How to Install Pico CMS with Nginx and Let’s Encrypt on CentOS 7
Pico is an open-source simple and fast flat-file CMS written in PHP. This means there is no administration backend and database to deal with. You simply create .md files in the content folder and that becomes a page. Pico uses the Twig templating engine, for powerful and flexible themes. Pico source code is available on Github. In this tutorial, we will install Pico CMS with Nginx on CentOS 7 system.
Requirements for running Pico are:
  • Nginx
  • PHP version 5.3.6 or greater
  • Composer
  • A CentOS 7 operating system.
Initial steps
Check your CentOS version:
cat /etc/centos-release
# CentOS Linux release 7.6.1810 (Core)
Set up the timezone:
timedatectl list-timezones
sudo yum update -y
Install some essential packages that are necessary for basic administration of the CentOS operating system:
sudo yum install -y curl wget vim git unzip socat bash-completion epel-release
Step 1 – Install PHP
Setup the Webtatic YUM repo:
sudo yum install -y php72w php72w-cli php72w-fpm php72w-common php72w-curl php72w-gd php72w-json php72w-zip php72w-xml php72w-mbstring
php -m
ctype
curl
exif
fileinfo
Check the PHP version:
php --version
# PHP 7.2.19 (cli) (built: Jan 12 2019 12:47:33) ( NTS )
# Zend Engine v3.0.0, Copyright (c) 1998-2017 Zend Technologies
# with Zend OPcache v7.2.14, Copyright (c) 1999-2018, by Zend Technologies
Step 2 – Install acme.sh client and obtain Let’s Encrypt certificate (optional)
Securing your forum with HTTPS is not necessary, but it is a good practice to secure your site traffic. In order to obtain a TLS certificate from Let’s Encrypt we will use acme.sh client. Acme.sh is a pure UNIX shell software for obtaining TLS certificates from Let’s Encrypt with zero dependencies.
Download and install acme.sh:
sudo su - root
cd acme.sh
source ~/.bashrc
cd ~
Check acme.sh version:
acme.sh --version
# v2.8.2
# RSA 2048
# ECDSA
If you want fake certificates for testing you can add --staging flag to the above commands.
acme.sh --list
Create a directory to store your certs. We will use /etc/letsencrypt directory.
# RSA
# ECC/ECDSA
All the certificates will be automatically renewed every 60 days.
exit
Step 3 – Install and configure NGINX
Download and install Nginx from the CentOS repository:
sudo yum install -y nginx
Check the Nginx version:
nginx -v
# nginx version: nginx/1.12.2
Start and enable Nginx service:
Configure NGINX for Pico CMS by running:
sudo vim /etc/nginx/conf.d/pico.conf
listen 443 ssl;
server_name example.com;
root /var/www/pico;
index index.php;
location ~ ^/((config|content|vendor|composer.(json|lock|phar))(/|$)|(.+/)?.(?!well-known(/|$))) {
deny all;
index index.php;
location ~ .php$ {
try_files $uri =404;
fastcgi_index index.php;
fastcgi_pass 127.0.0.1:9000;
include fastcgi_params;
fastcgi_param PICO_URL_REWRITING 1;
Check NGINX configuration for syntax errors:
sudo nginx -t
Reload NGINX service:
Step 4 – Install Composer
Install Composer, the PHP dependency manager globally:
php -r "if (hash_file('sha384', 'composer-setup.php') === 'a5c698ffe4b8e849a443b120cd5ba38043260d5c4023dbf93e1558871f1f07f58274fc6f4c93bcfd858c6bd0775cd8d1') { echo 'Installer verified'; } else { echo 'Installer corrupt'; unlink('composer-setup.php'); } echo PHP_EOL;"
php composer-setup.php
Check the Composer version:
composer --version
# Composer version 1.9.0 2019-08-02 20:55:32
NOTE: Composer installation commands will change in the future, so check https://getcomposer.org/download/ for the most up to date commands if the above commands don’t work.
Step 5 – Install Pico CMS
Create a document root directory for Pico CMS:
sudo mkdir -p /var/www/pico
Change ownership of the /var/www/pico directory to your_username that you should have created before and you should be logged in as this user.
sudo chown -R your_username:your_username /var/www/pico
NOTE: Don’t forget to replace your_username with the name that you have chosen.
cd /var/www/pico
Download Pico with composer:
composer create-project picocms/pico-composer .
Provide the appropriate ownership:
sudo chown -R nginx:nginx /var/www/pico
Run sudo vim /etc/php-fpm.d/www.conf and set the user and group to nginx. Initially, they will be set to apache. Run:
And set user and group to nginx, like below:
user = nginx
group = nginx
And finally, restart PHP-FPM service for these changes to take effect:
You have successfully installed Pico CMS on CentOS 7 server. You can now simply create your own content folder in Pico’s root directory, create .md files in the content directory and those files become your pages.
Links
