view, and manage your Kubernetes clusters, click the Manage Your Clusters link. The dashboard shows all cluster-related information:
BMC portal solutions section.
The Actions menu lets you view cluster details, view nodes, delete a cluster, and launch Rancher UI.
Billing & Usage
The Billing & Usage section lets you view the statistics about the resources you used and how much you will be charged. The donut chart provides the month-to-date breakdown of prices for all services.
There are four tabs in this section:
  • All – Shows the prices on one screen for every purchase on your account: server, bandwidth, OS licenses, and IP charges.
  • Hourly – Shows hourly billed servers and Windows OS licenses.
  • Reserved – Shows only the reserved instances.
  • Other – Shows bandwidth and OS license prices.
BMC portal billing and usage page.
Each tab shows the filtered results on the right side. Click a column name to change the sorting by category, purchase type, hostname, etc.
Use the search bar to narrow down the list. When a server is active, click the hostname to load the server details page.
Note: When quantity shows less than one, the rest of the period will be factored in the following calendar month. This happens on the first and last billing month for reserved instances.
If you see one server name two times on the report, this means the hourly billing was upgraded at one point. Click the info icon next to the expired hourly model to view the details.
The server list shows deleted instances as well. Click the trash can to view the server ID.
Billing and usage report list
Reservations
The Reservation page lets you view and manage your server and bandwidth reservations. The list provides the necessary information such as instance configuration and location details, start and expiration and date, auto-renew status, and unit price.
The server manage column has the Actions link where you can view reservation details, disable or enable auto-renew, and deploy a new server.
BMC reservations servers page actions menu
The bandwidth table lets you view bandwidth details, change bandwidth, and disable or enable auto-renew.
Click a column name to change the sorting in the table.
Server Reservations
To view and manage server reservations, navigate to the Reservations page, and select the Servers tab.
View Server Reservation Details
To view server reservation details:
1. Locate the server reservation you want to view and click Actions under the Manage column.
2. Select View Details to view the available information. The screen shows all the pricing details for your reservation.
BMC Portal reservation details page
Disable Auto Renew
One-month server reservations have the auto-renew option enabled by default. To disable the auto-renew option:
1. Click Actions and select Disable Auto Renew for the server instance you want.
2. Add the cancellation reason and click Disable Auto Renew when ready. The reservation remains active until the expiration date. Then, the reservation switches to the hourly billing model until you delete the server.
Disable auto-renew confirmation box.
Enable Auto Renew
You can enable auto-renew until the reservation’s expiration date.
To enable the auto-renew option:
1. Click Actions and select Enable Auto Renew for the instance you want.
2. Read the information and click the Enable Auto Renew button. This option allows uninterrupted service.
Enable server reservation auto renew confirmation box
Deploy a New Server Using an Existing Reservation
To reuse a reservation and create a BMC server with the same configuration:
1. Navigate to the Reservations screen.
2. Select the Servers tab.
3. Locate the reservation and select Deploy New Server under the Actions menu.
Deploy New Server using an existent reservation
4. Complete the OS, hostname, and network steps to create a new BMC server using an existing reservation.
Bandwidth Reservations
To buy, view, and manage bandwidth reservations, navigate to the Reservations->Bandwidth page.
To benefit from cheaper rates, buy a bandwidth package instead of being charged at a regular rate. The packages you purchase are tied to one account, and bandwidth can be shared across servers in the same data center.
To buy a bandwidth package:
1. Navigate to either the Reservations -> Bandwidth or Servers page.
2. Click the Buy Bandwidth Package button.
Note: The Buy Bandwidth Package button is visible only if you do not have a bandwidth package reservation on locations where you deployed the servers.
You get 15TB free of charge with the first server you deploy at each location. Click Continue to close the message box.
BMC free bandwidth pop-up message.
3. Select a data center location. You can only purchase one package per location. Only the locations where you have a server deployed are available.
BMC Portal location selection for bandwidth package.
4. Choose a preferred billing model. Savings are greater for longer terms. One-month bandwidth reservations have the auto-renew option enabled by default. If you select 12 months or longer, you must agree to the terms and conditions.
Choose a billing model for the bandwidth package
5. Select a bandwidth package ranging from 30 TB to 2000 TB per month. When you get 15TB free for your first server, the price will be deducted from the package you select.
BMC Portal bandwidth package selection
If you need a larger package, click the contact sales link to start a live chat session. Any bandwidth used over the package you purchased is charged at the price for the selected location.
