A shebang (also known as a hashbang or sha-bang) is the #!
character sequence at the beginning of a script in Unix-like operating systems. The shebang is followed by the interpreter or the command that should be used to execute the script.
When running a script, the OS looks for the shebang line and uses the specified interpreter or command to execute the script.
In this tutorial, you will learn to use the shebang in Bash scripts.
- A system running Linux.
- Access to the terminal (Ctrl + Alt + T)
- A Linux text editor.
What Does Shebang Mean in Bash?
In Bash, the term “shebang” refers to the first line of a Bash script that specifies which interpreter will be used when executing the script. The shebang line allows users to leverage the power of different interpreters or customize the script execution behavior.
Bash scripts usually start with one of the following shebang lines:
#!/bin/bash
or
#!/usr/bin/env bash
When you run the script, the operating system reads the shebang line and runs the specified interpreter to process the script file.
Using Shebang in Bash Scripts
When writing Bash scripts, understanding and using the shebang line can enhance script execution and portability. Including the appropriate shebang at the beginning of a Bash script ensures that the desired shell interprets the script correctly.
Shebang allows the use of different interpreters or programming languages in scripts and facilitates script execution and compatibility across platforms.
The sections below will provide examples of using the shebang line in Bash scripts.
Use Bash Interpreter
Bash is the default command-line interpreter in Linux and macOS operating systems. The following Bash script example uses a shebang line that explicitly instructs the OS to use the Bash interpreter located at /bin/bash to run the script.
Follow the steps:
1. Create the script using a text editor of your choice:
nano [script_name]
2. Paste the following lines:
#!/bin/bash
echo "Hello, world!"
The script lines below the shebang contain Bash commands which are interpreted and executed using the Bash interpreter. In this case, it is the echo command.
3. Make the script executable by using the following syntax:
chmod +x [script_name]
4. Run the script using the following syntax:
./[script_name]
The OS reads the shebang line and uses the specified interpreter (in this case, Bash) to execute the script and print the line using the echo
command.
Use Bash Interpreter Through env
The env
command allows users to display the current environment or run a specified command in a changed environment. The following shebang line uses the env
command to locate the Bash interpreter in the system’s default paths:
#!/usr/bin/env bash
Using the env
command in such a way provides flexibility in case the Bash interpreter is installed in a different location.
Running the script produces the same output because env
finds the Bash interpreter in the $PATH
and executes the script:
Use POSIX Shell Interpreter
The POSIX (Portable Operating System Interface) Shell is the standard Unix shell. The benefit of using the POSIX shell is that it makes scripts portable and more likely to run consistently across different Unix-like systems. This behavior is not typical for other shell types.
The POSIX shell is located at /bin/sh in the system. That location should be specified in the shebang line by using:
#!/bin/sh
This shebang line specifies the POSIX shell interpreter. This ensures compatibility with a broader range of Unix-like systems that may not have Bash installed but have a POSIX-compliant shell.
To test using the POSIX shell interpreter and check if a string matches a regular expression, follow the steps below:
1. Create a new script.
#!/bin/sh
SOME_VAR="foo-bar-3"
if echo "$SOME_VAR" | grep -P 'd$';then
echo "it ends in a digit!"
else
echo "it doesn't end in a digit!"
fi
Note: Read our tutorial and learn to use grep regex.
3. Make the script executable.
4. Run the script:
Note: Keep in mind that the POSIX shell interpreter doesn’t provide some of Bash’s advanced features and enhancements.
Use Python Interpreter
A Python interpreter is responsible for running Python scripts, and it works on the Read-Eval-Print-Loop (REPL) environment. Although unconventional, you can specify the Python interpreter in the shebang line to allow a Python script to execute Bash script commands.
#!/usr/bin/env python
The env
command locates the Python interpreter in the $PATH
, and the OS uses it to execute the script.
1. Create a new script and paste the following lines:
#!/usr/bin/env python3
print('hello world')
2. Save the changes and make the script executable.
3. Run the script:
The Python interpreter interprets and executes the script.
