How to Install Laravel based PyroCMS with Nginx on CentOS 7
PyroCMS is a powerful modular CMS and development platform built with Laravel 5, which allows you to build better Laravel websites and applications faster.
In this tutorial, we will walk you through the PyroCMS installation process on a CentOS 7 operating system by using NGINX as a web server, MariaDB as a database server, and optionally you can secure the transport layer by using acme.sh client and Let’s Encrypt certificate authority to add SSL support.
To install PyroCMS, make sure your system meets the following requirements:
- At least 1GB of RAM or Swap configured
- PHP version 7.0 or greater with PDO, cURL, SQLite, OpenSSL, Mbstring, Fileinfo, Tokenizer, GD PHP extensions.
- MariaDB
- NGINX
- A system running CentOS 7 system.
Initial steps
Check your CentOS version:
cat /etc/centos-release
# CentOS Linux release 7.6.1810 (Core)
Set up the timezone:
timedatectl list-timezones
sudo yum update -y
Install some essential packages that are necessary for basic administration of the CentOS operating system:
sudo yum install -y curl wget vim git unzip socat bash-completion epel-release
Setup the Webtatic YUM repo:
Download and install PHP and required PHP extensions:
sudo yum install -y php72w php72w-cli php72w-fpm php72w-mysqlnd php72w-curl php72w-sqlite3 php72w-mbstring php72w-gd php72w-xml
php -m
ctype
curl
exif
fileinfo
Check the PHP version:
php --version
# PHP 7.2.19 (cli) (built: Jan 12 2019 12:47:33) ( NTS )
# Zend Engine v3.0.0, Copyright (c) 1998-2017 Zend Technologies
# with Zend OPcache v7.2.14, Copyright (c) 1999-2018, by Zend Technologies
Step 2 – Install MariaDB and create a database for PyroCMS
Install MariaDB from the official MariaDB repository. Create a repository first:
sudo vim /etc/yum.repos.d/MariaDB.repo
Copy and paste following fragment to the /etc/yum.repos.d/MariaDB.repo file:
[mariadb]
name = MariaDB
baseurl = https://yum.mariadb.org/10.2/centos7-amd64
gpgkey=https://yum.mariadb.org/RPM-GPG-KEY-MariaDB
gpgcheck=1
Install MariaDB:
sudo yum install -y MariaDB-server MariaDB-client
Check the MariaDB version:
mysql --version
# mysql Ver 15.1 Distrib 10.2.13-MariaDB, for Linux (x86_64) using readline 5.1
Start and enable MariaDB service:
Run mysql_secure installation
script to improve MariaDB security and set the password for MariaDB root
user:
Answer each of the questions:
Enter current password for root (enter for none): Press Enter
Set root password? [Y/n] Y
Re-enter new password: your_secure_password
Log into MariaDB as the root user:
sudo mysql -u root -p
# Enter password
Create a MariaDB database and user that you will use for your installation of PyroCMS, and remember the credentials:
CREATE DATABASE dbname;
FLUSH PRIVILEGES;
Replace dbname and username with appropriate names for your setup. Replace password with a strong password.
Exit from MariaDB shell:
quit
Step 3 – Install Acme.sh client and obtain Let’s Encrypt certificate (optional)
Securing your website with HTTPS is not necessary, but it is a good practice to secure your site traffic. In order to obtain an SSL certificate from Let’s Encrypt we will use Acme.sh client. Acme.sh is a pure UNIX shell software for obtaining SSL certificates from Let’s Encrypt with zero dependencies.
Download and install acme.sh:
sudo su - root
cd acme.sh
./acme.sh --install --accountemail [email protected]
source ~/.bashrc
cd ~
Check acme.sh version:
acme.sh --version
# v2.8.1
# RSA 2048
# ECDSA
If you want fake certificates for testing you can add --staging
flag to the above commands.
acme.sh --list
Create a directory to store your certs. We will use /etc/letsencrypt
directory.
mkdir -p /etc/letsencrypt/example.com
# RSA
acme.sh --install-cert -d example.com
--cert-file /etc/letsencrypt/example.com/cert.pem
--key-file /etc/letsencrypt/example.com/private.key
--fullchain-file /etc/letsencrypt/example.com/fullchain.pem
--reloadcmd "sudo systemctl reload nginx.service"
# ECC/ECDSA
acme.sh --install-cert -d example.com --ecc
--cert-file /etc/letsencrypt/example.com_ecc/cert.pem
--key-file /etc/letsencrypt/example.com_ecc/private.key
--fullchain-file /etc/letsencrypt/example.com_ecc/fullchain.pem
- For RSA: /etc/letsencrypt
/example.com
directory. - For ECC/ECDSA: /etc/letsencrypt
/example.com_ecc
directory.
After obtaining certs, exit from root user and return back to normal sudo user:
exit
Step 4 – Install NGINX and configure NGINX for PyroCMS
Install the NGINX web server:
sudo yum install -y nginx
Check the NGINX version:
nginx -v
Start and enable Nginx service:
Configure NGINX for PyroCMS by running:
sudo vim /etc/nginx/conf.d/pyro.conf
listen 443 ssl;
server_name example.com;
index index.php index.html;
root /var/www/pyro/public;
ssl_certificate /etc/letsencrypt/status.example.com/fullchain.cer;
ssl_certificate_key /etc/letsencrypt/status.example.com/status.example.com.key;
ssl_certificate /etc/letsencrypt/status.example.com_ecc/fullchain.cer;
ssl_certificate_key /etc/letsencrypt/status.example.com_ecc/status.example.com.key;
location ~ .php$ {
include fastcgi_params;
fastcgi_pass 127.0.0.1:9000;
fastcgi_index index.php;
sudo nginx -t
Reload NGINX service:
Step 5 – Install Composer
Install Composer, the PHP dependency manager globally:
php -r "if (hash_file('sha384', 'composer-setup.php') === 'a5c698ffe4b8e849a443b120cd5ba38043260d5c4023dbf93e1558871f1f07f58274fc6f4c93bcfd858c6bd0775cd8d1') { echo 'Installer verified'; } else { echo 'Installer corrupt'; unlink('composer-setup.php'); } echo PHP_EOL;"
php composer-setup.php
Check Composer version:
composer --version
# Composer version 1.9.0 2019-08-02 10:52:10
Step 6 – Install PyroCMS
Create a document root directory where PyroCMS should reside in:
sudo mkdir -p /var/www/pyro
Change ownership of the /var/www/pyro
directory to your_username
that you should have created before and you should be logged in as this user.
sudo chown -R your_username:your_username /var/www/pyro
NOTE: Don’t forget to replace your_username with the name that you have chosen.
Navigate to document root:
cd /var/www/pyro
Download the latest stable release of PyroCMS via composer
composer create-project pyrocms/pyrocms .
directory to www-data
sudo chown -R nginx:nginx /var/www/pyro
Run sudo vim /etc/php-fpm.d/www.conf
and set the user and group to nginx
. Initially, they will be set to apache.
Run:
And set user and group to nginx, like below:
user = nginx
group = nginx
And finally, restart PHP-FPM service for these changes to take effect:
Step 7 – Complete the PyroCMS setup
Access your site in a web browser via domain name or IP address and follow the PyroCMS web installation wizard.
After you have filled all the required information, your PyroCMS installation is complete.
Links
