Install Automad CMS with Nginx and Let’s Encrypt SSL on Ubuntu 18.04
screenshot 2019 07 03 at 07 1
Automad is an open-source file-based content management system (CMS) and a template engine written in PHP. All content is stored in human-readable text files instead of a database. An Automad site is therefore fully portable, easy to install, and can be version controlled by using Git or Mercurial. It nevertheless offers database features like searching and tagging. The built-in template engine allows even inexperienced developers and designers to create beautiful themes and templates. In this tutorial, we will go through the Automad CMS installation and setup on Ubuntu 18.04 LTS system by using NGINX as a web server.
Requirements for installing and running Automad CMS are as follows:
  • PHP version 5.4 or higher.
  • Web server software like Nginx or Apache.
  • An Ubuntu 18.04 LTS operating system.
Initial steps
Check your Ubuntu version:
lsb_release -ds
# Ubuntu 18.04.2 LTS
Set up the timezone:
sudo dpkg-reconfigure tzdata
Update your operating system packages (software). That is an essential first step because it ensures you have the latest updates and security fixes for your operating system’s default software packages:
Install some essential packages that are necessary for basic administration of Ubuntu operating system:
sudo apt install -y curl wget vim git unzip socat bash-completion apt-transport-https
Install PHP, as well as the required PHP extensions:
sudo apt install -y php7.2 php7.2-cli php7.2-fpm php7.2-common php7.2-mbstring php7.2-xmlrpc php7.2-soap php7.2-gd php7.2-xml php7.2-curl php7.2-zip
php -m
ctype
curl
exif
fileinfo
Check the version:
php --version
# PHP 7.2.19-0ubuntu0.18.04.1 (cli) (built: Jun 4 2019 14:48:12) ( NTS )
# with Zend OPcache v7.2.19-0ubuntu0.18.04.1, Copyright (c) 1999-2018, by Zend Technologies
PHP-FPM service is automatically started and enabled on reboot on Ubuntu 18.04 system, so there is no need to start and enable it manually. We can move on to the next step.
Securing your forum with HTTPS is not necessary, but it is a good practice to secure your site traffic. To obtain a TLS certificate from Let’s Encrypt we will use acme.sh client. Acme.sh is a simple UNIX shell software for obtaining TLS certificates from Let’s Encrypt with zero dependencies.
Download and install acme.sh:
sudo su - root
cd acme.sh
source ~/.bashrc
cd ~
Check acme.sh version:
acme.sh --version
# v2.8.0
# RSA 2048
# ECDSA
If you want fake certificates for testing, you can add --staging flag to the above commands.
acme.sh --list
Create a directory to store your certs. We will use /etc/letsencrypt directory.
# RSA
# ECC/ECDSA
After obtaining certs exit from root user and return to regular sudo user:
exit
Download and install NGINX from the Ubuntu repository:
sudo apt install -y nginx
Check the NGINX version:
sudo nginx -v
# nginx version: nginx/1.14.0 (Ubuntu)
Run sudo vim /etc/nginx/sites-available/automad.conf and populate the file with the following configuration:
listen [::]:443 ssl http2;
listen 443 ssl http2;
listen [::]:80;
# RSA
# ECC
server_name example.com;
root /var/www/automad;
index index.php index.html;
client_max_body_size 100M;
location ~ .php$ {
fastcgi_index index.php;
include fastcgi_params;
Activate the new automad.conf configuration by linking the file to the sites-enabled directory:
sudo ln -s /etc/nginx/sites-available/automad.conf /etc/nginx/sites-enabled/
Check NGINX configuration for syntax errors:
sudo nginx -t
Reload Nginx:
Step 4 – Install Automad CMS
Create a document root directory for Automad:
sudo mkdir -p /var/www/automad
Navigate to the document root:
cd /var/www/automad
Using curl download the latest release of Automad CMS. Don’t forget to bump up the version numbers if there is a newer release:
sudo curl -O -J -L https://automad.org/download
Uncompress the zip archive:
sudo unzip marcantondahmen-automad-6fff2a0456dc.zip
Move all Automad files to the document root and remove downloaded zip archive:
sudo mv marcantondahmen-automad-6fff2a0456dc/* . && sudo mv marcantondahmen-automad-6fff2a0456dc/.* .
sudo rm marcantondahmen-automad-6fff2a0456dc.zip
sudo rmdir marcantondahmen-automad-6fff2a0456dc
Change ownership of the /var/www/automad directory to www-data:
sudo chown -R www-data:www-data /var/www/automad
Step 5 – Finish the Automad installation
As the last step, create a user account to use the browser-based user interface called the Dashboard. Therefore navigate to https://example.com/dashboard and follow the instructions.
Before you can use Automad dashboard, you will need to create an account:
Create website in Automad
Create a user account using the form and download the generated file to your computer. After you will need to move the downloaded file to the “/config” directory within Automad installation directory.
After that you can log in to Automad dashboard:
Automad Log in
In the end, Automad admin interface will be displayed:
Automad admin dashboard
That’s it. Automad installation is finished.
Links
