How to Install InvoicePlane with Nginx on Debian 9
invoiceplane welcome 2
InvoicePlane is a free and open-source invoicing application. Its source code can be found on this Github. This tutorial will show you how to install InvoicePlane on a fresh Debian 9 (stretch) system.
  • WebServer (Apache, NGINX). This tutorial will use Nginx.
  • MySQL version 5.5 or greater or the equivalent version of MariaDB.
  • PHP version 7.0, 7.1, or 7.2 with the following PHP extensions installed and activated:
  • php-gd
  • php-hash
  • php-json
  • php-mbstring
  • php-mcrypt
  • php-mysqli
  • php-openssl
  • php-recode
  • php-xmlrpc
  • php-zlib
  • A server running Debian 9.
Initial steps
Check your Debian version:
lsb_release -ds
# Debian GNU/Linux 9 (stretch)
Set up the timezone:
sudo dpkg-reconfigure tzdata
Update your operating system packages (software). That is an essential first step because it ensures you have the latest updates and security fixes for your operating system’s default software packages:
Install some essential packages that are necessary for basic administration of the Debian operating system:
sudo apt install -y curl wget vim git unzip socat bash-completion apt-transport-https
Step 1 – Install PHP and required PHP extensions
InvoicePlane web application requires PHP version 7.0 or greater.
sudo apt install -y php-cli php-fpm php-common php-gd php-json php-mbstring php-mysql php-xmlrpc php-recode
php -m
ctype
curl
exif
fileinfo
Check the PHP version:
php --version
# PHP 7.0.9-1~deb10u1 (cli) (built: Sep 18 2019 10:33:23) ( NTS )
# Zend Engine v3.3.9, Copyright (c) 1998-2018 Zend Technologies
# with Zend OPcache v7.0.9-1~deb10u1, Copyright (c) 1999-2018, by Zend Technologies
sudo systemctl start php7.0-fpm.service
sudo systemctl enable php7.0-fpm.service
Step 2 – Install MariaDB
Install MariaDB:
sudo apt install -y mariadb-server
Check the MariaDB version:
mysql --version
Start and enable MariaDB service:
Run mysql_secure installation script to improve MariaDB security and set the password for MariaDB root user:
Set root password? [Y/n]: Y
Log into MariaDB shell as the user root:
mysql -u root -p
# Enter password
Create a MariaDB database and user that you will use for your installation of InvoicePlane, and remember the credentials:
CREATE DATABASE dbname;
FLUSH PRIVILEGES;
Exit from MariaDB shell:
quit
Replace dbnameusername, and password with your own names.
Step 3 – Install NGINX
Install Nginx webserver:
sudo apt install -y nginx
Check the NGINX version:
nginx -v
# nginx version: nginx/1.10.3
Start and enable Nginx service:
Configure NGINX for InvoicePlane. Run sudo vim /etc/nginx/sites-available/invoiceplane.conf and populate the file with the following configuration:
listen [::]:80;
server_name example.com;
root /var/www/InvoicePlane;
index index.php index.html;
location ~ .php$ {
include fastcgi_params;
fastcgi_pass unix:/var/run/php/php7.0-fpm.sock;
Activate the new invoiceplane.conf configuration by linking the file to the sites-enabled directory:
sudo ln -s /etc/nginx/sites-available/invoiceplane.conf /etc/nginx/sites-enabled/
Test the NGINX configuration:
sudo nginx -t
Reload NGINX:
Step 4 – Install InvoicePlane
Download the latest stable version of InvoicePlane and extract the archive:
sudo mkdir -p /var/www
cd /var/www
sudo curl -O -J -L https://invoiceplane.com/download/v1.5.9
sudo unzip v1.5.9.zip
sudo rm v1.5.9.zip
sudo mv ip invoiceplane
Navigate to /var/www/invoiceplane directory:
cd /var/www/invoiceplane
Make a copy of the ipconfig.php.example file and rename the copy to ipconfig.php:
sudo cp ipconfig.php.example ipconfig.php
Open the ipconfig.php file and add your URL in it:
sudo vim ipconfig.php
# Something like this
IP_URL=http://example.com
Change ownership of the /var/www/invoiceplane directory to www-data:
sudo chown -R www-data:www-data /var/www/InvoicePlane
Run sudo vim /etc/php.ini and set date.timezone:
date.timezone = Region/City
Restart the PHP-FPM service:
sudo systemctl restart php7.0-fpm.service
Run the InvoicePlane installer from your web browser and follow the instructions:
http://example.com/index.php/setup
Once the installation has finished, you may log into InvoicePlane using the email address and password you have chosen during the installation.
If you want to secure your installation, you may disable the setup. To do so, replace the DISABLE_SETUP=false line with DISABLE_SETUP=true in your ipconfig.php file.
Step 5 – Complete the InvoicePlane setup
InvoicePlane is now installed and configured, it’s time to access its web installation wizard.
InvoicePlane web installer
Now, click on the Setup button. You should see the following page:
Choose language
Next, choose the language and click on the Continue button. You should see the following page:
Check system requirements
Next, click on the Continue button. You should see the following page:
Database details
Here, provide your database details and click on the Try Again button. You should see the following page:
Database connection successful
Now, click on the Continue button. You should see the following page:
Create user account
InvoicePlane installation complete
Now, provide all the required details, then click on the Continue button. Once the installation is completed, you should see the following page:
Login to InvoicePlane
Now, click on the Login button to access InvoicePlane administration.