6. Review the package summary, especially the notes in blue.
BMC bandwidth package summary
7. Click Buy Bandwidth Package to confirm the purchase.
The bandwidth packages you purchased are listed in the Bandwidth tab.
The list of bandwidth packages in the portal.
View Bandwidth Reservation Details
To view bandwidth reservation details:
1. Locate the bandwidth reservation you want to view and click Actions under the Manage column.
2. Select View Details to view the available information. The screen shows all the bandwidth pricing details for your reservation.
BMC bandwidth reservation details page.
Change Bandwidth
1. Locate the bandwidth reservation you want to change and click Actions under the Manage column.
2. Select Change Bandwidth to upgrade the package.
BMC portal change bandwidth action link.
3. Select a longer reservation length and/or a larger bandwidth package.
4. Click the Change Bandwidth Package button. The button is available only when you make a change.
Note: Downgrading the bandwidth reservation length or package is not possible.
Disable Bandwidth Auto Renew
1. Click Actions and select Disable Auto Renew for the bandwidth package you want.
2. Add the cancellation reason and click Disable Auto Renew when ready. The reservation remains active until the expiration date. Then, you will be charged per GB at the standard rate for the data center location.
Disable bandwidth auto renew confirmation box.
Enable Bandwidth Auto Renew
You can enable auto-renew until the reservation’s expiration date. To reenable the bandwidth auto-renew option:
1. Click Actions and select Enable Auto Renew for the bandwidth package you want.
2. Read the information and click the Enable Auto Renew button. By enabling auto-renew, you avoid higher costs if you forget to renew the package manually.
Enable bandwidth auto renew confirmation box.
Storage
The Storage page lets you expand your BMC network storage. Use this feature to increase storage capacity on demand.
Navigate to the Storage page to create a network file storage. If storage exists, the Manage Your Network File Storage button also shows.
Bare Metal Cloud Storage page buttons
Create Network File Storage
Click the Create Network File Storage button to start the creation process.
1. Choose the data center location for the network file storage.
Choosing the data center location for the network file storage
The network storage creates a private network. The storage and servers in the network must have a matching location.
Note: If you have reached the maximum number of networks, you cannot create network file storage.
2. Enter a name in the Storage Name field. Open the Add Description dropdown and add an optional description.
Storage info entry UI
The end of the Storage section shows the maximum capacity in TB and GB. You can request a quota to increase by contacting sales or clicking the link.
3. Enter a Volume Name to help identify the storage volume.
4. Add a Path Suffix. The suffix represents a custom part of the volume path and helps identify a volume. The path suffix is optional but recommended. The Add Description dropdown allows adding an optional description for the volume.
Create file storage volume details UI
5. Set the Volume Size in TB. The size cannot exceed the maximum capacity stated in the Storage section. The price per TB-Hour is next to the volume size. For more information, refer to the BMC billing models article.
6. Review the network file storage in the summary box. Click Create Network File Storage when ready to complete the process.
The network storage list loads. The Status column displays the state of the network file storage.
network file storage listing ready
When done, the status changes to READY. If the status is ERROR, repeat the process or contact support for further assistance.
View Network Storage Details
To see the details of network storage:
1. Go to Storage -> Manage Your Network File Storage. The page shows brief details about your storage.
2. Locate the network file storage for which you want to view the details.
3. To view more details, click Actions -> Storage Details.
The storage details page loads with Storage Info and Volumes tabs.
Network file storage details tabs
Storage Info
The Storage Info tab shows the network file storage configuration details. Note the Storage ID in the Storage Configuration section to manage the storage via API.
Storage configuration details UI
The Storage Network section shows the network details of the storage. Click the Private Networks link to access the Private Networks page. Remove or add servers to the storage network to use the NFS.
The Billing section shows the billing model and prices without tax.
Storage network billing UI
Volumes
The Volumes tab shows the volume details. Note the Volume ID to manage the volume via API.
Volumes detail page UI
The Action column contains the link to the mount command for Linux-based servers. For more details on how to mount the volume, visit the Bare Metal Cloud Storage Management page.
Note: To update the volume name, description, capacity, or path suffix, use the Network Storage API PATCH method. For more details, visit the Network Storage API VolumeUpdate documentation page.
Delete Network File Storage
Deleting a network file storage deletes the storage network and all the data on it. Remove all servers residing on the network before deleting the storage.
Warning: Before deleting the NFS, backup all critical data.
