Setting Up Machine Learning Environments on Bare Metal Cloud GPU Instances
Machine learning, deep learning, computer vision, and large datasets require a robust, GPU-based infrastructure with parallel processing. The Bare Metal Cloud (BMC) GPU instances offer dedicated access to hardware designed for demanding GPU computing and AI tasks.
These BMC server types have two Intel MAX 1100 GPU cards. The server’s parallel processing capabilities and computational power are essential for faster model training and intensive machine learning tasks.
This guide shows how to set up a machine learning environment on a BMC GPU instance.
Step 1: Deploy and Access BMC GPU Server
This section shows how to deploy and access the BMC GPU server through simplified steps. For more information about each server deployment step, see our in-depth guide on deploying a Bare Metal Cloud server.
To deploy and access a BMC server:
1. Log into the BMC portal using your credentials.
2. Navigate to the Deploy Servers page.
3. Choose the data center location (Phoenix or Ashburn).
4. The GPU instance types require a reservation. Choose between a monthly or a long-term reservation.
BMC deployment reservation options
The reservation guarantees the resources during the selected period. For more details about reservations and billing, see the in-depth guide for billing with different reservation types.
5. Use the GPU filter to list the MAX GPU servers. Select one of the available server instances.
BMC deployment GPU instances
This guide uses the d3.g2.c1.xlarge instance to demonstrate the installation steps.
6. Provide the hostname for the server.
7. Choose an existing public SSH key from the list. Alternatively, generate an SSH key pair and add the new public key.
8. (Optional) Set up the network and IP settings. If using a public network, refer to our public IP management guide and configure the server after deployment.
9. Review all the information and deploy the server when ready.
10. Once deployed (status POWERED ON), SSH into the server:
ssh ubuntu@[server_IP]
Replace [server_IP] with the actual server address. The address is visible on the server listing page in the IP Address column and the server details page in the Network & IP Settings tab.
11. Enter yes to approve the connection when prompted.
SSH connection GPU server Ubuntu 22.04
The IP address is added to the list of known hosts, and the connection to the server is established.
Note: The BMC API is another way to deploy the server. Use the POST /servers method and provide the server type as either d3.g2.c1.xlarge, d3.g2.c2.xlarge, or d3.g2.c3.xlarge.
For more information, see how to create a server via BMC API.
View GPU Topology and Driver Details
The server has two Intel MAX 1100 GPU cards and a preinstalled GPU driver. To view the card topology, run:
xpu-smi topology -m
xpu-smi topology -m terminal output
This command shows the system’s GPU topology in matrix form, illustrating how the GPU cards are interconnected and how data flows between them.
To view the preconfigured driver details, run:
modinfo i915
modinfo i915 terminal output
This command displays information about the i915 kernel module, which manages the Intel graphics driver. It shows details such as module parameters, dependencies, and license information.
Note: Learn more about why GPUs and deep learning go hand-in-hand.
Step 2: Install Intel oneAPI Base Toolkit
The Intel oneAPI Base Toolkit is a collection of essential tools for optimizing machine learning across different hardware. It serves as a unified API that (with minimal adjustments) works in various architectures.
To install the toolkit, do the following:
1. Update the APT package list:
2. Set up the repository:
wget -O- https://apt.repos.intel.com/intel-gpg-keys/GPG-PUB-KEY-INTEL-SW-PRODUCTS.PUB | gpg --dearmor | sudo tee /usr/share/keyrings/oneapi-archive-keyring.gpg > /dev/null
wget Intel oneAPI GPG key terminal output
The command downloads the repository key and adds it to the system keyring.
3. Add the entry to APT sources:
echo "deb [signed-by=/usr/share/keyrings/oneapi-archive-keyring.gpg] https://apt.repos.intel.com/oneapi all main" | sudo tee /etc/apt/sources.list.d/oneAPI.list
oneAPI Intel repo source added terminal output
The command adds the signed entry and enables using the repository.
4. Update the package list:
The list now includes the newly added source.
5. Install the base toolkit with:
sudo apt install intel-basekit
sudo apt install intel-basekit terminal output
The command installs the latest available toolkit.
