How to Install Tiki Wiki with Apache and Let’s encrypt SSL on Debian 10
TikiWiki is a free and open-source content management system written in PHP language. It is is very powerful, full-featured and can be used to create websites, wikis, Web applications, knowledge-base, portals, image galleries and many more. TikiWiki made up from four major components content creation and management tools, communication tools, and configuration and administration tools, and content organization tools and navigation aids. These will allows you to create and manage content, and configure sites. TikiWiki comes with a rich set of features, including, Forums, Blog, Maps, Workspace, Slideshow, Shopping Cart, Bug and issue tracker, Multilingual, File and image gallery, Events and many more.
In this tutorial, we will learn how to install TikiWiki CMS on Debian 10.
- A server running Debian 10.
- A root password is set up to your server.
apt-get upgrade -y
Install LAMP Server
TikiWiki runs on Apache / Nginx web server, written in PHP language and use MariaDB/MySQL to store its data. So you will need to install Apache, MariaDB, PHP and other required extensions on your server. First, install Apache and MariaDB server with the following command:
apt-get install apache2 mariadb-server unzip -y
By default, Debian 10 ships with PHP version 7.3. But, TikiWiki does not support PHP 7.3. So, you will need to install PHP 7.2 and other required extensions.
To add SURY repository, first download and GPG key with the following command:
wget https://packages.sury.org/php/apt.gpg
apt-key add apt.gpg
Next, add the SURY repository to APT with the following command:
echo "deb https://packages.sury.org/php/ $(lsb_release -sc) main" | tee /etc/apt/sources.list.d/php.list
Next, update the repository and install PHP7.2 along with all required extensions with the following commands:
apt-get install php7.2 libapache2-mod-php7.2 php7.2-common php7.2-sqlite3 php7.2-curl php7.2-intl php7.2-mbstring php7.2-xmlrpc php7.2-mysql php7.2-gd php7.2-xml php7.2-cli php7.2-zip -y
After installing PHP7.2, open php.ini file and tweak some settings:
nano /etc/php/7.2/apache2/php.ini
memory_limit = 256M
upload_max_filesize = 100M
max_execution_time = 360
date.timezone = Asia/Kolkata
Save and close the file when you are finished. Then, proceed to the next step.
Create Database for TikiWiki
By default, MariaDB is not secured. So, you will need to secure it first. You can secure it with the following script:
mysql_secure_installation
You should answer all the questions as shown below:
Set root password? [Y/n]: N
Once MariaDB is secured, login to MariaDB shell:
mysql -u root -p
Provide your root password when prompt then create a database and user for TikiWiki with the following command:
MariaDB [(none)]> CREATE DATABASE tikidb;
MariaDB [(none)]> CREATE USER 'tiki'@'localhost' IDENTIFIED BY 'password';
Next, grant all the privileges to TikiWiki Database with the following command:
MariaDB [(none)]> GRANT ALL ON tikidb.* TO 'tiki'@'localhost' IDENTIFIED BY 'password' WITH GRANT OPTION;
MariaDB [(none)]> EXIT;
Download TikiWiki
First, you will need to download the latest version of TikiWiki from the Sourceforge website. You can download it with the following command:
cd /var/www/html/
wget https://sourceforge.net/projects/tikiwiki/files/latest/download -O tikiwiki.zip
unzip tikiwiki.zip
Next, rename the extracted directory to tikiwiki with the following command:
mv tiki-20.0 tikiwiki
Next, give proper permissions to the tikiwiki directory with the following command:
chown -R www-data:www-data /var/www/html/tikiwiki/
chmod -R 755 /var/www/html/tikiwiki/
Configure Apache for TikiWiki
Next, you will need to create an Apache virtual host configuration file for TikiWiki. You can create it with the following command:
nano /etc/apache2/sites-available/tikiwiki.conf
Add the following content:
ServerAdmin [email protected]
DocumentRoot /var/www/html/tikiwiki
ServerName example.com
<Directory /var/www/html/tikiwiki/>
Options FollowSymlinks
Require all granted
ErrorLog ${APACHE_LOG_DIR}/tikiwiki_error.log
CustomLog ${APACHE_LOG_DIR}/tikiwiki_access.log combined
Save and close the file. Then, enable the virtual host configuration file with the following command:
a2ensite tikiwiki.conf
