APT vs APT-GET: What’s the Difference?
Like many other Ubuntu users, you may have wondered – What is the difference between apt-get and apt? Or perhaps – When to use apt-get and when apt?
To answer these questions, you first need to understand when and why these command-line interfaces were created. Then, you can compare them side-by-side to see why to use one over the other.
In this tutorial, you will learn the difference between apt and apt-get.
Article explaining the differences between apt and apt-get.
What is the apt-get Command?
If you are a Linux user comfortable with the command line, apt-get is probably something you use often. You utilize this tool to install, update, list, and remove packages from your system.
apt-get is a command line program used to interact with the APT (Advanced Package Tool) package management system. However, this is just one of the tools used to communicate with the APT system. Along with apt-get, there are also apt-cacheapt-config, and (the newly added) apt.
Note: To learn more about the apt-get command and its basic usage, refer to the articles How to Use APT-GET in Linux and How To Use Apt-Get Reinstall On Debian And Ubuntu.
APT vs APT-GET: What is the Difference?
There are four main differences between apt and apt-get:
  1. The apt tool merges functionalities of apt-get and apt-cache
  2. Additional output and improved design
  3. Changes in command syntax for existing functionalities
  4. Two new functionalities exclusive to the Linux apt command
1. APT Combines APT-GET and APT-CACHE Functionalities
Prior to Ubuntu 16.04, users regularly interacted with the APT package manager through the use of command line tools: apt-get, apt-cache, and apt-config. Although these tools offer many functionalities, most average users did not utilize all of the commands they provide.
Therefore, Linux wanted to create a simplified tool that only consisted of essential commands. With the release of Ubuntu 16.04 and Debian 8, they introduced a new command-line interface – apt.
The main goal for this novelty was to merge the most commonly used apt-get and apt-cache commands under the same command prefix.
Note: The apt command is more user-friendly compared to the existing APT tools. Also, it was simpler to use as you didn’t have to switch between apt-get and apt-cache.
2. Additional Output and Improved Design
Apart from the apparent differences between commands, apt also introduced changes to the output design.
Along with updating your local repository, the update command now includes an additional line displaying the number of packages that should be upgraded. There is a difference between updating and upgrading packages on your system. Therefore, this novelty serves as a useful reminder to upgrade the required packages.
Update package repository and see how many package are ready for upgrading.
Once the output displays the number of packages that can be upgraded, you can prompt the package manager to see a list of these packages. Run the apt list --upgradable command, and the output shows the specified list.
The output includes improved design for clearer representation with color emphasis.
List upgradable packages with the apt command.
Finally, the apt command added a progress bar displaying the upgrade process. This is a simple yet useful addition that gives the user more information about the given process.
Progress bar showing upgrade progress from apt upgrade.
3. apt vs apt-get Commands
Although apt commands replace commonly used apt-get and apt-cache functions, they are not backward compatible with all of them. You cannot always replace the older package managers with apt.
In the table below, see the apt command for any given function, as well as which command it replaces.
Command Function Existing Command apt Command
Update the package repository apt-get update apt update
Upgrade packages apt-get upgrade apt upgrade
Upgrade packages and remove unnecessary dependencies apt-get dist-upgrade apt full-upgrade
Install a package apt-get install [package_name] apt install [package_name]
Remove a package apt-get remove [package_name] apt-remove [package_name]
Remove a package with configuration apt-get purge [package_name] apt purge [package_name]
Remove unnecessary dependencies apt-get autoremove apt autoremove
Search for a package apt-get search [package_name] apt-get search [package_name]
Show package information apt-cache show [package_name] apt show [package_name]
Show active package sources apt-cache policy apt policy
Show installed and available versions of a package apt-cache policy [package_name] apt policy [package_name]
Note: If you need a one-page reference sheet with commands, you can use our downloadable Linux commands cheat sheet.
4. New apt Commands
Apart for simplifying existing commands, apt has a couple of its own. They were added to fulfill the needed command functions listed below.
Command Function New apt Command
List packages by criteria apt list
Edit sources list apt edit-sources
When to Use apt Instead of apt-get?
Most Linux users suggest using the apt command instead of apt-get whenever you can. Not only is it easier to type and remember, it performs tasks much faster.
Naturally, there are instances where substituting apt-get or apt-cache is not possible. Although you may still need to switch between command-line interfaces, many believe the apt command will eventually take over. For now, there is no official statement when or whether that will happen.
After reading this, you should have a better understanding of the differences between apt and apt-get. Using one or the other is a matter of habit. Therefore, try to get in the practice of using the apt command.
