How to Install ExpressionEngine CMS on CentOS 8
ExpressionEngine is a mature, flexible, secure, free open-source content management system (CMS) written in PHP. Its source code is hosted on Github. With ExpressionEngine, you can build full-featured websites, create a web app, or serve content to mobile applications. All without requiring complex programming skills. This guide will walk you through the ExpressionEngine installation process on a fresh CentOS 8 using PHP, MariaDB as a database, and Nginx as a web server.
ExpressionEngine requires a web server running PHP and MySQL/MariaDB. The recommend software stack and versions are:
- PHP version 7.0 or greater, running with PHP-FPM and with the following PHP extensions (
gd
,fileinfo
,intl
,mbstring
). - MySQL version 5.6 or greater or Percona version 5.6 or greater. This tutorial will use MariaDB.
- A web server like Nginx or Apache. This tutorial will use Nginx.
Initial Steps
Check your CentOS version:
cat /etc/centos-release
# CentOS Linux release 8.0.1905 (Core)
Set up the timezone:
timedatectl list-timezones
sudo yum update -y
Install some essential packages that are necessary for basic administration of the CentOS operating system:
sudo yum install -y curl wget vim git unzip socat bash-completion epel-release
Step 1 – Install PHP
sudo yum install -y php-cli php-fpm php-common php-mbstring php-gd php-intl php-mysql php-json php-zip
Check the PHP version:
php --version
# PHP 7.2.19 (cli) (built: Jun 2 2019 09:49:05) ( NTS )
php -m
ctype
curl
exif
fileinfo
Step 2 – Install MariaDB
Install the MariaDB database server:
sudo yum install -y mariadb-server
Check the MariaDB version:
mysql --version
# mysql Ver 15.1 Distrib 10.3.11-MariaDB, for Linux (x86_64) using readline 5.1
Start and enable MariaDB service:
Run the mysql_secure_installation
script to improve the security of your MariaDB installation:
Log into MariaDB as the root user:
sudo mysql -u root -p
# Enter password:
Create a new MariaDB database and database user, and remember the credentials:
CREATE DATABASE dbname;
FLUSH PRIVILEGES;
quit
NOTE: Replace dbname
and username
with appropriate names for your setup. Replace password
with a strong password.
Step 3 – Install Acme.sh client and obtain Let’s Encrypt certificate (optional)
Securing your website with HTTPS is not necessary, but it is a good practice to secure your site traffic. To obtain an SSL certificate from Let’s Encrypt we will use Acme.sh client. Acme.sh is a pure Unix shell software for obtaining TLS certificates from Let’s Encrypt with zero dependencies.
Download and install acme.sh:
sudo su - root
cd acme.sh
./acme.sh --install --accountemail [email protected]
source ~/.bashrc
cd ~
Check acme.sh version:
acme.sh --version
# v2.8.3
# RSA 2048
# ECDSA
If you want fake certificates for testing you can add --staging flag to the above commands.
- For RSA:
/home/username/example.com directory.
- For ECC/ECDSA:
/home/username/example.com_ecc directory.
acme.sh --list
Create a directory to store your certs. We will use a directory /etc/letsencrypt.
Install/copy certificates to /etc/letsencrypt directory:
# RSA
# ECC/ECDSA
exit
Step 4 – Install Nginx
Install Nginx webserver:
sudo yum install -y nginx
Check the Nginx version:
nginx -v
# nginx version: nginx/1.12.2
Start and enable Nginx:
Configure Nginx for ExpressionEngine. Run sudo vi /etc/nginx/conf.d/expressionengine.conf
and populate the file with the following configuration.
listen 443 ssl;
server_name example.com;
root /var/www/expressionengine;
# RSA
# ECDSA
index index.php;
index index.php;
try_files $uri $uri/ @ee;
location @ee {
rewrite ^(.*) /index.php?$1 last;
location ~* .php$ {
fastcgi_pass 127.0.0.1:9000;
include fastcgi_params;
fastcgi_index index.php;
sudo nginx -t
Reload NGINX service:
Step 5 – Install ExpressionEngine
Create a document root directory where ExpressionEngine should reside in:
sudo mkdir -p /var/www/expressionengine
Navigate to the document root folder:
cd /var/www/expressionengine
Download the latest release of ExpressionEngine and unzip the files to a folder on your server:
sudo wget -O ee.zip --referer https://expressionengine.com/ 'https://expressionengine.com/?ACT=243'
sudo unzip ee.zip
sudo rm ee.zip
Change ownership of the /var/www/expressionengine
directory to nginx:
sudo chown -R nginx:nginx /var/www/expressionengine
Run sudo vim /etc/php-fpm.d/www.conf
and set the user and group to nginx
. Initially, they will be set to apache:
sudo vi /etc/php-fpm.d/www.conf
# user = nginx
# group = nginx
Restart the PHP-FPM service:
Point your browser to the URL of the admin.php
file you uploaded. For example: http://example.com/admin.php
. Follow the on-screen instructions to install ExpressionEngine. Once the Installation Wizard is finished, you should rename or remove the system/ee/installer/
directory from your server.
Step 6 – Complete the ExpressionEngine setup
Complete the ExpressionEngine installation by entering the database and administrator account details:
After, you will see default login page:
This is the ExpressionEngine administration dashboard:
And here is the frontend page:
That’s it! ExpressionEngine installation is completed.
Links
