How to Install WonderCMS with Nginx on Debian 9
WonderCMS is a free and open source flat file CMS, aimed to be extremely small, light and simple. It’s built with PHP, jQuery, HTML/CSS and developed since 2008. No initial configuration required. The installation process is pretty straightforward – unzip and upload 5 files. All files can be easily moved, backed up and restored by copy/pasting all files to another location. Moving them to another host does not require any re-configuration. WonderCMS also doesn’t require a traditional/relational database like MySQL. The flat file technology enables WonderCMS to save all data to a text file (flat file) called database.js which is structured in JSON format. In this tutorial, we will go through the WonderCMS installation and setup on the Debian 9 system by using Nginx as a web server, and optionally you can secure the transport layer by using Acme.sh client and Let’s Encrypt certificate authority to add SSL support.
Requirements for installing and running WonderCMS are:
- PHP version 7.1 or greater with the curl, mbstring and zip extensions.
- Web server (Apache with
mod_rewrite
module enabled, Nginx, IIS).
- An Debian 9 operating system.
- A non-root user with
sudo
privileges.
Initial steps
Check your Debian version:
lsb_release -ds
# Debian GNU/Linux 9.9 (stretch)
Set up the timezone:
sudo dpkg-reconfigure tzdata
Install some essential packages that are necessary for basic administration of the Debian operating system:
sudo apt install -y curl wget vim git unzip socat bash-completion apt-transport-https
Add third-party repo for PHP 7.2 installation:
sudo apt install apt-transport-https lsb-release ca-certificates
wget -O /etc/apt/trusted.gpg.d/php.gpg https://packages.sury.org/php/apt.gpg
echo "deb https://packages.sury.org/php/ $(lsb_release -sc) main" > /etc/apt/sources.list.d/php.list
sudo apt install -y php7.2 php7.2-cli php7.2-fpm php7.2-common php7.2-curl php7.2-zip php7.2-mbstring
php -m
ctype
curl
exif
fileinfo
Check the PHP version:
php --version
# PHP 7.2.17.18.04.1 (cli) (built: Apr 18 2019 14:12:38) ( NTS )
# with Zend OPcache v7.2.10.debian.18.04.1, Copyright (c) 1999-2018, by Zend Technologies
PHP-FPM service is automatically started and enabled on reboot on Debian 9 system, so there is no need to start and enable it manually. We can move on to the next step, which is the SSL setup.
Securing your forum with HTTPS is not necessary, but it is a good practice to secure your site traffic. In order to obtain a TLS certificate from Let’s Encrypt we will use Acme.sh client. Acme.sh is a pure UNIX shell software for obtaining TLS certificates from Let’s Encrypt with zero dependencies.
Download and install acme.sh:
sudo su - root
cd acme.sh
./acme.sh --install --accountemail [email protected]
source ~/.bashrc
cd ~
Check acme.sh version:
acme.sh --version
# v2.8.0
# RSA 2048
# ECDSA
If you want fake certificates for testing you can add --staging
flag to the above commands.
- For RSA:
/home/username/example.com
directory. - For ECC/ECDSA:
/home/username/example.com_ecc
directory.
acme.sh --list
Create a directory to store your certs. We will use /etc/letsencrypt
directory.
# RSA
# ECC/ECDSA
exit
WonderCMS can work fine with many popular web server software. In this tutorial, we selected NGINX.
Install NGINX:
sudo apt install -y nginx
Check the NGINX version:
sudo nginx -v
# nginx version: nginx/1.10.3
Next, configure NGINX for WonderCMS. Run sudo vim /etc/nginx/sites-available/wondercms.conf
and add the following configuration:
listen 443 ssl;
server_name example.com;
root /var/www/wondercms;
index index.php;
if (!-e $request_filename) {
rewrite ^/(.+)$ /index.php?page=$1 last;
location ~ database.js {
return 403;
location ~ .php(/|$) {
Activate the new wondercms.conf
configuration by linking the file to the sites-enabled
directory:
sudo ln -s /etc/nginx/sites-available/wondercms.conf /etc/nginx/sites-enabled/
sudo nginx -t
Reload NGINX service:
Step 4 – Install WonderCMS
Create a document root directory for WonderCMS.
sudo mkdir -p /var/www/wondercms
Change ownership of the /var/www/wondercms
directory to [jour_username]
sudo chown -R [your_username]:[your_username] /var/www/wondercms
cd /var/www/wondercms
Download and unzip WonderCMS source:
wget https://github.com/robiso/wondercms/releases/download/2.7.0/WonderCMS-2.7.0.zip
unzip WonderCMS-2.7.0.zip
rm WonderCMS-2.7.0.zip
Move WonderCMS files to document root directory.
mv wondercms/* . && mv wondercms/.*.
rmdir wondercms
directory to www-data:
sudo chown -R www-data:www-data /var/www/wondercms
Open your site in a web browser and log in with default password admin
and change the default password afterward.
Links