Finally, enable Apache rewrite module and restart Apache service to reload the configuration changes with the following command:
a2enmod rewrite
systemctl restart apache2
Access TikiWiki Web Interface
Now, open your web browser and type the URL http://example.com. You will be redirected to the TikiWiki welcome page:
Select your language and click on the Continue button. You should see the following page:
Accept the License agreement and click on the Continue button. You should see the following page:
Confirm your system meet the minimum requirements and click on the Continue button. You should see the following page:
Provide your database name, database username and password. Then, click on the Continue button. You should see the following page:
Select the database engine and click on the Install button to start the installation. Once the installation has been completed successfully, you should see the following page:
Now, click on the Continue button, you should see the following page:
Provide all the required information like Wiki title, Sender email, Secure login, Admin email and click on the Continue button. You should see the following page:
Read all the information and click on the Continue button. You should see the following page:
Now, click on the “Enter Tiki and Lock Installer” button. You should see the following page:
Now, set your admin password and click on the Apply button. You should see the following page:
Secure TikiWiki with Let’s Encrypt
In this section, we will explain how to secure your TikiWiki site with Let’s Encrypt free SSL.
First, you will need to install Certbot tool to download and install Let’s Encrypt free SSL for your website. By default, the latest version of Certbot is not available in the Debian 10 default repository. So, you will need to add Certbot repository to your system.
You can add the Certbot repository with the following command:
apt-get install software-properties-common
add-apt-repository ppa:certbot/certbot
Next, update the repository and install Certbot with the following command:
apt-get install certbot python-certbot-apache -y
Once installed, create a well-known.conf file for Let’s Encrypt to validate your domain.
First, create a .well-known directory and give proper permissions:
mkdir -p /var/lib/letsencrypt/.well-known
chgrp www-data /var/lib/letsencrypt
chmod g+s /var/lib/letsencrypt
Next, create a well-known.conf file with the following command:
nano /etc/apache2/conf-available/well-known.conf
Alias /.well-known/acme-challenge/ "/var/lib/letsencrypt/.well-known/acme-challenge/"
<Directory "/var/lib/letsencrypt/">
AllowOverride None
Options MultiViews Indexes SymLinksIfOwnerMatch IncludesNoExec
Require method GET POST OPTIONS
Save and close the file. Then, enable the required modules with the following command:
a2enmod ssl
a2enmod http2
a2enmod headers
a2enconf well-known
Next, restart Apache service to apply all the configuration changes:
Now, let’s start to install the free SSL certificate for your domain example.com with the following command:
certbot --apache -d example.com
First, you will need to provide a valid email address and agree to the terms of service as shown below:
cancel): [email protected]
(A)gree/(C)ancel: A
(Y)es/(N)o: Y
Obtaining a new certificate
http-01 challenge for example.com
Enabled Apache rewrite module
Waiting for verification...
Cleaning up challenges
Created an SSL vhost at /etc/apache2/sites-available/example.com-le-ssl.conf
Deploying Certificate to VirtualHost /etc/apache2/sites-available/example.com-le-ssl.conf
Enabling available site: /etc/apache2/sites-available/example.com-le-ssl.conf
Next, choose option 2 to download and install free SSL certificate for your domain. Once the installation has been completed successfully. You should get the following output:
Redirecting vhost in /etc/apache2/sites-enabled/example.com.conf to ssl vhost in /etc/apache2/sites-available/
Congratulations! You have successfully enabled https://example.com
https://www.ssllabs.com/ssltest/analyze.html?d=example.com
IMPORTANT NOTES:
/etc/letsencrypt/live/example.com/fullchain.pem
/etc/letsencrypt/live/example.com/privkey.pem
Your cert will expire on 2019-10-22. To obtain a new or tweaked
That’s it. Now, open your web browser and access your TikiWiki CMS using the URL https://example.com. You should that your TikiWiki site is properly secured with free SSL certificate.
