How to Use the Linux less Command
The less command in Linux is a powerful tool used primarily for viewing the contents of a text file, one page (or screen) at a time. Unlike the more command, less allows backward movement in the file as well as forward movement. This flexibility makes it a preferred choice for viewing large files.
Basic Usage
To open a file with less, type less followed by the file name:
less filename.txt
This command will open filename.txt in a scrollable text format.
  • Scrolling: Use the arrow keys to move up or down line by line. The space bar scrolls down a page, and b scrolls back a page.
  • Search: Type / followed by a search term and press Enter to search downwards. Use ? to search upwards.
  • Go to Line: Type g to go to the start of the file or G to go to the end. You can also go to a specific line by typing NG, where N is the line number.
  • Exit: Press q to exit less.
Examples
Viewing Large Log Files
less /var/log/syslog
This command is useful for inspecting large log files where you can scroll through the data and search for specific entries.
Checking Configuration Files
less /etc/nginx/nginx.conf
Use less to examine configuration files. It’s safe and doesn’t risk accidental file modification.
Piping Output to less
dmesg | less
This is useful for commands that produce a lot of output. It allows you to view the output one page at a time.
Frequently Asked Questions
Can I edit files with less?
No, less is a viewer, not an editor. To edit files, use an editor like vim or nano.
How do I highlight search results in less?
After performing a search with / or ?less will highlight the matching terms. To cycle through search results, use n for the next match and N for the previous match.Ezoic
Can less handle binary files?
less can open binary files, but it’s not ideal for viewing them. For binary files, consider using a tool like hexdump.
How do I view multiple files with less?
You can open multiple files by listing them: less file1.txt file2.txt. Use :n to go to the next file and :p to go to the previous file.
Is it possible to customize less?Ezoic
Yes, less can be customized using various options and environment variables. For example, setting the LESS environment variable to -R enables interpretation of color escape sequences.
The less command, with its simple yet powerful features, is an indispensable tool for navigating through text data in Linux. Its ability to handle large files efficiently and user-friendly navigation options make it a go-to choice for system administrators and programmers.
