How to Install WonderCMS with Nginx and Let’s Encrypt on FreeBSD 12
WonderCMS is a free and open-source flat-file CMS, aimed to be extremely small, light and simple. It’s built with PHP, jQuery, HTML/CSS and developed since 2008. No initial configuration required. The installation process is pretty straightforward – unzip and upload 5 files. All files can be easily moved, backed up and restored by copy/pasting all files to another location. Moving them to another host does not require any re-configuration. WonderCMS also doesn’t require a traditional/relational database like MySQL. The flat file technology enables WonderCMS to save all data to a text file (flat file) called database.js which is structured in JSON format. In this tutorial, we will go through the WonderCMS installation and setup on the FreeBSD 12 system by using Nginx as a web server, and optionally you can secure the transport layer by using Acme.sh client and Let’s Encrypt certificate authority to add SSL support.
Requirements for installing and running WonderCMS are:
  • PHP version 7.1 or greater with the curl, mbstring and zip extensions.
  • Web server (Apache with mod_rewrite module enabled, Nginx, IIS).
  • FreeBSD 12 operating system.
Initial steps
Check your FreeBSD version:
uname -ro
# FreeBSD 12.0-RELEASE
Set up the timezone:
tzsetup
freebsd-update fetch install
pkg update && pkg upgrade -y
Install some essential packages that are necessary for basic administration of FreeBSD 12.0 operating system:
pkg install -y sudo vim unzip wget bash socat
sudo pkg install -y php72 php72-mbstring php72-curl php72-gd php72-pdo php72-mysqli php72-pdo_mysql php72-json php72-openssl php72-ctype php72-dom php72-hash php72-iconv php72-tokenizer php72-calendar php72-fileinfo php72-session php72-simplexml php72-xml php72-filter
php -m
ctype
curl
exif
fileinfo
Check the PHP version:
php --version
# PHP 7.3.6 (cli) (built: May 28 2019 09:32:59) ( NTS )
# Zend Engine v3.3.6, Copyright (c) 1998-2018 Zend Technologies
sudo sysrc php_fpm_enable=yes
sudo service php-fpm start
Securing your forum with HTTPS is not necessary, but it is a good practice to secure your site traffic. In order to obtain a TLS certificate from Let’s Encrypt we will use acme.sh client. Acme.sh is a pure UNIX shell software for obtaining TLS certificates from Let’s Encrypt with zero dependencies.
Download and install acme.sh:
sudo pkg install -y acme.sh
Check acme.sh version:
acme.sh --version
# v2.8.2
# RSA 2048
# ECDSA
If you want fake certificates for testing you can add --staging flag to the above commands.
acme.sh --list
Create a directory to store your certs. We will use /etc/letsencrypt directory.
# RSA
# ECC/ECDSA
exit
WonderCMS can work fine with many popular web server software. In this tutorial, we selected NGINX.
Install NGINX:
sudo pkg install -y nginx
Check the NGINX version:
nginx -v
# nginx version: nginx/1.16.1
Start and enable NGINX service:
sudo sysrc nginx_enable=yes
sudo service nginx start
Next, configure NGINX for WonderCMS. Run sudo vim /usr/local/etc/nginx/wondercms.conf and add the following configuration:
listen 443 ssl;
server_name example.com;
root /usr/local/www/wondercms;
index index.php;
if (!-e $request_filename) {
rewrite ^/(.+)$ /index.php?page=$1 last;
location ~ database.js {
return 403;
location ~ .php(/|$) {
fastcgi_index index.php;
fastcgi_pass 127.0.0.1:9000;
include fastcgi_params;
Run sudo vim /usr/local/etc/nginx/nginx.conf and add the below line to http {} block to include WonderCMS config.
include wondercms.conf;
Check Nginx configuration for syntax errors:
sudo nginx -t
Reload Nginx service:
sudo service nginx reload
Step 4 – Install WonderCMS
Create a document root directory for WonderCMS.
sudo mkdir -p /usr/local/www/wondercms
cd /usr/local/www/wondercms
Download and unzip WonderCMS source:
sudo wget https://github.com/robiso/wondercms/releases/download/2.7.0/WonderCMS-2.7.0.zip
sudo unzip WonderCMS-2.7.0.zip
sudo rm WonderCMS-2.7.0.zip
Move WonderCMS files to document root directory.
sudo mv wondercms/* .
sudo mv wondercms/.* .
sudo rmdir wondercms
Change ownership of the /usr/local/www/wondercms directory to nginx:
sudo chown -R nginx:nginx /usr/local/www/wondercms
Restart PHP-FPM service:
sudo service php-fpm restart
Open your site in a web browser and log in with default password admin and change the default password afterward.
WonderCMS on FreeBSD
Links
