How to create an SQS Queue on AWS
Amazon Simple Queue Service (SQS) is a managed message queuing service of AWS which enables us to decouple and scale microservices, distributed systems, and serverless applications. Using SQS, we can send, store, and receive messages between software components at any volume, without losing messages. Standard queues offer maximum throughput, best-effort ordering, and at least-once delivery. FIFO queues are designed to guarantee that messages are processed exactly once, in the exact order that they are sent.
SQS Eliminates administrative overhead, provides Reliably delivery of messages, keeps sensitive data secure, and scales elastically and cost-effectively.
Security, Durability, Availability, Scalability, Reliability, Customization are a few of the benefits of using SQS.
There are 2 types of SQS Queues on AWS.
  1. Standard Queue
  2. FIFO Queue
  1. Standard Queue:
    Supports a nearly unlimited number of transactions per second (TPS) per API actionA message is delivered at least once, but occasionally more than one copy of a message is delivered. Occasionally, messages might be delivered in an order different from which they were sent.
  2. FIFO Queue:
    FIFO queues support up to 3,000 messages per second (TPS), per API actionA message is delivered once and remains available until a consumer processes and deletes itThe order in which messages are sent and received is strictly preserved.
To know more about the SQS Queues, click here.
For SQS we pay only for what we use, there is no minimum fee. To know more about the pricing of AWS SQS click here
In this article, we will see the steps to create a Standard and FIFO Queue, send messages to them, delete messages and delete Queues.
What will we do?
  1. Login to AWS.
  2. Create SQS Queues and Send Message
  3. View and delete Messages from the queues
  4. Delete the Queues
Login to AWS
Login to AWS
Once we login into AWS successfully, we will see the main console with all the services listed.
AWS Management Console
Create SQS Queues
Click on “Services” in the top left and search for “SQS” and click on “Simple Queue Service”.
Create SQS Queue
You will see the Main Page, here click on “Get started Queue”.
On the “Create New Queue” page, give a name to Standard Queue and scroll down the page.
Set Queue name
After giving a name to the Standard Queue, click on “Create Queue” button in the bottom left.
Resource Groups
Once the Standar Queue gets created, select the Queue and click on “Queue Actions” and “Send a Message”.
Send a Message
Type a message that you want to send and click on the “Send Message” button.
Message Body
You will get the following screen where you will be asked to send another message, send another message or click on “Close”.
Test Message Queue
To create a FIFO Queue, select “FIFO Queue” and give a name to it. After giving a name to the FIFO Queue, scroll down the page.
Create FIFO Queue
Here, click on “Quick- Create Queue”.
FIFO Queue resource group
Once the FIFO Queue gets created, select the Queue and click on “Queue Actions” and “Send a Message”.
Send a message to FIFO Queue
Here, type a message that you want to send to the FIFO Queue and give Message Group ID and Message Duplication ID and click on “Send Message”.
Message body content
Here also, you will get the following screen where you will be asked to send another message, send another message or click on “Close”.
Test success
View and Delete Message from the Queue
Select the Queue Name from which you want to read the message sent in the above steps.
I have selected the Standard Queue here, click on “Quick Actions” -> View/Delete Messages.
View Delete Messages
Here, click on “Start Polling for Messages”.
Poll Messages
Now, you can see the message that you sent in the previous step.
To delete the same, select the message and click “Delete 1 Message”.
Remove message from queue
In the confirmation box, click on “Yes, Delete Checked Messages” to delete the selected message/s.
In the same way, you can view/delete messages sent to FIFO Queue. Select the FIFO queue, click on “Quick Actions” -> “View/Delete Messages”.
View Deleted Messages
Here, click on “Start Polling for Messages” to view the messages sent in the previous step.
Message Body details
Once you get a list of message/s, select that particular message to delete it and click on “Delete 1 Message”.
Stop queue now
In the confirmation box, click on “Yes, Delete Checked Message”.
Delete Checked message
Delete Queues
You can delete Queues by selecting them, click on “Quick Actions” and “Delete Queues”.
Delete SQL Queue
On the confirmation page, click on “yes, Delete 2 Queus.”
Continue Deleting queues
In this article, we saw the steps to create standard and FIFO queues, send messages to them, read them and delete the same. We also saw the steps to delete the Queues.
