Apache 403 Forbidden: Reasons and How to Fix It
Apache is a popular open-source app for running web servers, owing to its reliability and stability. Despite its ease of use, it’s not uncommon to encounter a ‘403 Forbidden’ error after setting up a website using Apache.
In this tutorial, we will go over potential causes of the Apache ‘403 Forbidden’ error and different ways you can fix it.
Apache 403 forbidden: reasons and how to fix it
Apache 403 Forbidden: Effects and Possible Causes
The Apache ‘403 Forbidden’ error appears when you try to load a web page with restricted access. Depending on your browser and the website in question, there are different versions of the 403 error message:
  • Forbidden
  • Error 403
  • HTTP Error 403.14 – Forbidden
  • 403 Forbidden
  • HTTP 403
  • Forbidden: You don’t have permission to access the site using this server
  • Error 403 – Forbidden
  • HTTP Error 403 – Forbidden
Example of an Apache 403 forbidden error message.
There are several potential reasons why the Apache 403 error occurs:
  • The first option is a permission error in the webroot directory, where users don’t have access to website files.
  • The second possible reason for a 403 error is missing or incorrect settings in the Apache configuration files.
  • Finally, failing to set up a default directory index also triggers a 403 error message in Apache.
How to Fix ‘403 Forbidden’ in Apache
If you have come across an Apache ‘403 Forbidden’ message, there are several ways to fix it:
Method 1: Setting File Permissions and Ownership
If you suspect the cause of the 403 error to be incorrect file permissions, use:
sudo chmod -R 775 /path/to/webroot/directory
The chmod command sets the execute permission for the webroot directory and read permission for the index.html file.
To change directory ownership, use:
sudo chown -R user:group /path/to/webroot/directory
Where:
  • user is the user account with root privileges on your web server.
  • group is www-data or apache.
Restart the Apache web server for the changes to take effect.
If you are working with Ubuntu, use the following command to restart Apache:
If you are working with Centos, use:
sudo systemctl restart httpd
Note: If you are having difficulties to restart the Apache service, see our articles: How to Restart Apache on CentOS or How Restart Apache on Ubuntu.
Method 2: Setting Apache Directives
It is possible that the proper require directive is not configured and restricts access to resources. To fix it:
1. Access Apache’s main configuration file. For Ubuntu, use:
sudo nano /etc/apache2/apache2.conf
For Centos, use:
sudo nano /etc/httpd/httpd.conf
2. Once you open the configuration file, scroll down to the following section:
Apache main configuration file
3. If the final line in the <Directory /var/www/> section contains Require all denied, change it to Require all granted.
4. Press Ctrl+X and then Y to save changes to the Apache configuration file.
5. Restart the Apache web server for the changes to take effect. For Ubuntu, use:
For Centos, use:
Method 3: Adding a Default Directory Index
When a user visits a URL that requests a directory, the web server looks for a file in the given directory. If the file or any similar files are not found, and directory index listings are disabled, the web server displays the ‘403 Forbidden’ error message.
To fix the issue, add a default directory index.
1. Access Apache’s main configuration file by using:
2. Scroll down to find out the default index file name:
DirectoryIndex index.html index.cgi index.pl index.php index.xhtml
3. Make sure there is a file in the webroot folder with this name and upload it if it’s missing.
After following this tutorial, you should be able to determine the cause of an Apache ‘403 Forbidden’ error and fix any issues you may find.
If you want to find out more about 403 forbidden error, read our article 403 forbidden error – what is it and how to fix it.
