How to Install X-Cart eCommerce platform on Debian 10
X-Cart is an extremely flexible open-source eCommerce platform with tons of features and integrations. X-Cart source code is hosted on Github. This guide describes the process of installing X-Cart 5 on Debian 10 by using Nginx as a web server and MariaDB as a database server.
  • PHP version 7.2 or higher
  • PHP extensions: pdo, phar, mysql, mbstring, curl
  • MySQL version 5.7.7 or higher or MariaDB equivalent
  • Nginx
Initial Steps
Check your Debian version:
lsb_release -ds
Set up the timezone:
sudo dpkg-reconfigure tzdata
Install some essential packages that are necessary for basic administration of Debian operating system:
sudo apt install -y curl wget vim git unzip socat bash-completion
sudo apt install -y php php-cli php-fpm php-common php-mbstring php-curl php-mysql php-json php-xml php-phar php-pdo php-gd
php -m
ctype
curl
exif
fileinfo
Check the PHP version:
php --version
# PHP 7.3.17-0debian0.18.04.1 (cli) (built: Apr 18 2019 14:12:38) ( NTS )
# with Zend OPcache v7.2.17-0debian0.18.04.1, Copyright (c) 1999-2018, by Zend Technologies
PHP-FPM service is automatically started and enabled on reboot on Debian 10 system, so there is no need to start and enable it manually. We can move on to the next step, which is the database installation and setup.
Step 2 – Install MariaDB and create a database
Install MySQL:
sudo apt install -y mariadb-server
Check the version:
mysql --version
# mysql  Ver 14.14 Distrib 5.7.27, for Linux (x86_64) using  EditLine wrapper
Run the mysql_secure_installation script to improve the security of your MariaDB installation:
Log into MariaDB as the root user:
sudo mysql -u root -p
# Enter password:
Create a new MariaDB database and user and remember the credentials:
CREATE DATABASE dbname;
FLUSH PRIVILEGES;
exit;
Step 3 – Install acme.sh client and obtain Let’s Encrypt certificate (optional)
Securing your website with HTTPS is not necessary, but it is a good practice to secure your site traffic. In order to obtain TLS certificate from Let’s Encrypt we will use acme.sh client. Acme.sh is a pure UNIX shell software for obtaining TLS certificates from Let’s Encrypt with zero dependencies.
Download and install acme.sh:
sudo su - root
cd acme.sh
source ~/.bashrc
cd ~
Check acme.sh version:
acme.sh --version
# v2.8.6
# RSA 2048
# ECDSA
If you want fake certificates for testing you can add the --staging flag to the above commands.
acme.sh --list
Create a directory to store your certs. We will use the /etc/letsencrypt directory.
# RSA
# ECC/ECDSA
All the certificates will be automatically renewed every 60 days.
After obtaining certs exit form the root user and return back to normal sudo user:
exit
Step 4 – Install and configure Nginx
Install Nginx:
sudo apt install -y nginx
Check the Nginx version:
sudo nginx -v
# nginx version: nginx/1.14.0
Configure Nginx for X-Cart by running:
sudo vim /etc/nginx/sites-available/xcart.conf
And populate the file with the below config.
listen [::]:80;
root /var/www/xcart;
server_name example.com;
location @handler {
index cart.php;
rewrite ^/sitemap.xml(?.+)?$ /cart.php?target=sitemap;
rewrite ^/(.*)$ /cart.php?url=$1 last;
try_files $uri $uri/ @handler;
location ~ .php$ {
try_files $uri @handler;
fastcgi_index index.php;
fastcgi_pass unix:/var/run/php/php7.3-fpm.sock;
include fastcgi_params;
Activate the new xcart.conf configuration by linking the file to the sites-enabled directory:
sudo ln -s /etc/nginx/sites-available/xcart.conf /etc/nginx/sites-enabled
Test the configuration:
sudo nginx -t
Reload Nginx:
Step 5 – Install X-Cart
Navigate to the /var/www directory:
cd /var/www/
Download the most recent release of X-Cart from https://www.x-cart.com/download.html and unpack it to your document root:
After downloading, change ownership of the /var/www/xcart directory to www-data:
sudo chown -R www-data:www-data /var/www/xcart
Navigate to example.com/install.php in your web browser and follow the instructions to finish the installation.
Step 6 – Finish setup
Accept the license agreement and click Next.
X-Cart Installation Wizard
Create an Administrator Account.
Add admin account
The installation wizard will check whether your server meets the system requirements for X-Cart 5
Check requirements
Configure database settings:
Database login details
Setting up Directories + Step 6. Building Cache. All the tasks at these steps are fully automated, so you just need to wait and let X-Cart 5 do the job
Installation progress
Now the installation process has been completed.  You can use the links provided to access your store’s Customer front end and Admin area.
x-Cart Installation successful
