Install Automad CMS with Nginx and Let’s Encrypt SSL on CentOS 7
Automad is a file-based content management system (CMS) and a template engine written in PHP. All content is stored in human-readable text files instead of a database. An Automad site is therefore fully portable, easy to install, and can be version controlled by using Git or Mercurial. It nevertheless offers database features like searching and tagging. The built-in template engine allows even inexperienced developers and designers to create beautiful themes and templates. In this tutorial, we will go through the Automad CMS installation and setup on CentOS 7 system by using NGINX as a web server.
Requirements for installing and running Automad CMS are as follows:
- PHP version 5.4 or higher.
- Web server software like Nginx or Apache.
- A CentOS 7 operating system.
- A non-root user with
sudo
privileges.
Initial steps
Check your CentOS version:
cat /etc/centos-release
# CentOS Linux release 7.6.1810 (Core)
Set up the timezone:
timedatectl list-timezones
sudo yum update -y
Install some essential packages that are necessary for basic administration of the CentOS operating system:
sudo yum install -y curl wget vim git unzip socat bash-completion epel-release
Setup the Webtatic YUM repo:
Install PHP, as well as the required PHP extensions:
sudo yum install -y php72w php72w-cli php72w-fpm php72w-common php72w-mbstring php72w-xmlrpc php72w-soap php72w-gd php72w-xml php72w-curl php72w-zip
php -m
ctype
curl
exif
fileinfo
Check the PHP version:
php --version
# PHP 7.2.19 (cli) (built: Jan 12 2019 12:47:33) ( NTS )
# Zend Engine v3.0.0, Copyright (c) 1998-2017 Zend Technologies
# with Zend OPcache v7.2.14, Copyright (c) 1999-2018, by Zend Technologies
Securing your forum with HTTPS is not necessary, but it is a good practice to secure your site traffic. To obtain a TLS certificate from Let’s Encrypt we will use acme.sh client. Acme.sh is a simple UNIX shell software for obtaining TLS certificates from Let’s Encrypt with zero dependencies.
Download and install acme.sh:
sudo su - root
cd acme.sh
./acme.sh --install --accountemail [email protected]
source ~/.bashrc
cd ~
Check acme.sh version:
acme.sh --version
# v2.8.2
# RSA 2048
# ECDSA
If you want fake certificates for testing, you can add --staging
flag to the above commands.
- For RSA:
/home/username/example.com
directory. - For ECC/ECDSA:
/home/username/example.com_ecc
directory.
acme.sh --list
Create a directory to store your certs. We will use the /etc/letsencrypt
directory.
# RSA
# ECC/ECDSA
After obtaining certs exit from root user and return to regular sudo user:
exit
Download and install NGINX from the CentOS repository:
sudo yum install -y nginx
Check the NGINX version:
sudo nginx -v
# nginx version: nginx/1.12.2
Start and enable Nginx service:
Run sudo vim /etc/nginx/conf.d/automad.conf
and populate the file with the following configuration:
listen [::]:443 ssl http2;
listen 443 ssl http2;
listen [::]:80;
# RSA
# ECC
server_name example.com;
root /var/www/automad;
index index.php index.html;
client_max_body_size 100M;
location ~ .php$ {
fastcgi_index index.php;
fastcgi_pass 127.0.0.1:9000;
include fastcgi_params;
sudo nginx -t
Reload Nginx:
Step 4 – Install Automad CMS
Create a document root directory for Automad:
sudo mkdir -p /var/www/automad
Navigate to the document root:
cd /var/www/automad
Using curl
download the latest release of Automad CMS. Don’t forget to bump up the version numbers if there is a newer release:
sudo curl -O -J -L https://automad.org/download
Uncompress the zip archive:
sudo unzip automad-master.zip
Move all Automad files to the document root and remove downloaded zip archive:
sudo mv automad-master/* . && sudo mv automad-master/.* .
sudo rm automad-master.zip
sudo rmdir automad-master
Provide the appropriate ownership:
sudo chown -R nginx:nginx /var/www/automad
Run sudo vim /etc/php-fpm.d/www.conf
and set the user and group to nginx
. Initially, they will be set to apache.
Run:
And set user and group to nginx, like below:
user = nginx
group = nginx
And finally, restart PHP-FPM service for these changes to take effect:
Step 5 – Finish the Automad installation
As the last step, create a user account to use the browser-based user interface called the Dashboard. Therefore navigate to https://example.com/dashboard
and follow the instructions.
Before you can use Automad dashboard, you will need to create an account:
Create a user account using the form and download the generated file to your computer. After you will need to move the downloaded file to the “/config” directory within Automad installation directory.
After that you can log in to Automad dashboard:
In the end, Automad admin interface will be displayed:
That’s it. Automad installation is finished.
Links
