How to Install WonderCMS with Apache and Let’s Encrypt SSL on CentOS 8
WonderCMS is a free, open-source, simple and lightweight content management system for building simple websites and blogs. It is a flat-file CMS and doesn’t require any database. The installation process is very simple and does not require any initial configuration. It offers a rich set of features including, WYSIWYG support, flexible CSS framework, SEO friendly and many more.
In this tutorial, we will show you how to install WonderCMS on CentOS 8 and secure it with Let’s Encrypt SSL.
- A server running CentOS 8.
Install Apache and PHP
First, install the Apache webserver, PHP and other PHP extensions with the following command:
dnf install httpd php php-mysqlnd php-curl php-opcache php-xml php-xmlrpc php-gd php-mbstring php-zip php-json wget unzip git -y
Once the installation has been completed, open the php.ini file and change some settings:
nano /etc/php.ini
Change the value as per your requirement:
memory_limit = 128M
post_max_size = 32M
upload_max_filesize = 16M
max_execution_time = 300
date.timezone = Asia/Kolkata
Save and close the file when you are finished. Then, start the Apache service and restart it to start after system reboot with the following command:
systemctl start httpd
systemctl enable httpd
Download WonderCMS
First, download the latest version of the WonderCMS from the Git repository:
cd /var/www/html
git clone https://github.com/robiso/wondercms.git
Once the download is completed, give proper permissions to the downloaded directory with the following command:
chown -R apache:apache /var/www/html/wondercms
chmod -R 775 /var/www/html/wondercms
Configure Apache for WonderCMS
First, create a new Apache virtual host configuration file for WonderCMS with the following command:
nano /etc/httpd/conf.d/wondercms.conf
ServerName wonder.linuxbuz.com
DirectoryIndex index.php
DocumentRoot /var/www/html/wondercms
Redirect /wondercms/loginURL /loginURL
ErrorLog /var/log/httpd/linuxbuz.com-error.log
CustomLog /var/log/httpd/linuxbuz.com-access.log combined
<Directory /var/www/html/wondercms>
Options FollowSymLinks
Require all granted
Save and close the file. Then, restart the Apache service with the following command:
systemctl restart httpd
You can also check the status of the Apache service with the following command:
systemctl status httpd
? httpd.service - The Apache HTTP Server
Loaded: loaded (/usr/lib/systemd/system/httpd.service; disabled; vendor preset: disabled)
Drop-In: /usr/lib/systemd/system/httpd.service.d
??php-fpm.conf
Active: active (running) since Wed 2020-02-19 08:51:34 EST; 1min 25s ago
Docs: man:httpd.service(8)
Main PID: 4716 (httpd)
Status: "Total requests: 6; Idle/Busy workers 100/0;Requests/sec: 0.0759; Bytes served/sec: 812 B/sec"
Tasks: 278 (limit: 12558)
Memory: 43.1M
CGroup: /system.slice/httpd.service
??4716 /usr/sbin/httpd -DFOREGROUND
??4718 /usr/sbin/httpd -DFOREGROUND
??4719 /usr/sbin/httpd -DFOREGROUND
??4720 /usr/sbin/httpd -DFOREGROUND
??4721 /usr/sbin/httpd -DFOREGROUND
??4935 /usr/sbin/httpd -DFOREGROUND
Feb 19 08:51:34 centos8 systemd[1]: Starting The Apache HTTP Server...
Secure WonderCMS with Let’s Encrypt SSL
Next, install the Certbot Let’s Encrypt client with the following command:
Now, run the following command to obtain and install an SSL certificate for your WonderCMS website.
certbot-auto --apache -d wonder.linuxbuz.com
The above command will first install all the required dependencies on your server. Once installed, you will be asked to provide an email address and accept the term of service as shown below:
Note : If you will get any SSL certificate related error then restart the Apache service and run the above command again.
cancel): [email protected]
(A)gree/(C)ancel: A
(Y)es/(N)o: Y
Obtaining a new certificate
http-01 challenge for wonder.linuxbuz.com
Waiting for verification...
Cleaning up challenges
Deploying Certificate to VirtualHost /etc/nginx/conf.d/wondercms.conf
Next, you will need to choose whether or not to redirect HTTP traffic to HTTPS as shown below:
Type 2 and hit Enter to continue. Once the installation has been finished, you should see the following output:
Redirecting all traffic on port 80 to ssl in /etc/nginx/conf.d/wondercms.conf
Congratulations! You have successfully enabled https://wonder.linuxbuz.com
https://www.ssllabs.com/ssltest/analyze.html?d=wonder.linuxbuz.com
IMPORTANT NOTES:
/etc/letsencrypt/live/wonder.linuxbuz.com/fullchain.pem
/etc/letsencrypt/live/wonder.linuxbuz.com/privkey.pem
Your cert will expire on 2020-03-23. To obtain a new or tweaked
Configure Firewall and SELinux
Next, you will need to create a firewall rule to allow HTTP and HTTPS service from external networks. You can allow it with the following command:
firewall-cmd --reload
Next, you will need to configure SELinux for WonderCMS. You can configure SELinux using the following command:
setsebool httpd_can_network_connect on -P
chcon -R -u system_u -t httpd_sys_rw_content_t -r object_r /var/www/html/wondercms
Finally, restart the Apache service to apply the changes:
Access WonderCMS
Now, open your web browser and type the URL https://wonder.linuxbuz.com. You will be redirected to the WonderCMS home page:
Now, copy the password from the above page and click on the Click to login button. You should see the following page:
Paste the password and click on the Login button. You should see the following page:
Next, click on the Settings => Security. You should see the following page:
Change your login URL, password and click on the CHANGE PASSWORD button.
Congratulations! you have successfully installed and secured WonderCMS on CentOS 8 with Let’s Encrypt SSL. You can now host your own blog and website easily using WonderCMS.