To delete a network file storage, do the following:
2. Find the network file storage on the list.
3. Click Actions -> Delete Storage.
4. Enter the storage name to confirm deletion and click Delete Storage.
Delete storage popout
Networking
The Networking section allows you to have control over your BMC public and private networks, as well as public IP allocations. Use this feature to create, manage, and view networks, and buy and manage public IP allocations.
Networks
The Networks section lets you create and manage public and private networks and add servers to them. Use the Private or Public tab to view the list of available networks, and create new and edit existing networks.
BMC portal Networks page
The table shows previously created networks, their network ID, name, location, CIDR, VLAN ID, IPs in use, and the creation date. The table for private networks has the column “Default” to show if a private network is the default network for the location.
Note: The maximum number of both public and private networks for a location is 15.
Create a Network
Click the Create a Network button in the Networks section to create a network. This action takes you to the network creation page with three steps.
1. Choose a network location.
Network location selection step.
Note: When creating a public network, the location selection impacts the number of available public IP blocks in step 3. The configuration summary box on the right side of the screen shows if the location does not have available public IPs.
2. Select the network type. The wizard preselects the network type depending on where you clicked the Create a Network button.
Specify the network name and add an optional description.
Network details step BMC portal.
For private networks, choose if you want to set it as default by selecting Set this network as default for all servers you will deploy in the selected location.
3. Enter a VLAN ID or leave the field blank, and the system will assign it.
VLAN ID field in the BMC portal
4. This step shows different settings depending on the selected network type.
When creating a public network:
Specify public IP settings.
  • Choose Assign my previously purchased public IP allocation to this public network to allow servers to join the public network. Click the field to see and select the available IP blocks. You can choose, paste, or type in up to 10 IP blocks.
Public IP settings step in the BMC portal.
Note: The list shows the public IP blocks based on the location and status. If an IP block is not listed, it is either already assigned or purchased for another location.
  • If you do not have IP blocks available for the selected location and have not purchased any public IP blocks, the Buy a public IP allocation for your network option appears. Click the Public IP Allocations link to purchase an IP block.
Buy a public IP allocation for your network in the BMC portal.
  • Choose Do not assign a public IP allocation if you want to assign a public IP block later.
Do not assign a public IP allocation option in the BMC portal.
When creating a private network:
Specify Private Network Settings in step 3. Enter a network CIDR size between /31 and /22.
For example, 10.0.0.0/24.
Private Network Settings step
Finally, review the network configuration summary on the right side and click Create Network when ready.
Network summary BMC portal.
The confirmation message shows if the process is successful. The network appears on the list.
New network listed in the table.
Click View More to view all IPs in use for the network.
View Network Details
To view details of ­a network:
1. Navigate to the Networking -> Networks page and choose Public or Private.
2. Locate the network for which you want to view the details.
3. Click the network name or select Actions -> View Details.
Network view details link.
The page with network details loads. There are Network Info and Server in the Network tabs.
Network details page in the BMC portal.
Network Info
The Network Info tab for public networks shows the following sections:
  • Network configuration. Displays the network ID, type, and VLAN. Note the ID of your network if you want to use the API to manage the network.
  • Public IP Allocations. View the assigned IP blocks and unassign them. Select the Assign Public IP Allocation button and choose the available IP blocks to assign them to the network.
  • Additional details. This section appears if you entered a description during the network creation.
The Network Info tab for private networks displays:
  • Network configuration. Shows the network ID, type, VLAN, and if the network is set as default. Note the ID of your network if you want to use the API to manage the network.
  • Network CIDR. Shows the set CIDR and IP range.
The Network Info tab for a private network
The Actions button lets you edit or delete a network.
Servers in the Network
This tab lists all the servers assigned to the network in question, along with the basic information. Use the search bar to find a server quickly.
To view a server’s details, click the server’s name. To remove a server, use the Remove link.
To add more servers to a public or private network:
1. Select the Add Server to Network button.
Add server to network button.
2. Select a server from the list and assign a public or private IP address depending on the network type. Manual OS-level configuration on your BMC server is necessary for changes to take effect.
Assign an IP address to the server being added to the network.
When adding a server to a private network, you can assign up to 10 private IPs. If you skip this step, the system assigns the first available IP. Additionally, one server can belong to multiple private networks.
3. Select Add to Network to complete the process.
Edit Network
The BMC portal lets you edit the network name and description.
To do so:
2. Locate the network you want to edit.
3. Select Actions – > Edit.
Edit network details in the BMC portal.
4. Enter a new name and/or description. For private networks, you can set them as default.
Edit private network and set it as default.
5. Click Update. The changes are instant.
Delete Network
Deleting a network is an irreversible process.
