How to Install Grav CMS with Nginx on Debian 9
screenshot 2019 05 30 at 02
Grav is a FastSimple, and Flexible, file-based Web-platform. It follows similar principles to other flat-file CMS platforms but has a different design philosophy than most. Grav comes with a powerful Package Management System to allow for simple installation and upgrading of plugins and themes, as well as simple updating of Grav itself.
The underlying architecture of Grav is designed to use well-established and best-in-class technologies to ensure that Grav is simple to use and easy to extend. Some of these key technologies include:
  • Twig Templating: for powerful control of the user interface
  • Markdown: for easy content creation
  • YAML: for simple configuration
  • Parsedown: for fast Markdown and Markdown Extra support
  • Doctrine Cache: layer for performance
  • Pimple Dependency Injection Container: for extensibility and maintainability
  • Symfony Event Dispatcher: for plugin event handling
  • Symfony Console: for CLI interface
  • Gregwar Image Library: for dynamic image manipulation
In this guide, we will guide you step-by-step through the Grav CMS installation process on the Debian 9 operating system using Nginx as the web server, and acme.sh and Let’s Encrypt for HTTPS.
  • Web Server (Apache, Nginx, LiteSpeed, Lightly or IIS). In this guide, we will use NGINX.
  • PHP 7.1.3 or higher with the following PHP extensions: curl, ctype, dom, gd, json, mbstring, openssl, session, simplexml, xml, zip, apcu(optional), opcache(optional).
  • An operating system running Debian 9.
Initial steps
Check your Debian version:
lsb_release -ds
# Debian GNU/Linux 9.9 (stretch)
Set up the timezone:
sudo dpkg-reconfigure tzdata
Install some essential packages that are necessary for basic administration of the Debian operating system:
sudo apt install -y curl wget vim git unzip socat apt-transport-https
Grav CMS requires PHP version 7.1 or greater. Debian has PHP version 7 in the default repository, thus you will need to use third-party repo to install a newer version.
sudo apt install apt-transport-https lsb-release ca-certificates
sudo wget -O /etc/apt/trusted.gpg.d/php.gpg https://packages.sury.org/php/apt.gpg
echo "deb https://packages.sury.org/php/ $(lsb_release -sc) main" | sudo tee /etc/apt/sources.list.d/php.list
Install PHP 7.2, as well as the necessary PHP extensions:
sudo apt install -y php7.2 php7.2-cli php7.2-fpm php7.2-common php7.2-curl php7.2-gd php7.2-json php7.2-mbstring php7.2-xml php7.2-zip php7.2-opcache php-apcu
Check the PHP version:
php --version
# PHP 7.2.18-1+0~20190503103213.21+stretch~1.gbp101320 (cli) (built: May  3 2019 10:32:13) ( NTS )
# with Zend OPcache v7.2.18-1+0~20190503103213.21+stretch~1.gbp101320, Copyright (c) 1999-2018, by Zend Technologies
PHP-FPM service is automatically started and enabled on reboot on Debian 9 system, so there is no need to start and enable it manually. We can move on to the next step, which is SSL setup.
Step 2 – Install Acme.sh client and obtain Let’s Encrypt certificate (optional)
Securing your website with HTTPS is not necessary, but it is a good practice to secure your site traffic. In order to obtain TLS certificate from Let’s Encrypt we will use Acme.sh client. Acme.sh is a pure Unix shell software for obtaining TLS certificates from Let’s Encrypt with zero dependencies.
Download and install Acme.sh:
sudo mkdir /etc/letsencrypt
cd acme.sh
sudo ./acme.sh --install --home /etc/letsencrypt --accountemail [email protected]
cd ~
Check Acme.sh version:
/etc/letsencrypt/acme.sh --version
# v2.8.0
# RSA 2048
sudo /etc/letsencrypt/acme.sh --issue --standalone --home /etc/letsencrypt -d example.com --keylength 2048
# ECDSA
sudo /etc/letsencrypt/acme.sh --issue --standalone --home /etc/letsencrypt -d example.com --keylength ec-256
  • For RSA: /etc/letsencrypt/example.com directory.
  • For ECC/ECDSA: /etc/letsencrypt/example.com_ecc directory.
Step 3 – Install and configure NGINX
Install the NGINX web server:
sudo apt install -y nginx
Check the NGINX version:
nginx -v
# nginx version: nginx/1.10.3
Run sudo vim /etc/nginx/sites-available/grav.conf and populate the file with the following configuration:
server_name example.com;
root /var/www/grav;
index index.html index.php;
location ~* /(.git|cache|bin|logs|backup|tests)/.*$ { return 403; }
location ~* /(system|vendor)/.*.(txt|xml|md|html|yaml|yml|php|pl|py|cgi|twig|sh|bat)$ { return 403; }
location ~* /user/.*.(txt|md|yaml|yml|php|pl|py|cgi|twig|sh|bat)$ { return 403; }
location ~ /(LICENSE.txt|composer.lock|composer.json|nginx.conf|web.config|htaccess.txt|.htaccess) { return 403; }
location ~ .php$ {
fastcgi_index index.php;
include fastcgi_params;
fastcgi_param SCRIPT_FILENAME $document_root/$fastcgi_script_name;
Activate the new grav.conf configuration by linking the file to the sites-enabled directory.
sudo ln -s /etc/nginx/sites-available/grav.conf /etc/nginx/sites-enabled
Check NGINX configuration for syntax errors:
sudo nginx -t
Reload NGINX service:
Step 4 – Install Grav CMS
Create a document root directory where Grav should reside in:
sudo mkdir -p /var/www/grav
Change the ownership of the /var/www/grav directory to {your_user}. Replace {your_user} in the command below with the username that you are currently logged into Debian.:
sudo chown -R {your_user}:{your_user} /var/www/grav
cd /var/www/grav
Download the latest version from the official page and extract the zip file:
wget https://getgrav.org/download/core/grav-admin/1.6.9
unzip 1.6.9
mv grav-admin/* . && mv grav-admin/.* .
rm -rf grav-admin 1.6.9
NOTE: Update download URL if there is a newer release.
Change ownership of the /var/www/grav directory to www-data:
sudo chown -R www-data:www-data /var/www/grav
Step 5 – Complete the Grav setup
Open your site in a web browser and you should see a page that asks you to create a Grav admin account. Create one and proceed by clicking the “Create User” button:
svg%3E
That’s it. Your Grav installation is complete.
