How to Install Grav CMS on CentOS 7
Grav is a fast, simple, and flexible, file-based CMS platform. Grav comes with a powerful Package Management System to allow for simple installation and upgrading of plugins and themes, as well as simple updating of Grav itself.
The underlying architecture of Grav is designed to use well-established and best-in-class technologies to ensure that Grav is simple to use and easy to extend. Some of these key technologies include:
- Twig Templating: for powerful control of the user interface
- Markdown: for easy content creation
- YAML: for simple configuration
- Parsedown: for fast Markdown and Markdown Extra support
- Doctrine Cache: layer for performance
- Pimple Dependency Injection Container: for extensibility and maintainability
- Symfony Event Dispatcher: for plugin event handling
- Symfony Console: for CLI interface
- Gregwar Image Library: for dynamic image manipulation
Grav is intentionally designed with few requirements. Grav is built with plain text files for your content. There is no database needed.
Make sure your system meets the following requirements:
- Web Server (Apache, Nginx, LiteSpeed, Lightly, IIS, etc.) We will use NGINX.
- PHP version 7.1.3 or higher
- An operating system running CentOS 7.
Initial steps
Check your CentOS version:
cat /etc/centos-release
# CentOS Linux release 7.6.1810 (Core)
Set up the timezone:
timedatectl list-timezones
sudo yum update -y
Install some essential packages that are necessary for basic administration of the CentOS operating system:
sudo yum install -y curl wget vim git unzip socat bash-completion epel-release
Setup the Webtatic YUM repo:
sudo yum install -y php72w php72w-cli php72w-fpm php72w-common php72w-curl php72w-gd php72w-json php72w-mbstring php72w-xml php72w-zip php72w-opcache php72w-pecl-apcu
php -m
ctype
curl
exif
fileinfo
Check the PHP version:
php --version
# PHP 7.2.17 (cli) (built: May 13 2019 18:03:04) ( NTS )
# with Zend OPcache v7.2.17, Copyright (c) 1999-2018, by Zend Technologies
Securing your forum with HTTPS is not necessary, but it is a good practice to secure your site traffic. In order to obtain TLS certificate from Let’s Encrypt we will use acme.sh client. Acme.sh is a pure UNIX shell software for obtaining TLS certificates from Let’s Encrypt with zero dependencies.
Download and install acme.sh:
sudo su - root
cd acme.sh
./acme.sh --install --accountemail [email protected]
source ~/.bashrc
cd ~
Check acme.sh version:
acme.sh --version
# v2.8.0
# RSA 2048
# ECDSA
If you want fake certificates for testing you can add --staging
flag to the above commands.
- For RSA:
/home/username/example.com
directory. - For ECC/ECDSA:
/home/username/example.com_ecc
directory.
acme.sh --list
Create a directory to store your certs. We will use /etc/letsencrypt
directory.
# RSA
# ECC/ECDSA
exit
Install NGINX:
sudo yum install -y nginx
Check the NGINX version:
nginx -v
# nginx version: nginx/1.12.2
Start and enable NGINX service:
Configure NGINX for Grav. Run sudo vim /etc/nginx/conf.d/grav.conf
and add the following configuration.
listen 443 ssl;
server_name example.com;
root /var/www/grav;
index index.html index.php;
location ~* /(.git|cache|bin|logs|backup|tests)/.*$ { return 403; }
location ~* /(system|vendor)/.*.(txt|xml|md|html|yaml|yml|php|pl|py|cgi|twig|sh|bat)$ { return 403; }
location ~* /user/.*.(txt|md|yaml|yml|php|pl|py|cgi|twig|sh|bat)$ { return 403; }
location ~ /(LICENSE.txt|composer.lock|composer.json|nginx.conf|web.config|htaccess.txt|.htaccess) { return 403; }
location ~ .php$ {
fastcgi_pass 127.0.0.1:9000;
fastcgi_index index.php;
include fastcgi_params;
fastcgi_param SCRIPT_FILENAME $document_root/$fastcgi_script_name;
sudo nginx -t
Reload NGINX service:
Step 4 – Install Grav CMS
Create a document root directory:
sudo mkdir -p /var/www/grav
Change ownership of the /var/www/grav
directory to johndoe:
sudo chown -R johndoe:johndoe /var/www/grav
Navigate to the document root folder:
cd /var/www/grav
Download and unzip Grav:
wget https://getgrav.org/download/core/grav-admin/1.6.9
unzip 1.6.9
mv grav-admin/* . && mv grav-admin/.* .
rm -rf grav-admin 1.6.9
NOTE: Version 1.6.9 is the current version and may be different by the time you read this. Please check the Grav website for the latest information.
directory to nginx:
sudo chown -R nginx:nginx /var/www/grav
Run sudo vim /etc/php-fpm.d/www.conf
and set user and group to nginx
. Initially, it will be set to user and group apache:
# user = nginx
# group = nginx
Restart the PHP-FPM service.
Create /var/lib/php/session/
directory and change ownership to nginx:
sudo mkdir -p /var/lib/php/session/ && sudo chown -R nginx:nginx /var/lib/php/session/
Open http://example.com
in your web browser and follow the on-screen instructions. To access Grav admin append /admin
to your URL.
Step 5 – Complete Grav setup
Create a Grav admin user:
After the creation, you will be redirected to the admin dashboard:
Links
