How to Install Fuel CMS with Nginx and Let’s Encrypt SSL on Ubuntu 22.04
Fuel CMS is an open-source content management system used for websites. It is based on the CodeIgniter PHP web framework and is used for advanced web development. It helps users create custom modules and view and use the CMS part as per their requirements. It offers a simple and user-friendly web interface to manage websites from any device.
This article will explain how to install the Fuel CMS system with Nginx and Let’s Encrypt SSL on Ubuntu 22.04.
- A domain name is pointed to your server IP.
Update the System
First, updating your system packages to the latest version is recommended. You can update them with the following command:apt-get update -y
apt-get upgrade -y
Install Nginx, MariaDB, and PHP
Next, you must install the Nginx web server, MariaDB, PHP, and other PHP extensions to your system. You can install all the packages with the following command:apt-get install nginx mariadb-server php php-cli php-fpm php-mysqli php-curl php-gd php-xml php-common unzip -y
Once all the packages are installed, edit the php.ini file and change some default PHP settings:nano /etc/php/8.1/fpm/php.ini
Change the following lines:memory_limit = 256M
upload_max_filesize = 100M
max_execution_time = 360
date.timezone = UTC
Save and close the file then restart the PHP-FPM service to apply the changes:systemctl restart php8.1-fpm
Configure MariaDB Database
Next, you will need to create a database and user for Fuel CMS. First, log into the MariaDB console with the following command:mysql
Once you are connected, create a database and user with the following command:MariaDB [(none)]> CREATE DATABASE fuel;
MariaDB [(none)]> GRANT ALL ON fuel.* TO 'fuel'@'localhost' IDENTIFIED BY 'password';
Next, flush the privileges and exit from the MariaDB with the following command:MariaDB [(none)]> FLUSH PRIVILEGES;
MariaDB [(none)]> EXIT;
At this point, MariaDB is configured for Fuel CMS. You can now proceed to the next step.
Install Fuel CMS
First, create a directory to store Fuel CMS content with the following command:mkdir -p /var/www/html/fuel
Next, navigate to the Fuel CMS directory and download the latest version of Fuel CMS with the following command:cd /var/www/html/fuel
wget https://github.com/daylightstudio/FUEL-CMS/archive/master.zip
Once the download is completed, unzip the downloaded file with the following command:unzip master.zip
Next, move all the content from the extracted directory to your current directory with the following command:mv FUEL-CMS-master/* .
Next, edit the database.php file and define your database settings:nano fuel/application/config/database.php
Change the following lines:$db['default'] = array(
'dsn' => '',
'hostname' => 'localhost',
'username' => 'fuel',
'password' => 'password',
'database' => 'fuel',
'dbdriver' => 'mysqli',
'dbprefix' => '',
'pconnect' => FALSE,
Next, import the Fuel CMS schema to the fuel database with the following command:mysql -u fuel -p fuel < fuel/install/fuel_schema.sql
Next, edit the MY_fuel.php and enable the admin login:nano fuel/application/config/MY_fuel.php
Change the FALSE to TRUE as shown below:$config['admin_enabled’] = TRUE;
Save and close the file then create a session directory and set proper ownership:mkdir -p /var/lib/php/session
chown -R www-data:www-data /var/lib/php/session
chown -R www-data:www-data /var/www/html/fuel
Configure Nginx for Fuel CMS
First, create an Nginx virtual host configuration file to serve Fuel CMS.nano /etc/nginx/conf.d/fuel.conf
Add the following lines:server {
root /var/www/html/fuel;
server_name fuelcms.example.com;
try_files $uri $uri/ /index.php?q=$uri&$args;
location ~ .php$ {
fastcgi_pass unix:/var/run/php/php8.1-fpm.sock;
Save and close the file then verify the Nginx for any syntax error with the following command:nginx -t
You should get the following output:nginx: the configuration file /etc/nginx/nginx.conf syntax is ok
Next, restart the Nginx service to apply the changes:systemctl reload nginx
You can now verify the status of the Nginx with the following command:systemctl status nginx
You should see the following output:? nginx.service - A high performance web server and a reverse proxy server
Active: active (running) since Sun 2022-11-20 11:20:17 UTC; 8min ago
Docs: man:nginx(8)
Process: 77816 ExecReload=/usr/sbin/nginx -g daemon on; master_process on; -s reload (code=exited, status=0/SUCCESS)
Main PID: 76763 (nginx)
Tasks: 2 (limit: 2242)
Memory: 3.0M
CPU: 62ms
??76763 "nginx: master process /usr/sbin/nginx -g daemon on; master_process on;"
??77817 "nginx: worker process" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" "" ""
Nov 20 11:20:17 ubuntu2204 systemd[1]: Starting A high performance web server and a reverse proxy server...
Nov 20 11:20:17 ubuntu2204 systemd[1]: Started A high performance web server and a reverse proxy server.
Nov 20 11:28:14 ubuntu2204 systemd[1]: Reloading A high performance web server and a reverse proxy server...
Nov 20 11:28:14 ubuntu2204 systemd[1]: Reloaded A high performance web server and a reverse proxy server.
At this point, Nginx is configured to host Fuel CMS. You can now proceed to access Fuel CMS.
Access Fuel CMS Web Interface
Now, open your web browser and access the Fuel CMS using the URL http://fuelcms.example.com/fuel. You will be redirected to the Fuel CMS login page:
Provide the default admin username and password as admin and click on the Login button. You should see the password reset screen:
Click on the reset password button. You should see the following screen:
Provide your new password and click on the Save button to save the changes. Now, click on the Dashboard button. You should see the Fuel CMS dashboard on the following page:
Secure Fuel CMS with Let’s Encrypt
Next, you will need to install the Certbot client package to install and manage the Let’s Encrypt SSL.
First, install the Certbot with the following command:apt-get install python3-certbot-nginx -y
Once the installation is finished, run the following command to install the Let’s Encrypt SSL on your website:certbot --nginx -d fuelcms.example.com
You will be asked to provide a valid email address and accept the term of service as shown below:Saving debug log to /var/log/letsencrypt/letsencrypt.log
cancel): [email protected]
(A)gree/(C)ancel: A
(Y)es/(N)o: Y
Obtaining a new certificate
http-01 challenge for fuelcms.example.com
Waiting for verification...
Cleaning up challenges
Deploying Certificate to VirtualHost /etc/nginx/sites-enabled/fuel.conf
Next, choose whether or not to redirect HTTP traffic to HTTPS as shown below:- - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -
Type 2 and hit Enter to finish the installation. You should see the following output:Redirecting all traffic on port 80 to ssl in /etc/nginx/sites-enabled/fuel.conf
Congratulations! You have successfully enabled https://fuelcms.example.com
https://www.ssllabs.com/ssltest/analyze.html?d=fuelcms.example.com
IMPORTANT NOTES:
/etc/letsencrypt/live/fuelcms.example.com/fullchain.pem
/etc/letsencrypt/live/fuelcms.example.com/privkey.pem
Your cert will expire on 2023-02-20. To obtain a new or tweaked
- We were unable to subscribe you the EFF mailing list because your
e-mail address appears to be invalid. You can try again later by
visiting https://act.eff.org.
Now, your website is secured with Let’s Encrypt SSL. You can access it securely using the URL https://fuelcms.example.com
Congratulations! you have successfully installed Fuel CMS with Nginx and Let’s Encrypt SSL on Ubuntu 22.04. You can now try Fuel CMS, explore its features and start hosting your own website or blog. Feel free to ask me if you have any questions.
