How to set up OpenLDAP Client on Debian 10
In this tutorial, I will show you how to set up an OpenLDAP client using the Debian 10 Buster. Before using this guide, ensure that you have an OpenLDAP server installed on another node or server that the client can be connected to.
For this tutorial, I will use the Debian 10 with 1GB of RAM and 15GB disk space. Also, you must have the root privileges.
What we will do
- Install and Configure OpenLDAP Client Packages
- Set Up Name Service Switch (nsswitch)
- Set Up Pam Authentication and Session
- Testing
Step 1 – Install and Configure OpenLDAP Client Packages
First, we will install LDAP packages on the client-side. We will install the libnss and libpam packges for ldap client.
During the ldap client packages installation, you will be asked for some configuration, including the the ldap server address, ldap base DN, and the password for ldap admin user.
Install ldap packages for clients using the apt command below.
sudo apt install libnss-ldap libpam-ldap ldap-utils
Install libnss-ldap
Now you will be asked for the LDAP server IP address. Type your LDAP/LDAPS server IP address and choose ‘OK’.
Type the base DN of your LDAP server and choose ‘OK’.
Now specify the LDAP protocol version to ‘3’ and choose ‘OK’.
Type default LDAP root user (default is admin) and choose ‘OK’ again.
Now type the password for default admin user.
For the NSSwitch configuration, choose ‘OK’.
Install libpam-ldap
Next, allow the ldap admin user to hevae like the root user by choosing ‘Yes’.
For the LDAP database login password, I choose ‘No’ in my case.
Now type again the default admin user for LDP server and choose ‘OK’.
Type the admin password and choose ‘OK’ again.
Step 2 – Set Up Name Service Switch (nsswitch)
In this step, we will modify the NSSwitch configuration ‘/etc/nsswitch.conf’ to use the ldap as a datasource.
Edit the configuration ‘/etc/nsswitch.conf’ using vim editor.
vim /etc/nsswitch.conf
Now change detail lines exact as below.
passwd: compat ldap
group: compat ldap
shadow: compat ldap
Save and close.
Now the NSSwitch will loopkup information for user authentication to the ldap server.
Step 3 – Set Up Pam Authentication and Session
In this step we will setup the pam password authentiucation by disabling the ‘use_authok’ module and add optional pam session for automatically create home directory.
The ‘use_authtok’ module will not prompt the user for a new password, and the ‘pam_mkhomedir’ module will automatically create home directory for ldap users.
For the pam authentication password, edit the configuration ‘/etc/pam.d/common-password’ using vim editor.
vim /etc/pam.d/common-password
Remove the option ‘use_authtok’ on the password ‘pam_ldap’ module configuraiton as below.
password [success=1 user_unknown=ignore default=die] pam_ldap.so try_Step 4 - Testingfirst_pass
Save and close.
Next, edit the pam session configiration ‘/etc/pam.d/common-session’.
vim /etc/pam.d/common-session
Add the ‘pam_mkhomedir’ module configuration below.
session optional pam_mkhomedir.so skel=/etc/skel umask=077
Save and close.
As a result, you’ve set up the PAM module for authentication and session configuration.
Now reboot the Debian client.
sudo reboot
Step 4 – Testing
To test the OpenLDAP client installation and configuration, log in to the client system using the user provided by the OpenLDAP server.
Log in using the user ‘olaf’ that available on OpenLDAP server.
Once the ‘olaf’ user logged in, a new user home directory for that user will be automatically created.
As a result, the installation and configuration of OpenLDAP client on Debian 10 has been completed successfully.
