How to Install Phorum with Nginx on Fedora 30
Phorum is a PHP and MySQL based Open Source forum software. In this guide, we will guide you step-by-step through the Phorum installation process on the Fedora 30 operating system using Nginx as the web server, MariaDB as the database, and acme.sh and Let’s Encrypt for HTTPS.
Requirements for running Phorum are:
- Nginx
- PHP version 5.2 or greater
- MySQL version 5.0 or greater
- Fedora 30 operating system.
- A non-root user with
sudo
privileges.
Initial steps
Check your Fedora system version:
cat /etc/fedora-release
# Fedora release 30 (Thirty)
Set up the timezone:
timedatectl list-timezones
sudo dnf upgrade -y
Install some essential packages that are necessary for basic administration of the Fedora operating system:
sudo dnf install -y curl wget vim git sudo unzip socat bash-completion
Step 1 – Install PHP
sudo dnf install -y php php-cli php-fpm php-common php-mysqlnd
php -m
ctype
curl
exif
fileinfo
Check the PHP version:
php --version
# PHP 7.3.5 (cli) (built: Apr 30 2019 08:37:17) ( NTS )
# Zend Engine v3.3.5, Copyright (c) 1998-2018 Zend Technologies
Step 2 – Install MariaDB and create a database
Install MariaDB database server:
sudo dnf install -y mariadb-server
Check the MariaDB version:
mysql --version
# mysql Ver 15.1 Distrib 10.3.12-MariaDB, for Linux (x86_64) using readline 5.1
Start and enable MariaDB service:
Run mysql_secure installation
script to improve MariaDB security and set the password for MariaDB root
user:
Answer each of the questions:
Would you like to setup VALIDATE PASSWORD plugin? N
Re-enter new password: your_secure_password
Connect to MariaDB shell as the root user:
sudo mysql -u root -p
# Enter password
Create an empty MariaDB database and user for Phorum and remember the credentials:
mysql> CREATE DATABASE dbname;
mysql> GRANT ALL ON dbname.* TO 'username' IDENTIFIED BY 'password';
mysql> FLUSH PRIVILEGES;
Exit from MariaDB:
mysql> exit
Replace dbname
, username
and password
with your own names.
Step 3 – Install acme.sh
client and obtain Let’s Encrypt certificate (optional)
Securing your forum with HTTPS is not necessary, but it is a good practice to secure your site traffic. In order to obtain TLS certificate from Let’s Encrypt we will use acme.sh client. Acme.sh is a pure UNIX shell software for obtaining TLS certificates from Let’s Encrypt with zero dependencies.
Download and install acme.sh:
sudo su - root
cd acme.sh
./acme.sh --install --accountemail [email protected]
source ~/.bashrc
cd ~
Check acme.sh version:
acme.sh --version
# v2.8.0
# RSA 2048
# ECDSA
If you want fake certificates for testing you can add --staging
flag to the above commands.
- For RSA:
/home/username/example.com
directory. - For ECC/ECDSA:
/home/username/example.com_ecc
directory.
acme.sh --list
Create a directory to store your certs. We will use /etc/letsencrypt
directory.
# RSA
# ECC/ECDSA
exit
Step 4 – Install and configure NGINX
Install NGINX:
sudo dnf install -y nginx
Check the NGINX version:
nginx -v
# nginx version: nginx/1.16.0
Start and enable NGINX service:
Configure NGINX for Phorum. Run sudo vim /etc/nginx/conf.d/phorum.conf
and add the following configuration.
listen 443 ssl;
server_name example.com;
root /var/www/phorum;
index index.php index.html;
location ~ .php$ {
include default.d/php.conf;
fastcgi_index index.php;
include fastcgi_params;
sudo nginx -t
Reload NGINX service:
Step 4 – Install Phorum
Create a document root directory for Phorum:
sudo mkdir -p /var/www/phorum
Change ownership of the /var/www/phorum
directory to [jour_user]:
sudo chown -R [your_user]:[your_user] /var/www/phorum
cd /var/www/phorum
Download the latest stable Phorum distribution from the official website:
wget https://www.phorum.org/downloads/phorum-5.2.23.tar.gz
Unpack the downloaded archive and move files to the document root:
tar xvzf phorum-5.2.23.tar.gz
rm phorum-5.2.23.tar.gz
mv Core-phorum_5_2_23/* . && mv Core-phorum_5_2_23/.* .
rmdir Core-phorum_5_2_23
Configure the database access:
cp include/db/config.php.sample include/db/config.php
Configure database settings by editing include/db/config.php
file:
vim include/db/config.php
Change ownership of the /var/www/craft
directory to nginx:
sudo chown -R nginx:nginx /var/www/phorum
Run sudo vim /etc/php-fpm.d/www.conf
and set the user and group to nginx
. Initially, they will be set to apache:
# user = nginx
# group = nginx
To finish the installation, run the web-based installer by visiting http://forum.example.com/admin.php
in your web browser.
