How to Install WonderCMS on Fedora 30
WonderCMS is a free and open source flat file CMS, aimed to be extremely small, light and simple. It’s built with PHP, jQuery, HTML/CSS and developed since 2008. No initial configuration required. The installation process is pretty straightforward – unzip and upload 5 files. All files can be easily moved, backed up and restored by copy/pasting all files to another location. Moving them to another host does not require any re-configuration. WonderCMS also doesn’t require a traditional/relational database like MySQL. The flat file technology enables WonderCMS to save all data to a text file (flat file) called database.js which is structured in JSON format. In this tutorial, we will go through the WonderCMS installation and setup on Fedora 30 system by using Nginx as a web server, and optionally you can secure the transport layer by using Acme.sh client and Let’s Encrypt certificate authority to add SSL support.
Requirements for installing and running WonderCMS are:
  • PHP version 7.1 or greater with the curl, mbstring and zip extensions.
  • Web server (Apache with mod_rewrite module enabled, Nginx, IIS).
  • Fedora 30 operating system.
Initial steps
Check your Fedora version:
cat /etc/fedora-release
# Fedora release 30 (Thirty)
Set up the timezone:
timedatectl list-timezones
sudo dnf update -y
Install some essential packages that are necessary for basic administration of the Fedora operating system:
sudo dnf install -y curl wget vim git unzip socat bash-completion
sudo dnf install -y php-cli php-fpm php-common php-curl php-zip php-mbstring php-json
php -m
ctype
curl
exif
fileinfo
Check the PHP version:
php --version
# PHP 7.3.6 (cli) (built: May 28 2019 09:32:59) ( NTS )
# Zend Engine v3.3.6, Copyright (c) 1998-2018 Zend Technologies
Securing your forum with HTTPS is not necessary, but it is a good practice to secure your site traffic. In order to obtain a TLS certificate from Let’s Encrypt we will use acme.sh client. Acme.sh is a pure UNIX shell software for obtaining TLS certificates from Let’s Encrypt with zero dependencies.
Download and install acme.sh:
sudo su - root
cd acme.sh
source ~/.bashrc
cd ~
Check acme.sh version:
acme.sh --version
# v2.8.2
# RSA 2048
# ECDSA
If you want fake certificates for testing you can add --staging flag to the above commands.
acme.sh --list
Create a directory to store your certs. We will use /etc/letsencrypt directory.
# RSA
# ECC/ECDSA
exit
WonderCMS can work fine with many popular web server software. In this tutorial, we selected NGINX.
Install NGINX:
sudo dnf install -y nginx
Check the NGINX version:
nginx -v
# nginx version: nginx/1.16.0
Start and enable NGINX service:
Next, configure NGINX for WonderCMS. Run sudo vim /etc/nginx/conf.d/wondercms.conf and add the following configuration:
listen 443 ssl;
server_name example.com;
root /var/www/wondercms;
index index.php;
if (!-e $request_filename) {
rewrite ^/(.+)$ /index.php?page=$1 last;
location ~ database.js {
return 403;
location ~ .php(/|$) {
include default.d/php.conf;
sudo nginx -t
Reload NGINX service:
Step 4 – Install WonderCMS
Create a document root directory for WonderCMS.
sudo mkdir -p /var/www/wondercms
Change ownership of the /var/www/wondercms directory to [your_username]:
sudo chown -R [your_username]:[your_username] /var/www/wondercms
Replace [your_username] with the username that you are logged into the server.
cd /var/www/wondercms
Download and unzip WonderCMS source:
wget https://github.com/robiso/wondercms/releases/download/2.7.0/WonderCMS-2.7.0.zip
unzip WonderCMS-2.7.0.zip
rm WonderCMS-2.7.0.zip
Move WonderCMS files to document root directory.
mv wondercms/* .
mv wondercms/.* .
rmdir wondercms
Change ownership of the /var/www/wondercms directory to nginx:
sudo chown -R nginx:nginx /var/www/wondercms
Run sudo vim /etc/php-fpm.d/www.conf and set user and group to nginx. Initially, it’s set to user and group apache:
# user = nginx
# group = nginx
Create /var/lib/php/session/ directory and change ownership to nginx:
sudo mkdir -p /var/lib/php/session/ && sudo chown -R nginx:nginx /var/lib/php/session/
Restart the PHP-FPM service.
Open your site in a web browser and log in with default password admin and change the default password afterward.
WonderCMS with Nginx on Fedora
Links