6. Set up the oneAPI environment variables by running these shell scripts:
  • Data Parallel C++ (DPC++) Compiler (oneDPL):
source /opt/intel/oneapi/compiler/latest/env/vars.sh
  • Math Kernel Library (oneMKL):
source /opt/intel/oneapi/mkl/latest/env/vars.sh
  • MPI Library:
source /opt/intel/oneapi/mpi/latest/env/vars.sh
  • Collective Communications Library (oneCCL):
source /opt/intel/oneapi/ccl/latest/env/vars.sh
Intel oneAPI vars.sh scripts
These are the minimum requirements for the Intel extension to work with TensorFlow or PyTorch. Add other components as needed, such as the oneDNN library for deep neural networks or oneTBB for parallelizing compute-intensive workloads.
Step 3: Set Up Machine Learning Libraries
PyTorch and TensorFlow are popular machine learning frameworks that support Intel GPUs.
First, install the Python venv module with:
sudo apt install python3.10-venv
This module lets you create isolated virtual environments for Python development.
Next, depending on your requirements, install and set up either TensorFlow or PyTorch. The sections below provide step-by-step installation instructions specifically tailored for Intel AI workloads.
Note: For a standard setup, follow normal PyTorch or TensorFlow installation steps instead.
Option 1: TensorFlow for GPU
To install TensorFlow with the Intel extension for TensorFlow support, follow the steps below:
1. Create a virtual environment for the installation:
python3 -m venv tensorflow_test
This command creates an isolated environment for package installation, as TensorFlow recommends.
2. Run the activation script to activate the virtual environment:
source tensorflow_test/bin/activate
python venv tensorflow_test create and activate terminal output
3. Upgrade PIP to the latest version:
pip install --upgrade pip
4. Install TensorFlow using PIP:
pip install tensorflow==2.15.0
pip install tensorflow venv terminal output
Adjust the version number to make it compatible with the oneAPI base toolkit version.
5. Install the Intel extension for TensorFlow:
pip install --upgrade intel-extension-for-tensorflow[xpu]
pip install intel-extension-for-tensorflow xpu terminal output
The Intel extension is specifically tailored for Intel-based AI workloads.
6. Confirm the setup worked. Run the following command:
python3 -c "import tensorflow as tf; import intel_extension_for_tensorflow as itex; print(tf.__version__); print(itex.__version__); [print(f'[{device}]: {tf.config.experimental.get_device_details(device)}') for device in tf.config.experimental.list_physical_devices('XPU')];"
TensorFlow and Intel extension version and two XPU devices
The script imports TensorFlow and the Intel extension for TensorFlow. It prints the versions of these two libraries and the device details.
If successful, the output shows that the Intel extension for TensorFlow GPU has been loaded and lists the two available XPU devices.
Option 2: PyTorch for GPU
To install and set up PyTorch and the Intel extension for PyTorch, do the following:
1. Create a virtual environment:
python3 -m venv torch_test
The environment enables isolating the installation from the rest of the system.
2. Activate the environment:
source torch_test/bin/activate
python venv torch_test create and activate terminal output
The terminal changes to the torch_test environment.
3. Upgrade PIP with:
4. Install PyTorch inside the environment:
python -m pip install torch==2.1.0.post2 torchvision==0.16.0.post2 torchaudio==2.1.0.post2 intel-extension-for-pytorch==2.1.30+xpu oneccl_bind_pt==2.1.300+xpu --extra-index-url https://pytorch-extension.intel.com/release-whl/stable/xpu/us/
pip install torch torchvision torchaudio and intel extension terminal output
The command installs torch, torchvision, torchaudio, and the Intel extension for PyTorch. Ensure the versions are compatible with the installed oneAPI version.
Note: Installing torchvision and torchaudio is optional. Check project requirements to install only the required packages.
5. Confirm the installation worked with the following:
python3 -c "import torch; import intel_extension_for_pytorch as ipex; print(torch.__version__); print(ipex.__version__); [print(f'[{i}]: {torch.xpu.get_device_properties(i)}') for i in range(torch.xpu.device_count())];"
PyTorch and Intel extension version and two XPU devices
The script imports PyTorch and the Intel extension libraries. It prints their versions and the details for the two XPU devices.
This guide showed how to set up a machine learning environment on a BMC GPU instance. You can now leverage powerful tools like TensorFlow and PyTorch with Intel’s oneAPI Base Toolkit to optimize performance.
Contact us if you need assistance with your Bare Metal Cloud instance.