Note: The network you want to delete must not have any resources attached. Remove all assigned resources before proceeding.
To delete a network:
2. Locate the network you want to delete.
3. Select Actions -> Delete.
4. Enter the network name to confirm the action and click Delete Network. For public networks, all public IP blocks will be in the unassigned state and stay in the account’s ownership for future use. You will be charged for the unassigned IP allocations until you delete them, except for BYO IPs.
Note: For more info, refer to our detailed guide on how to configure a BMC server after adding it to a network via portal.
The Public IP Allocations section lets you purchase and manage public IP blocks.
By using the Actions button in the Manage column, you can assign, unassign, and delete public IP allocations.
Public IP allocation section in BMC Portal
To buy a public IP allocation via the portal:
1. Navigate to the Networking->Public IP Allocations section.
2. Select Buy a Public IP Allocation.
3. Choose a location for the public IP block. You can only assign IP blocks to the servers in the same data center location.
4. Choose the public IP allocation size to purchase. The prices on the card are for the whole block.
5. Click Buy a Public IP Allocation to purchase the block.
BMC portal buy public IP allocation summary.
The IP address appears on the list as Unassigned.
To learn how to assign, unassign, and delete a public IP block, read the BMC Public IP Management guide.
API Credentials
The API Credentials page holds the credentials for your APIs. The list shows the name, description, Client ID, and scopes for your credentials.
The Actions menu under the Manage column lets you view and delete credentials.
BMC API credentials page actions menu
Create Credentials
To create new API credentials:
1. Navigate to the API Credentials page.
2. Click the Create Credentials button.
3. Add the credential name and optional description.
4. Assign permissions scopes. Check the box next to the permission level you want to grant to the credentials for each API set.
Create API credentials dialogue box.
5. Click Create when ready.
6. The confirmation window shows the Client ID and Client Secret.
API Credentials client ID and client secret.
7. Copy the credentials and click Close. Your new credentials appear in the API credentials table.
You can create multiple API credentials with different scopes and permission levels. For every set of credentials, you get a unique Client ID and Client Secret to authorize API requests.
View Credentials
To view API credentials:
2. Locate the name of the entry and click Actions under the Manage column.
3. Select View Credentials to see the API credentials for the specific entry.
View API credentials link
This screen lets you generate a new secret. Click the Regenerate Secret button to get a new secret. There is no confirmation message, except that your browser may ask you if you want to save your credentials.
Delete Credentials
To delete API credentials:
3. Select Delete to delete your API credentials. This action invalidates authorized access tokens and permissions.
4. Click Delete Credentials when ready. You cannot undo this action.
Delete API credentials confirmation box.
SSH Keys Management
The SSH Keys Management section is a repository for your public SSH keys. You can add, edit, and delete keys using the options on this screen.
The already uploaded public SSH keys are listed in a table with sortable columns. Sort the keys by name, fingerprint, whether they are marked as default and the creation date.
BMC portal SSH Keys Management page
The Actions menu lets you edit and delete your keys.
Add Public SSH Key
To add a new public SSH key:
1. Navigate to the SSH Keys Management screen.
2. Click the Add a Public SSH Key button.
3. Enter the key name.
4. Paste your public SSH key content in the field.
5. Optionally, set the key as default, and the key will be preselected at the Deploy New Server screen.
Add public SSH key box.
6. Click Add. The key appears in the API credentials table.
Add as many keys as you want. To grant access to multiple accounts and applications, upload different public SSH keys.
Note: It is not possible to add the same SSH key twice. If you try adding the same key, an error appears.
Edit Public SSH Key
To edit an SSH key name:
1. Navigate to the SSH Keys Management page.
2. Locate the public SSH key and click Actions under the Manage column.
3. Select Edit from the menu.
4. Change the name and click Update Key. Optionally, set the key as default.
Edit public SSH key box.
It is not possible to edit the public SSH key content. If you need to edit the content, delete the key, and create a new one.
Delete Public SSH Key
To delete a public SSH key:
3. Select Delete from the menu.
4. Select Delete SSH Key to remove the key permanently.
Disable public SSH key confirmation box.
Note: Learn how to expand storage capacity on a network through Network File Storage (NFS) by referring to our guide Bare Metal Cloud Storage Management via Portal and API.
You should now know how to use the Bare Metal Cloud portal. The steps listed in this guide helped you create and manage Bare Metal Cloud Servers and networks, view different reports, and add and manage API Credentials and public SSH keys.
For any questions or concerns about your BMC servers, contact the Support Team.