Use Specific Version of Bash
Specify a version of the Bash interpreter in the shebang line to execute a script using that interpreter. Using a specific Bash version ensures compatibility with older systems that don’t support newer Bash versions or if your script requires features available only in a specific Bash version.
#!/bin/bash-5.1
This shebang line specifies version 5.1 of the Bash interpreter to execute the script.
Use Different Shell Interpreter
Bash has several shell alternatives in Unix-like systems. The shebang line allows users to specify a different shell in their script. One such shell is the Korn shell (ksh
), which offers better performance in script execution and has more programming features.
The following example shows how to specify the Korn shell in the shebang line:
#!/bin/ksh
# Korn shell script code here
The shebang line specifies the Korn shell (ksh
) as the interpreter for executing the script.
Use Interpreted Language Other than Bash
An interpreted language is a programming language that is generally interpreted and doesn’t require compilation before it is executed. In such languages, the instructions are not directly executed by the target machine. Instead, another program reads and executes them.
One such programming language is Perl, and you can specify it in the shebang line to use the Perl interpreter for script execution:
#!/usr/bin/env perl
The following example script is a hello world script executed using Perl:
#!/usr/bin/env perl
# Modules used
use strict;
use warnings;
# Print function
print("Hello Worldn");
2. Make the script executable.
3. Run the script:
In this example, the shebang line uses env
to locate perl
, and the OS uses it to execute the script. Replace perl
with other interpreted languages like Ruby, Python, or PHP, depending on your requirements.
Use Shell Script as Configuration File
Shell scripts can serve as configuration files by specifying #!/bin/false
as the interpreter. The interpreter prevents the script from being executed and causes it to exit with a non-zero status.
That way, the script can be used as a configuration file. Instead of executing the script, it can be sourced or included within another script or program. The variables and settings defined in the script can then be accessed and utilized by the calling script or program.
#!/bin/false
# Configuration parameters defined as shell variables
The shebang line #!/bin/false
indicates that the script is not intended for execution as a standalone script. Instead, it serves as a configuration file where variables and settings can be defined. Thus, the script has no output, regardless of what it contains.
The variables defined in the script can be used to store values such as usernames, passwords, file paths, or any other settings specific to the application or script.
Use Shell Wrapper Script
A shell wrapper script is a script that embeds a command or utility and saves a set of parameters passed to that command. The purpose of using a shell wrapper is to simplify invoking a complex command line.
The syntax for using a shell wrapper script is:
#!/bin/bash
exec /path/to/actual/script.sh "$@"
This shebang line is used in a shell wrapper script that executes another script located at /path/to/actual/script.sh while passing any command-line arguments ("$@"
) to it. The line allows you to add functionality or pre-processing before invoking the main script.
The following example shows how to replace egrep
in new GNU/Linux systems with a wrapper script named egrep
#!/bin/bash
exec grep -E "$@"
Running egrep
in such systems actually runs grep -E
and forwards all the arguments.
Use Different Custom Interpreter or Command
Aside from all the interpreters mentioned above, the shebang line allows you to specify a custom interpreter or command you want to use to execute the script.
The syntax for specifying a custom interpreter or command in the shebang line is:
#!/[path/to/custom/interpreter]
# Code executed by the custom interpreter
Remember to place the shebang at the beginning of the script file, with no spaces or extra characters before it. The line informs the operating system how to execute the script when invoked.
How to Override the Interpreter
Linux allows you to override the interpreter set by the shebang line by specifying which shell you want to use when running a script. For example, if a script contains #!/bin/ksh
in the shebang line, but you want to run it using the Bash shell, use the following syntax:
bash [script_name]
bash helloworld.sh
The command runs the specified script using the Bash shell, regardless of which shell interpreter is specified in the shebang line. However, be careful when overriding the shell interpreter, as it may lead to the script malfunctioning or unexpected behavior.
This tutorial showed how to use the shebang line in Bash scripts to specify which shell interpreter or command the system should use to execute the script. The shebang line allows developers to create scripts and control which shell and command execute the script.
For more scripting tutorials, read our articles regarding writing a Bash script or learn to use the for loop in Bash scripts through hands-on examples.
