How to Install Fork CMS with NGINX on CentOS 8
fork installation system check
Fork is easy to use open-source CMS built using Symfony Components. It has an intuitive and user-friendly interface, powerful apps that you can download to expand your site, and a wide collection of beautiful themes. In this tutorial, we will go through the Fork CMS installation and setup on the CentOS 8 system by using Nginx as a web server, MariaDB as the database engine, and optionally you can secure the transport layer by using Acme.sh client and Let’s Encrypt certificate authority to add SSL support.
Requirements for installing and running Fork CMS are:
  • PHP version 7.1 or higher.
  • The following PHP extensions should be installed and enabled: cURL, libxml, DOM, SimpleXML, SPL, PDO (with MySQL driver), mb_string, iconv, GD2 graphics library, JSON, PCRE, intl.
  • MySQL 5.0 or higher.
  • NGINX or Apache with .htaccess, mod_rewrite, mod_expires (optional but recommended), mod_deflate(optional) enabled.
  • An operating system running CentOS 8.
Initial steps
Check your CentOS version:
cat /etc/centos-release
# CentOS Linux release 8.0.1905 (Core)
Set up the timezone:
timedatectl list-timezones
sudo yum update -y
Install some essential packages that are necessary for basic administration of the CentOS operating system:
sudo yum install -y curl wget vim git unzip socat bash-completion epel-release
Install PHP, as well as the necessary PHP extensions for Fork CMS:
sudo yum install -y php php-cli php-fpm php-common php-mysqlnd php-curl php-json php-zip php-gd php-xml php-mbstring php-opcache php-intl
php -m
ctype
curl
exif
fileinfo
Check the PHP version:
php --version
# PHP 7.2.11 (cli) (built: Oct 9 2018 15:09:36) ( NTS )
We can move on to the next step, which is the database installation and setup.
Step 2 – Install MariaDB and create a database for Fork CMS
Install MariaDB database server:
sudo yum install -y mariadb-server
Check the MariaDB version:
mysql --version
# mysql Ver 15.1 Distrib 10.3.11-MariaDB, for Linux (x86_64) using readline 5.1
Start and enable MariaDB service:
Run mysql_secure installation script to improve MariaDB security and set the password for MariaDB root user:
Answer each of the questions:
Would you like to setup VALIDATE PASSWORD plugin? N
Re-enter new password: your_secure_password
Connect to MariaDB shell as the root user:
sudo mysql -u root -p
# Enter password
Create an empty MariaDB database and user for Fork CMS and remember the credentials:
mysql> CREATE DATABASE dbname;
mysql> GRANT ALL ON dbname.* TO 'username' IDENTIFIED BY 'mypassword';
mysql> FLUSH PRIVILEGES;
Replace the word mypassword with a secure password of your choice. Exit from MariaDB:
mysql> exit
Step 3 – Install Acme.sh client and obtain Let’s Encrypt certificate (optional)
Securing your website with HTTPS is not necessary, but it is a good practice to secure your site traffic. To obtain an SSL certificate from Let’s Encrypt we will use Acme.sh client. Acme.sh is a pure Unix shell software for obtaining TLS certificates from Let’s Encrypt with zero dependencies.
Download and install acme.sh:
sudo su - root
cd acme.sh
source ~/.bashrc
cd ~
Check acme.sh version:
acme.sh --version
# v2.8.2
# RSA 2048
# ECDSA
If you want fake certificates for testing you can add --staging flag to the above commands.
acme.sh --list
Create a directory to store your certs. We will use a directory /etc/letsencrypt.
# RSA
# ECC/ECDSA
exit
Step 4 – Install and configure NGINX
Install the NGINX web server:
sudo yum install -y nginx
Check the NGINX version:
nginx -v
# nginx version: nginx/1.14.1
Configure NGINX for Fork CMS. Run sudo vim /etc/nginx/conf.d/fork.conf and add the following configuration:
listen 443 ssl;
root /var/www/fork;
index index.php index.html;
server_name example.com;
# Checks whether the requested url exists as a file $uri or directory $uri/ in the root, else redirect to /index.php.
try_files $uri $uri/ @redirects;
location @redirects {
rewrite ^ /index.php;
location ~ .php$ {
try_files $uri =404;
include fastcgi_params;
fastcgi_pass 127.0.0.1:9000;
fastcgi_index index.php;
fastcgi_read_timeout 60;
# Don't pollute the logs with common requests
location = /robots.txt { access_log off; log_not_found off; }
location = /favicon.ico { access_log off; log_not_found off; }
# As Fork CMS has the app_root as doc_root, we need to restrict access to a few things for security purposes!
location ~* ^/(composer..*|vendor/.*|Procfile$|.git/.*|src/Console.*|.*.gitignore|.editorconfig|.travis.yml|autoload.php|bower.json|phpunit.xml.dist|.*.md|app/logs/.*|app/config/.*|src/Frontend/Cache/CompiledTemplates.*|src/Frontend/Cache/Locale/.*.php|src/Frontend/Cache/Navigation/.*.php|src/Frontend/Cache/Search/.*|src/Backend/Cache/CompiledTemplates/.*|src/Backend/Cache/Locale/.*.php)$ {
deny all;
access_log off;
log_not_found off;
# Deny access to dot-files.
location ~ /. {
deny all;
access_log off;
log_not_found off;
sudo nginx -t
Reload NGINX service:
Step 5 – Install Composer
Install Composer, the PHP dependency manager globally:
php -r "if (hash_file('sha384', 'composer-setup.php') === 'a5c698ffe4b8e849a443b120cd5ba38043260d5c4023dbf93e1558871f1f07f58274fc6f4c93bcfd858c6bd0775cd8d1') { echo 'Installer verified'; } else { echo 'Installer corrupt'; unlink('composer-setup.php'); } echo PHP_EOL;"
php composer-setup.php
Check Composer version:
composer --version
# Composer version 1.9.0 2019-08-02 17:46:47
Step 6 – Install Fork CMS
Create a document root directory.
sudo mkdir -p /var/www/fork
Change ownership of the /var/www/fork directory to the user that you are currently logged in, in my case, this username is johndoe.
sudo chown -R johndoe:johndoe /var/www/fork
Replace johndoe with your login username in the above command! Download the latest stable release of Fork CMS from the command line.
cd /var/www/fork
composer create-project forkcms/forkcms .
Change ownership of the /var/www/fork directory to www-data.
sudo chown -R nginx:nginx /var/www/fork
Edit the app/config/parameters.yml.dist file and set database information.
sudo vim /var/www/fork/app/config/parameters_install.yml
Run sudo vim /etc/php-fpm.d/www.conf and set user and group to nginx:
Create /var/lib/php/session directory and change its ownership to user nginx:
sudo mkdir -p /var/lib/php/session
sudo chown -R nginx:nginx /var/lib/php/session
Restart php-fpm.service:
Using your preferred web browser, open your site and follow the Fork CMS installer. After following the installer you should have Fork up and running. To access the Fork admin area just append /private to your site URL.
Step 7 – Complete the Fork CMS setup
Make sure your server meets all the requirements and continue:
Fork CMS installer
Select language and click next:
Language settings
Select the settings as you wish and click next:
Settings
Enter your database settings and click next. Make sure you already created the database.
Database settings
Create user and finish the installation:
Create user
You will see the following page after you complete all the above steps:
Installation finished
You have successfully installed Fork CMS. Enjoy your new CMS!
Links
