How to Install WonderCMS with Nginx and Let’s Encrypt SSL on CentOS 7
WonderCMS is a free and open source flat file CMS, aimed to be extremely small, light and simple. It’s built with PHP, jQuery, HTML/CSS and developed since 2008. No initial configuration required. The installation process is pretty straightforward – unzip and upload 5 files. All files can be easily moved, backed up and restored by copy/pasting all files to another location. Moving them to another host does not require any re-configuration. WonderCMS also doesn’t require a traditional/relational database like MySQL. The flat file technology enables WonderCMS to save all data to a text file (flat file) called database.js which is structured in JSON format. In this tutorial, we will go through the WonderCMS installation and setup on CentOS 7 system by using Nginx as a web server, and optionally you can secure the transport layer by using Acme.sh client and Let’s Encrypt certificate authority to add SSL support.
Requirements for installing and running WonderCMS are:
  • PHP version 7.1 or greater with the curl, mbstring and zip extensions.
  • Web server (Apache with mod_rewrite module enabled, Nginx, IIS).
  • CentOS 7 operating system.
Initial steps
Check your CentOS version:
cat /etc/centos-release
# CentOS Linux release 7.6.1810 (Core)
Set up the timezone:
timedatectl list-timezones
sudo yum update -y
Install some essential packages that are necessary for basic administration of the CentOS operating system:
sudo yum install -y curl wget vim git unzip socat bash-completion epel-release
Setup the Webtatic YUM repo:
sudo yum install -y php72w php72w-cli php72w-fpm php72w-common php72w-curl php72w-zip php72w-mbstring php72w-json
php -m
ctype
curl
exif
fileinfo
Check the PHP version:
php --version
Securing your forum with HTTPS is not necessary, but it is a good practice to secure your site traffic. In order to obtain a TLS certificate from Let’s Encrypt we will use acme.sh client. Acme.sh is a pure UNIX shell software for obtaining TLS certificates from Let’s Encrypt with zero dependencies.
Download and install acme.sh:
sudo su - root
cd acme.sh
source ~/.bashrc
cd ~
Check acme.sh version:
acme.sh --version
# v2.8.0
# RSA 2048
# ECDSA
If you want fake certificates for testing you can add --staging flag to the above commands.
acme.sh --list
Create a directory to store your certs. We will use /etc/letsencrypt directory.
# RSA
# ECC/ECDSA
exit
WonderCMS can work fine with many popular web server software. In this tutorial, we selected NGINX.
Install NGINX:
sudo yum install -y nginx
Check the NGINX version:
nginx -v
# nginx version: nginx/1.12.2
Start and enable NGINX service:
Next, configure NGINX for WonderCMS. Run sudo vim /etc/nginx/conf.d/wondercms.conf and add the following configuration:
listen 443 ssl;
server_name example.com;
root /var/www/wondercms;
index index.php;
if (!-e $request_filename) {
rewrite ^/(.+)$ /index.php?page=$1 last;
location ~ database.js {
return 403;
location ~ .php(/|$) {
try_files $uri =404;
fastcgi_pass http://127.0.0.1:9000;
fastcgi_index index.php;
include fastcgi_params;
sudo nginx -t
Reload NGINX service:
Step 4 – Install WonderCMS
Create a document root directory for WonderCMS.
sudo mkdir -p /var/www/wondercms
Change ownership of the /var/www/wondercms directory to [jour_username]. The string [jour_username] must be replaced with the name of the Linux user that you are currently logged in.
sudo chown -R [your_username]:[your_username] /var/www/wondercms
cd /var/www/wondercms
Download and unzip WonderCMS source:
wget https://github.com/robiso/wondercms/releases/download/2.7.0/WonderCMS-2.7.0.zip
unzip WonderCMS-2.7.0.zip
rm WonderCMS-2.7.0.zip
Move WonderCMS files to document root directory.
mv wondercms/* . && mv wondercms/.*.
rmdir wondercms
Change ownership of the /var/www/wondercms directory to nginx:
sudo chown -R nginx:nginx /var/www/wondercms
Run sudo vim /etc/php-fpm.d/www.conf and set user and group to nginx.
user = nginx
group = nginx
Remove the # in front of the user and group line, in case there is a # in front.
Then restart the PHP-FPM service.
Open your site in a web browser and log in with default password admin and change the default password afterward.
WonderCMS with Nginx on CentOS
Links
