How to Install i-doit Asset Management Tool on Debian 10
i-doit is a free, open-source and IT documentation solution based on the configuration management database. It is a web-based tool that can be used to manage the entire IT system according to ITIL best practices. With this tool, you can keep track of software and hardware assets, their relations and visualize the relationships between these components. You can store, maintain and organize all IT documentation information in one place. It can be easily interfaced to other applications like, Nagios and Request Tracker that allows you to enter the data only once in the ITSM environment.
i-doit enables you to create a detailed overview of your entire IT-infrastructure for all kinds of assets including, servers, SAN, graphical rack views, clusters and blade/chassis systems. It comes with a rich set of features including, IT Documentation, Inventory, Infrastructure Planning, Asset Management, Virtual systems, IP Address Management, Storage Area Networks, Cable Management, Ticket System and many more.
In this tutorial, we will show you how to install and configure i-doit Asset Management Tool on Debian 10.
  • A server running Debian 10 with minimu 2GB RAM.
  • A valid domain name is pointed with your server IP address. In this tutorial, we will use idoit.linuxbuz.com.
  • A root password is configured on each server.
Before starting, it is a good idea to update your system with the latest version. You can update your system with the following command:
apt-get upgrade -y
After updating the system, restart it to implement the changes.
Install LAMP Server
First, you will need to install the Apache, MariaDB, PHP and other required PHP extensions to your system. You can install all of them with the following command:
apt-get install apache2 mariadb-server libapache2-mod-php php php-common php-curl php-bcmath php-gd php-json php-ldap php-mbstring php-mysql php-opcache php-pgsql php-soap php-xml php-soap php-zip php-memcached php-imagick unzip memcached moreutils -y
Once all the packages are installed, you will need to create a separate i-doit.ini PHP file with required settings.
You can create it with the following command:
nano /etc/php/7.3/mods-available/i-doit.ini
allow_url_fopen = Yes
file_uploads = On
magic_quotes_gpc = Off
max_execution_time = 300
max_file_uploads = 42
max_input_time = 60
max_input_vars = 10000
memory_limit = 256M
post_max_size = 128M
register_argc_argv = On
register_globals = Off
short_open_tag = On
upload_max_filesize = 128M
display_errors = Off
display_startup_errors = Off
error_reporting = E_ALL & ~E_DEPRECATED & ~E_STRICT
log_errors = On
default_charset = "UTF-8"
default_socket_timeout = 60
date.timezone = Asia/Kolkata
session.gc_maxlifetime = 604800
session.cookie_lifetime = 0
mysqli.default_socket = /var/run/mysqld/mysqld.sock
Save and close the file when you are finished. Then, enable the required PHP modules with the following command:
phpenmod i-doit
phpenmod memcached
Finally, restart the Apache service to implement the changes:
systemctl restart apache2
Configure MariaDB for i-doit
Next, you will need to set a MariaDB root password as it is not set in the Debian 10.
To do so, log in to MariaDB shell with the following command:
mysql
Once login, set a MariaDB root password with the following command:
MariaDB [(none)]> SET PASSWORD FOR 'root'@'localhost' = PASSWORD("yournewpassword");
Next, set the MariaDB authentication plugin to mysql_native_password with the following command:
MariaDB [(none)]> SET GLOBAL innodb_fast_shutdown = 0;
MariaDB [(none)]> UPDATE mysql.user SET plugin = 'mysql_native_password' WHERE User = 'root';
MariaDB [(none)]> EXIT;
Next, create a separate MariaDB configuration file for optimal performance:
nano /etc/mysql/mariadb.conf.d/99-i-doit.cnf
[mysqld] innodb_buffer_pool_size = 1G
innodb_buffer_pool_instances = 1
innodb_log_file_size = 512M
innodb_sort_buffer_size = 64M
sort_buffer_size = 262144 # default
join_buffer_size = 262144 # default
max_allowed_packet = 128M
max_heap_table_size = 32M
query_cache_min_res_unit = 4096
query_cache_type = 1
query_cache_limit = 5M
query_cache_size = 80M
tmp_table_size = 32M
max_connections = 200
innodb_file_per_table = 1
innodb_thread_concurrency = 0
innodb_flush_log_at_trx_commit = 1
innodb_flush_method = O_DIRECT
innodb_lru_scan_depth = 2048
table_definition_cache = 1024
table_open_cache = 2048
innodb_stats_on_metadata = 0
sql-mode = ""
Finally, restart the MariaDB service to apply the changes:
