How to Install Shopware with NGINX and Let’s encrypt on Debian 9
Shopware is a widely used professional open source e-commerce software. Based on bleeding edge technologies like Symfony 3, Doctrine2 and Zend Framework Shopware comes as the perfect platform for your next e-commerce project. This tutorial will show you how to install Shopware Community Edition (CE) on a Debian 9 system by using NGINX as a web server and how to secure the website with a free Let’s encrypt SSL certificate.
Make sure your system meets the following minimum requirements:
  • Linux-based operating system with NGINX or Apache 2.x (with mod_rewrite) web server installed.
  • PHP 5.6.4 or higher with ctype, gd, curl, dom, hash, iconv, zip, json, mbstring, openssl, session, simplexml, xml, zlib, fileinfo, and pdo/mysql extensions. PHP 7.1 or above is strongly recommended.
  • MySQL 5.5.0 or higher.
  • Possibility to set up cron jobs.
  • Minimum 4 GB available hard disk space.
  • IonCube Loader version 5.0.0 or higher (optional).
NOTE: Shopware is currently up to PHP 7.2.x compatible.
  • An operating system running Debian 9.
Initial steps
Check your Debian version:
lsb_release -ds
# Debian GNU/Linux 9.8 (stretch)
Set up the timezone:
sudo dpkg-reconfigure tzdata
Install some essential packages that are necessary for basic administration of the Debian operating system:
sudo apt install -y curl wget vim git unzip socat apt-transport-https
Install PHP, as well as the necessary PHP extensions for Shopware:
sudo apt install -y php7.0 php7.0-cli php7.0-fpm php7.0-common php7.0-mysql php7.0-curl php7.0-json php7.0-zip php7.0-gd php7.0-xml php7.0-mbstring php7.0-opcache
php -m
ctype
curl
exif
fileinfo
Check the PHP version:
php --version
# PHP 7.0.30-0+deb9u1 (cli) (built: Jun 14 2018 13:50:25) ( NTS )
# with Zend OPcache v7.2.15-0debian0.18.04.1, Copyright (c) 1999-2018, by Zend Technologies
PHP-FPM service is automatically started and enabled on reboot on Debian 9 system, so there is no need to start and enable it manually. We can move on to the next step, which is the IonCube Loader installation.
Step 2 – Install IonCube Loader (optional)
Download IonCube Loader:
cd /tmp && wget https://downloads.ioncube.com/loader_downloads/ioncube_loaders_lin_x86-64.tar.gz
Extract the loader:
tar xfz ioncube_loaders_lin_*.gz
Find the PHP extensions directory on the system by running the command below:
php -i | grep extension_dir
# extension_dir => /usr/lib/php/20170718 => /usr/lib/php/20170718
Copy the ionCube Loader into the PHP extensions directory:
sudo cp /tmp/ioncube/ioncube_loader_lin_7.0.so /usr/lib/php/20170718/
Include the loader via PHP configuration:
sudo vim /etc/php/7.0/fpm/php.ini
Then add a line in the file to include ionCube loader. It can be anywhere in the file below [PHP] line:
zend_extension = /usr/lib/php/20170718/ioncube_loader_lin_7.0.so
Save the file and restart PHP-FPM:
sudo systemctl restart php7.0-fpm.service
Step 3 – Install MariaDB and create a database for Shopware
Install MariaDB database server:
sudo apt install -y mariadb-server
Check MariaDB version:
mysql --version
# mysql Ver 14.14 Distrib 5.7.26, for Linux (x86_64) using EditLine wrapper
Run mysql_secure installation script to improve MariaDB security and set the password for MariaDB root user:
Answer each of the questions:
Would you like to setup VALIDATE PASSWORD plugin? N
Re-enter new password: your_secure_password
Connect to MariaDB shell as the root user:
sudo mysql -u root -p
# Enter password
Create an empty MariaDB database and user for Shopware and remember the credentials:
mysql> CREATE DATABASE dbname;
mysql> GRANT ALL ON dbname.* TO 'username' IDENTIFIED BY 'password';
mysql> FLUSH PRIVILEGES;
Exit from MariaDB:
mysql> exit
Step 4 – Install Acme.sh client and obtain Let’s Encrypt certificate (optional)
Securing your website with HTTPS is not necessary, but it is a good practice to secure your site traffic. In order to obtain a TLS certificate from Let’s Encrypt we will use Acme.sh client. Acme.sh is a pure Unix shell software for obtaining TLS certificates from Let’s Encrypt with zero dependencies.
Download and install acme.sh:
sudo su - root
cd acme.sh
source ~/.bashrc
cd ~
Check acme.sh version:
acme.sh --version
# v2.8.1
# RSA 2048
# ECDSA
If you want fake certificates for testing you can add --staging flag to the above commands.
acme.sh --list
Create a directory to store your certs. We will use a directory /etc/letsencrypt.
# RSA
# ECC/ECDSA
exit
Step 5 – Install and configure NGINX
Install the NGINX web server:
sudo apt install -y nginx
Check the NGINX version:
sudo nginx -v
# nginx version: nginx/1.10.3
Configure NGINX for Shopware. Run sudo vim /etc/nginx/sites-available/shopware.conf and add the following configuration:
listen 443 ssl;
server_name example.com;
root /var/www/shopware;
index shopware.php index.php;
try_files $uri $uri/ /shopware.php$is_args$args;
location /recovery/install {
index index.php;
try_files $uri /recovery/install/index.php$is_args$args;
location ~ .php$ {
fastcgi_pass unix:/var/run/php/php7.0-fpm.sock;
Activate the new shopware.conf configuration by linking the file to the sites-enabled directory:
sudo ln -s /etc/nginx/sites-available/shopware.conf /etc/nginx/sites-enabled
sudo nginx -t
Reload NGINX service:
Step 6 – Install Shopware
Create a document root directory for Shopware:
sudo mkdir -p /var/www/shopware
Change ownership of the /var/www/shopware directory to {jour_user}:
sudo chown -R {your_user}:{your_user} /var/www/shopware
cd /var/www/shopware
Download and unzip the latest Shopware release via wget:
wget https://releases.shopware.com/install_5.5.8_d5bf50630eeaacc6679683e0ab0dcba89498be6d.zip?_ga=2.141661361.269357371.1556739808-1418008019.1556603459 -O shopware.zip
unzip shopware.zip
rm shopware.zip
NOTE: Update download URL if there is a newer release.
Change ownership of the /var/www/shopware directory to www-data.
sudo chown -R www-data:www-data /var/www/shopware
Increase memory_limit = 256M and upload_max_filesize = 6M, and set allow_url_fopen = On if not already set in /etc/php/7.0/fpm/php.ini file.
After making changes in /etc/php/7.0/fpm/php.ini file, reload php7.0-fpm.service:
sudo systemctl reload php7.0-fpm.service
Open your domain/IP in the web browser and follow the installation wizard. The backend of Shopware is located at /backend example: http://example.com/backend.
Step 7 – Complete the Shopware setup
Start by selecting the language and click Next:
Shopware setup wizard
Next, make sure you meet all the Shopware requirements:
System requirements are met
Agree with Shopware TOS and click Next:
Accept license
Enter database credentials and click Next:
Shopware database settings
Start the installation to create database tables:
Installing database tables
After that, you will see a message about successful database import:
Database initialization successful
Choose a license and click Next:
Choose license
Fill in a few basic settings to finish up the setup and click Next:
Basic settings
Installation is complete.
To access admin area append /backend to your URL.
Shopware backend login
You have successfully installed Shopware. Enjoy your new online shop!
