How to Install Pico CMS with Nginx on Debian 10
Pico is an open-source simple and fast flat-file CMS written in PHP. This means there is no administration backend and database to deal with. You simply create .md files in the content folder, and that becomes a page. Pico uses the Twig templating engine for powerful and flexible themes. Pico source code is available on Github. In this tutorial, we will install Pico CMS with Nginx on Debian 10 (buster) system.
Requirements for running Pico are:
  • Nginx
  • PHP version 5.3.6 or greater
  • Composer
  • Debian 10 (buster) operating system.
Initial steps
Check your Debian version:
lsb_release -ds
# Debian GNU/Linux 10 (buster)
Set up the timezone:
sudo dpkg-reconfigure tzdata
Update your operating system packages (software). This is an essential first step because it ensures you have the latest updates and security fixes for your operating system’s default software packages:
Install some essential packages that are necessary for basic administration of the Debian operating system:
sudo apt install -y curl wget vim git unzip socat bash-completion apt-transport-https
Step 1 – Install PHP
Install PHP, as well as the required PHP extensions:
sudo apt install -y php7.3 php7.3-cli php7.3-fpm php7.3-common php7.3-curl php7.3-gd php7.3-json php7.3-zip php7.3-xml php7.3-mbstring
php -m
ctype
curl
exif
fileinfo
Check the PHP version:
php --version
# PHP 7.3.4-2 (cli) (built: Apr 13 2019 19:05:48) ( NTS )
# Zend Engine v3.3.4, Copyright (c) 1998-2018 Zend Technologies
# with Zend OPcache v7.3.4-2, Copyright (c) 1999-2018, by Zend Technologies
PHP-FPM service is automatically started and enabled on reboot on Debian 10 system, so there is no need to start and enable it manually. We can move on to the next step, which is the database installation and setup.
Step 2 – Install acme.sh client and obtain Let’s Encrypt certificate (optional)
Securing your forum with HTTPS is not necessary, but it is a good practice to secure your site traffic. To obtain a TLS certificate from Let’s Encrypt we will use acme.sh client. Acme.sh is a pure UNIX shell software for obtaining TLS certificates from Let’s Encrypt with zero dependencies.
Download and install acme.sh:
sudo su - root
cd acme.sh
source ~/.bashrc
cd ~
Check acme.sh version:
acme.sh --version
# v2.8.0
# RSA 2048
# ECDSA
If you want fake certificates for testing, you can add --staging flag to the above commands.
acme.sh --list
Create a directory to store your certs. We will use /etc/letsencrypt directory.
# RSA
# ECC/ECDSA
All the certificates will be automatically renewed every 60 days.
After obtaining certs exit from root user and return back to regular sudo user:
exit
Step 3 – Install and configure NGINX
Install NGINX:
sudo apt install -y nginx
Check the NGINX version:
sudo nginx -v
# nginx version: nginx/1.14.2
Next, configure NGINX for Pico CMS. Run sudo vim /etc/nginx/sites-available/pico.conf and add the following configuration.
listen 443 ssl;
server_name example.com;
root /var/www/pico;
index index.php;
location ~ ^/((config|content|vendor|composer.(json|lock|phar))(/|$)|(.+/)?.(?!well-known(/|$))) {
deny all;
index index.php;
location ~ .php$ {
try_files $uri =404;
fastcgi_index index.php;
fastcgi_pass unix:/var/run/php/php7.3-fpm.sock;
include fastcgi_params;
fastcgi_param PICO_URL_REWRITING 1;
Activate the new pico.conf configuration by linking the file to the sites-enabled directory:
sudo ln -s /etc/nginx/sites-available/pico.conf /etc/nginx/sites-enabled
Check NGINX configuration for syntax errors:
sudo nginx -t
Reload NGINX service:
Step 4 – Install Composer
Install Composer, the PHP dependency manager globally:
php -r "if (hash_file('sha384', 'composer-setup.php') === 'a5c698ffe4b8e849a443b120cd5ba38043260d5c4023dbf93e1558871f1f07f58274fc6f4c93bcfd858c6bd0775cd8d1') { echo 'Installer verified'; } else { echo 'Installer corrupt'; unlink('composer-setup.php'); } echo PHP_EOL;"
php composer-setup.php
Check the Composer version:
composer --version
# Composer version 1.8.6 2019-06-11 15:03:05
NOTE: Composer installation commands will change in the future, so check https://getcomposer.org/download/ for the most up to date commands if the above commands don’t work.
Step 5 – Install Pico CMS
Create a document root directory for Pico CMS:
sudo mkdir -p /var/www/pico
Change ownership of the /var/www/pico directory to [your_username]:
sudo chown -R [your_username]:[your_username] /var/www/pico
Replace [your_username] in the command above with the username of the Linux user that you are currently logged in.
Then navigate to the document root directory:
cd /var/www/pico
Download Pico with composer:
composer create-project picocms/pico-composer .
Change ownership of the /var/www/pico directory to www-data:
sudo chown -R www-data:www-data /var/www/pico
You have successfully installed Pico CMS on Debian 10 (buster) system. You can now simply create your own content folder in Pico’s root directory, create .md files in the content directory and those files become your pages.
Pico CMS
Links