systemctl restart mariadb
Download i-doit
At the time of writing this article the latest version of i-doit is 1.14. You can download it with the following command:
wget https://excellmedia.dl.sourceforge.net/project/i-doit/i-doit/1.14/idoit-open-1.14.zip
Once the download is completed, unzip the downloaded file to the Apache root directory:
unzip idoit-open-1.14.zip -d /var/www/html/idoit
Next, give proper permissions to the i-doit direcotry:
chown -R www-data:www-data /var/www/html/idoit/
chmod -R 775 /var/www/html/idoit/
Configure Apache for i-doit
Next, you will need to configure an Apache virtual host configuration file for i-doit. You can create it with the following command:
nano /etc/apache2/sites-available/idoit.conf
ServerName idoit.linuxbuz.com
DirectoryIndex index.php
DocumentRoot /var/www/html/idoit
<Directory /var/www/html/idoit>
Require all granted
LogLevel warn
Save and close the file when you are finished. Then, enable the i-doit virtual host file and Apache rewrite module with the following command:
a2ensite i-doit
a2enmod rewrite
Access i-doit Web Interface
Open your web browser and type the URL http://idoit.linuxbuz.com. You will be redirected to the following page:
i-doit setup
Make sure all the required PHP extension are installed, then click on the Next button. You should see the following page:
i-doit Directory anf configuration
Check the suggested directory and click on the Next button. You should see the following page:
Database connection
Provide the MariaDB root username, password, a new database username, password, system database name and click on the Next button. You should see the following page:
Admin user details
Provide your Admin username, password and click on the Next button. You should see the following page:
Configuration check
Next, verify all the configuration and click on the Next button. You should see the following page:
Installation status
Click on the Next button to start the installation. Once the installation is finished, you should see the following page:
i-doit Login
Provide your admin username, password and click on the Login button. You should see the i-doit dashboard in the following page:
i-doit dashboard
Secure i-doit with Let’s Encrypt Free SSL
After installing i-doit, it is recommended to secure it with Let’s Encrypt free SSL. You can secure it with Certbot client.
By default, the Certbot client package is not available in the Debian 10 default repository. You can add it with the following command:
echo "deb http://ftp.debian.org/debian buster-backports main" >> /etc/apt/sources.list
Next, update the repository and install the Certbot client with the following command:
apt-get install python-certbot-apache -t buster-backports
Once installed, run the following command to obtain and install the SSL certificate for your domain:
certbot --apache -d idoit.linuxbuz.com
You will be prompt to accept the term of service and provide your valid email address as shown below:
cancel): [email protected]
(A)gree/(C)ancel: A
(Y)es/(N)o: Y
Obtaining a new certificate
http-01 challenge for idoit.linuxbuz.com
Waiting for verification...
Cleaning up challenges
Created an SSL vhost at /etc/apache2/sites-available/idoit-le-ssl.conf
Enabled Apache socache_shmcb module
Enabled Apache ssl module
Deploying Certificate to VirtualHost /etc/apache2/sites-available/idoit-le-ssl.conf
Enabling available site: /etc/apache2/sites-available/idoit-le-ssl.conf
Next, you will need to choose whether or not to redirect HTTP traffic to HTTPS as shown below:
Type 2 and hit Enter to continue. Once the installation has been completed, you should get the following output:
Redirecting vhost in /etc/apache2/sites-enabled/idoit.conf to ssl vhost in /etc/apache2/sites-available/idoit-le-ssl.conf
Congratulations! You have successfully enabled https://idoit.linuxbuz.com
https://www.ssllabs.com/ssltest/analyze.html?d=idoit.linuxbuz.com
IMPORTANT NOTES:
/etc/letsencrypt/live/idoit.linuxbuz.com/fullchain.pem
/etc/letsencrypt/live/idoit.linuxbuz.com/privkey.pem
Your cert will expire on 2020-04-30. To obtain a new or tweaked
Congratulations! your i-doit website is now secured with Let’s Encrypt SSL. You can now access it securely using the URL https://idoit.linuxbuz.com.
In the above tutorial, we learned how to install the i-doit asset management tool on Debian 10. we also learned how to secure it with Let’s Encrypt free SSL. You can now manage your entire IT documentation using the i-doit web interface.
