5 Ways to Fix the ifconfig Command not Found Error on Debian
How to Install ifconfig on Debian
The ifconfig command is a legacy tool used to configure network interfaces in Linux. Even though the utility was deprecated and replaced with the ip command, ifconfig is still used and often comes preinstalled on modern Linux distributions. However, installing ifconfig on Debian can be problematic.
This guide explains how to install ifconfig on Debian and fix the “command not found” error.
How to Fix ifconfig Command Not Found?
The ifconfig command is part of the net-tools package, a Linux network utility deprecated because of a lack of maintenance and IPv6 support.
While certain distributions still have net-tools preinstalled, others, like Debian, don’t. Therefore, when Debian users try to run ifconfig, the output prints an error.
ifconfig Debian terminal output
The error occurs either because the system does not have net-tools or because the ifconfig directory is not added to the standard PATH variable.
The following sections explain how to fix the ifconfig “command not found” issue.
Method 1: Install net-tools
The first step to fixing the “command not found” error is to install net-tools. Do the following:
1. Update Debian repositories.
sudo apt update terminal output
2. Install net-tools with apt.
sudo apt install net-tools
sudo apt install net-tools terminal output
3. Run ifconfig to confirm the installation.
ifconfig
The output above verifies the installation. However, in some cases, Debian won’t execute ifconfig even after the user installs net-tools. The command prints the same error as before the installation:
bash: ifconfig: command not found
This happens because the system installs ifconfig in /sbin/, which is not a part of the standard user PATH variable. By default, regular users cannot invoke ifconfig unless they add the command to PATH. However, workaround methods exist.
Method 2: Run ifconfig with sudo or as root
One way to run ifconfig without adding the command to PATH is to use sudo or switch to root with su. If you only need to execute ifconfig once, use sudo instead of su since the former is a safer option:
sudo ifconfig
sudo ifconfig terminal output
Method 3: Use the Full Path to the Command
Another option is to run the command as a regular user but to type in the full path to ifconfig:
/sbin/ifconfig
/sbin/ifconfig terminal output
The method works but requires users to remember the path, which is not practical if ifconfig is used often.
Method 4: Update the System PATH Variable
Using sudo or the entire path to the command works but is not practical in the long term. When a user needs to run ifconfig multiple times, it’s best to add the /sbin/ directory to the PATH variable permanently.
To update the PATH variable, follow these steps:
1. Access .profile in Vim or another text editor.
vim .profile
2. Go to the end of the file in Vim.
3. Paste the following line:
export PATH=$PATH: /sbin/
export PATH in Vim
3. Save and close the file.
5. Reboot the system to make the changes live.
6. Run ifconfig.
ifconfig
ifconfig Debian added to PATH terminal output
The output shows that the command is working.
Note: To install ifconfig for the current user only, change the $HOME/.profile file. To make changes system-wide, edit /etc/profile.
Method 5: Use an Alternative Command
While effective, ifconfig is a challenge to install and run on Debian. In modern distributions, ip is the go-to utility for network configuration.
The ip tool is installed by default on Debian. Run the command without any options to see the basic functions:
ip
ip terminal output
The ip command prints the list of network interfaces with the link show arguments:
ip link show
ip link show terminal output
After reading this tutorial, you know how to install ifconfig on Debian. Next, learn how to change the hostname in Debian 10.
