How to Install Shopware with NGINX and Let’s Encrypt on FreeBSD 12
shopware installer start
Shopware is the next generation of open source e-commerce software. Based on bleeding edge technologies like Symfony 3, Doctrine2 and Zend Framework Shopware comes as the perfect platform for your next e-commerce project. This tutorial will walk you through the Shopware Community Edition (CE) installation on FreeBSD 12 system by using NGINX as a web server.
Make sure your system meets the following minimum requirements:
  • Linux-based operating system with NGINX or Apache 2.x (with mod_rewrite) web server installed.
  • PHP 5.6.4 or higher with ctype, gd, curl, dom, hash, iconv, zip, json, mbstring, openssl, session, simplexml, xml, zlib, fileinfo, and pdo/mysql extensions. PHP 7.1 or above is strongly recommended.
  • MySQL 5.5.0 or higher.
  • Possibility to set up cron jobs.
  • Minimum 4 GB available hard disk space.
  • IonCube Loader version 5.0.0 or higher (optional).
NOTE: Shopware 5 is currently up to PHP 7.2.x compatible.
  • An operating system running FreeBSD 12.
I will be using the domain name example.com in this tutorial. Please replace the word example.com with your own domain name wherever it occurs in the commands and config files below (especially in the Nginx config file and the Let’s encrypt commands).
Initial steps
Check your FreeBSD version:
uname -ro
# FreeBSD 12.0-RELEASE
Set up the timezone:
tzsetup
freebsd-update fetch install
pkg update && pkg upgrade -y
Install some essential packages that are necessary for basic administration of FreeBSD 12.0 operating system:
pkg install -y sudo vim unzip wget bash socat
Install PHP, as well as the necessary PHP extensions for Shopware:
sudo pkg install -y php72 php72-ctype php72-curl php72-dom php72-hash php72-iconv php72-gd php72-json php72-mbstring php72-openssl php72-session php72-simplexml php72-xml php72-zip php72-zlib php72-pdo php72-pdo_mysql php72-filter php72-ftp php72-tokenizer php72-calendar php72-pecl-APCu php72-opcache
php -m
ctype
curl
exif
fileinfo
Check the PHP version:
php --version
# PHP 7.2.16 (cli) (built: Apr 30 2019 08:37:17) ( NTS )
# Zend Engine v3.3.5, Copyright (c) 1998-2018 Zend Technologies
# with Zend OPcache v7.3.5, Copyright (c) 1999-2018, by Zend Technologies
sudo sysrc php_fpm_enable=yes
sudo service php-fpm start
We can move on to the next step, which is the IonCube Loader installation.
Step 2 – Install IonCube Loader (optional)
This step is optional because Shopware works without IonCube now, but there might be still extensions or themes that use IonCube, so it does not hurt to install it. Download IonCube Loader:
cd /tmp && wget https://downloads.ioncube.com/loader_downloads/ioncube_loaders_fre_11_x86-64.tar.gz
Extract the loader:
tar xfz ioncube_loaders_fre_*.tar.gz
Find the PHP extensions directory on the system by running the command below:
php -i | grep extension_dir
# extension_dir => /usr/local/lib/php/20170718 => /usr/local/lib/php/20170718
Copy the ionCube Loader into the PHP extensions directory:
sudo cp /tmp/ioncube/ioncube_loader_fre_7.2.so /usr/local/lib/php/20170718
Include the loader via PHP configuration:
sudo vim /usr/local/etc/php.ini
Then add a line in the file to include ionCube loader. It can be anywhere in the file below [PHP] line:
zend_extension = /usr/local/lib/php/20170718/ioncube_loader_fre_7.2.so
Save the file and restart PHP-FPM:
sudo service php-fpm restart
Step 3 – Install MariaDB and create a database for Shopware
Install MariaDB database server:
sudo pkg install -y mariadb102-client mariadb102-server
Check the MariaDB version:
mysql --version
# mysql  Ver 15.1 Distrib 10.2.23-MariaDB, for Linux (x86_64) using readline 5.1
Start and enable MariaDB service:
sudo sysrc mysql_enable="yes"
sudo service mysql-server start
Run mysql_secure installation script to improve MariaDB security and set the password for MariaDB root user:
Answer each of the questions:
Would you like to setup VALIDATE PASSWORD plugin? N
Re-enter new password: your_secure_password
Connect to MariaDB shell as the root user:
sudo mysql -u root -p
# Enter password
Create an empty MariaDB database and user for Shopware and remember the credentials:
mysql> CREATE DATABASE dbname;
mysql> GRANT ALL ON dbname.* TO 'username' IDENTIFIED BY 'password';
mysql> FLUSH PRIVILEGES;
Exit from MariaDB:
mysql> exit
Step 4 – Install Acme.sh client and obtain Let’s Encrypt certificate (optional)
Securing your website with HTTPS is not necessary, but it is a good practice to secure your site traffic. In order to obtain a TLS certificate from Let’s Encrypt we will use acme.sh client. Acme.sh is a pure Unix shell software for obtaining TLS certificates from Let’s Encrypt with zero dependencies.
