Linux pgrep Command Tutorial for Beginners (10 Examples)
You might already know about the grep command in Linux, which searches for a pattern, and then prints the matching text in the output. What if the requirement is to apply this kind of processing to fetch select information about processes currently running in the system?
Well, you’ll be glad to know that there exists a command-line tool – pgrep – that lets you do exactly this. In this tutorial, we will discuss the basics of pgrep using some easy to understand examples. But before we do that, it’s worth mentioning that all examples here have been tested on an Ubuntu 20.04 LTS machine and on Debian 10.
Linux pgrep command
The pgrep command in Linux lets users look up processes based on name and other attributes. Following is its syntax:
pgrep [options] pattern
And here’s how the tool’s man page explains it:
pgrep looks through the currently running processes and lists the process IDs which match the
selection criteria to stdout. All the criteria have to match.
Following are some Q&A-styled examples that should give you a good idea of how the pgrep command works.
Q1. How to find the ID of a process owned by a specific user?
This can be done using the -u command-line option. For example, to find the ID of the ‘gedit’ process owned by user ‘himanshu’, use pgrep in the following way:
pgrep -u himanshu gedit
Here’s the output this command produced in my case:
Q2. How to make pgrep print count of matching processes?
In case you want the tool to just print the count, and not the IDs themselves, use the -c command-line option. For example, to know the count of processes owned by user ‘himanshu,’ run the following command:
pgrep -c -u himanshu
Following is the output this command produced on my system:
83
Q3. How to use a custom delimiter in output?
By default, the process IDs in output are delimited by a newline. However, if you want, you can change the delimiter, something which you can do using the -d command-line option.
For example, I wanted to use a colon (:) as a delimiter, so I executed the pgrep command in the following way:
pgrep -u himanshu -d:
And following is the output the command produced:
1793:1794:1807:1811:1813:1817:1820:1914:1917:1922:1925:1936:1938:1954:1974:1978:1980:1982:1993:1999
:2008:2009:2012:2020:2024:2034:2036:2043:2048:2049:2051:2052:2055:2064:2068:2073:2074:2085:2088:
2093:2094:2095:2098:2101:2104:2117:2125:2161:2162:2168:2173:2182:2201:2213:2233:2245:2266:2279:
2388:2409:2430:2456:2473:2564:2647:3085:3108:3178:3284:3297:3320:3325:3467:3487:3980:4040:4658:
5668:5721:5777:6271:6281:6512:6808
Q4. How to make pgrep search case insensitive?
By default, the pgrep search is case sensitive. However, if you want, you can make it case insensitive. For this, you have to use the -i command line option.
pgrep -i gedit
Q5. How to make pgrep list process names as well?
For this, use the -l command line option.
Here’s an example:
pgrep -u himanshu -l
Here’s an excerpt of the output produced on my system:
1793 systemd
1794 (sd-pam)
1807 gnome-keyring-d
1811 gdm-x-session
1813 Xorg
1817 dbus-daemon
1820 gnome-session-b
1914 ssh-agent
1917 gvfsd
1922 gvfsd-fuse
1925 at-spi-bus-laun
1936 dbus-daemon
1938 at-spi2-registr
1954 gnome-shell
1974 ibus-daemon
1978 ibus-dconf
1980 ibus-x11
1982 ibus-portal
1993 gnome-shell-cal
1999 evolution-sourc
2008 dconf-service
2009 gvfs-udisks2-vo
2012 goa-daemon
2020 gvfs-mtp-volume
2024 gvfs-goa-volume
So you can see that in addition to process IDs, process names were also produced in the output.
Q6. How to make pgrep list full command as well?
In case you want pgrep to display the complete command that was used to launch each process, use the -a command-line option.
pgrep -u himanshu -a
1793 /lib/systemd/systemd --user
1794 (sd-pam)
1807 /usr/bin/gnome-keyring-daemon --daemonize --login
1811 /usr/lib/gdm3/gdm-x-session --run-script env GNOME_SHELL_SESSION_MODE=ubuntu gnome-session --session=ubuntu
1813 /usr/lib/xorg/Xorg vt2 -displayfd 3 -auth /run/user/1000/gdm/Xauthority -background none -noreset -keeptty -verbose 3
1817 /usr/bin/dbus-daemon --session --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only
1820 /usr/lib/gnome-session/gnome-session-binary --session=ubuntu
1914 /usr/bin/ssh-agent /usr/bin/im-launch env GNOME_SHELL_SESSION_MODE=ubuntu gnome-session --session=ubuntu
1917 /usr/lib/gvfs/gvfsd
1922 /usr/lib/gvfs/gvfsd-fuse /run/user/1000/gvfs -f -o big_writes
1925 /usr/lib/at-spi2-core/at-spi-bus-launcher
1936 /usr/bin/dbus-daemon --config-file=/usr/share/defaults/at-spi2/accessibility.conf --nofork --print-address 3
1938 /usr/lib/at-spi2-core/at-spi2-registryd --use-gnome-session
1954 /usr/bin/gnome-shell
1974 ibus-daemon --xim --panel disable
1978 /usr/lib/ibus/ibus-dconf
1980 /usr/lib/ibus/ibus-x11 --kill-daemon
1982 /usr/lib/ibus/ibus-portal
1993 /usr/lib/gnome-shell/gnome-shell-calendar-server
1999 /usr/lib/evolution/evolution-source-registry
2008 /usr/lib/dconf/dconf-service
2009 /usr/lib/gvfs/gvfs-udisks2-volume-monitor
2012 /usr/lib/gnome-online-accounts/goa-daemon
2020 /usr/lib/gvfs/gvfs-mtp-volume-monitor
2024 /usr/lib/gvfs/gvfs-goa-volume-monitor
2034 /usr/lib/gnome-online-accounts/goa-identity-service
2036 /usr/lib/gvfs/gvfs-gphoto2-volume-monitor
2043 /usr/lib/gvfs/gvfs-afc-volume-monitor
Q7. How to make pgrep only display the newest process?
If instead of all processes, you want pgrep to output only the most recent process, then this can be done using the -n command line option.
Here’s an example:
pgrep -u himanshu -n -l
And following is the output this command produced:
7163 thunderbird
I can confirm that Thunderbird was indeed the most recent process that was launched by the user ‘himanshu.’
Q8. How to make pgrep only display the oldest process?
For this, use the -o command-line option.
pgrep -u himanshu -o -l
And here’s the output this command produced:
1793 systemd
So you can see that pgrep is an extremely helpful command. Once you are done practicing the command line option we’ve discussed here, you can head to the tool’s man page to learn more about it.