Download and install acme.sh:
sudo pkg install -y acme.sh
Check acme.sh version:
acme.sh --version
# v2.8.2
# RSA 2048
# ECDSA
If you want fake certificates for testing you can add --staging flag to the above commands.
acme.sh --list
Create a directory to store your certs. We will use a directory /etc/letsencrypt.
# RSA
# ECC/ECDSA
acme.sh --install-cert -d example.com --ecc --cert-file /etc/letsencrypt/example.com_ecc/cert.pem --key-file /etc/letsencrypt/example.com_ecc/private.key --fullchain-file /etc/letsencrypt/example.com_ecc/fullchain.pem --reloadcmd "sudo service nginx reload"
All the certificates will be automatically renewed every 60 days.
exit
Step 5 – Install and configure NGINX
Install the NGINX web server:
sudo pkg install -y nginx
Check the NGINX version:
nginx -v
# nginx version: nginx/1.14.2
Start and enable NGINX service:
sudo sysrc nginx_enable=yes
sudo service nginx start
Configure Nginx for Shopware by running:
sudo vim /usr/local/etc/nginx/shopware.conf
listen [::]:80;
server_name example.com;
root /usr/local/www/shopware;
index shopware.php index.php;
try_files $uri $uri/ /shopware.php$is_args$args;
location /recovery/install {
index index.php;
try_files $uri /recovery/install/index.php$is_args$args;
location ~ .php$ {
include fastcgi.conf;
fastcgi_pass 127.0.0.1:9000;
Run sudo vim /usr/local/etc/nginx/nginx.conf and add the below line to http {} block to include Shopware config.
include shopware.conf;
Check Nginx configuration for syntax errors:
sudo nginx -t
Reload Nginx service:
Step 6 – Install Shopware
Create a document root directory for Shopware:
sudo mkdir -p /usr/local/www/shopware
cd /usr/local/www/shopware
Download and unzip Shopware:
sudo wget https://releases.shopware.com/install_5.5.8_d5bf50630eeaacc6679683e0ab0dcba89498be6d.zip?_ga=2.141661361.269357371.1556739808-1418008019.1556603459 -O shopware.zip
sudo unzip shopware.zip
sudo rm shopware.zip
NOTE: Update download URL if there is a newer release.
Provide the appropriate ownership:
sudo chown -R www:www /usr/local/www/shopware
Increase memory_limit = 256M and upload_max_filesize = 6M, and set allow_url_fopen = On if it is not already set in the /usr/local/etc/php.ini file:
After making changes in the /etc/php/7.2/fpm/php.ini file, reload php-fpm.service:
sudo service php-fpm reload
Open your domain/IP in the web browser and follow the installation wizard. The backend of Shopware is located at /backend example: http://example.com/backend.
Step 7 – Complete the Shopware setup
Start by selecting the language and click Next:
Shopware Installation Wizard
Next, make sure you meet all the Shopware requirements:
Shopware System Requirements
Agree with Shopware TOS and click Next:
Terms of service from ShopWare
Enter database credentials and click Next:
Configure the database
Start the installation to create database tables:
Create database tables
After that, you will see a message about successful database import:
Installation successful
Choose a license and click Next:
Licensing
Fill in a few basic settings to finish up the setup and click Next:
Basic shop setup
Installation is complete.
Installation complete
To access admin area append /backend to your URL.
Shopware login
You have successfully installed Shopware. Enjoy your new online shop!
