How to Install ElkArte Forum with Apache and Let’s Encrypt on Debian 10
ElkArte is a free, open-source and powerful forum software that allows you to create your own online forum community. It is simple, lightweight and modern forum platform based on PHP and uses MySQL/MariaDB to store its data. ElkArte comes with a richs et of features including, Notifications, Likes for posts, Drafts, Auto save, Drag and drop file attachment, Integrated video embedding for youtube, Posting by Email, Improved Anti Spam measures and many more.
In this tutorial, we will explain how to install ElkArte on Debian 10 server.
  • A server running Debian 10.
  • A root password is setup to your server.
apt-get upgrade -y
Install Apache, MariaDB and PHP
First, you will need to install Apache web server, MariaDB database server, PHP and other required libraries to your server. You can install all of them by running the following command:
apt-get install apache2 mariadb-server php libapache2-mod-php php-common php-curl php-intl php-mbstring php-xmlrpc php-mysql php-gd php-pgsql php-xml php-cli php-imagick php-bcmath php-gmp php-zip unzip -y
Once all the packages are installed, open php.ini file and tweak some settings:
nano /etc/php/7.3/apache2/php.ini
Change the following lines:
memory_limit = 256M
upload_max_filesize = 100M
max_execution_time = 360
date.timezone = America/Chicago
Save and close the file when you are finished. Then, restart the Apache webserver with the following command:
systemctl restart apache2
Configure Database for ElkArte
Next, you will need to create a database and user for ElkArte. To do so, login to MariaDB shell with the following command:
mysql -u root -p
Provide your root password when prompt then create a database and user with the following command:
MariaDB [(none)]> CREATE DATABASE elkartedb;
MariaDB [(none)]> CREATE USER 'elkarte'@'localhost' IDENTIFIED BY 'password';
Next, grant all the privileges to ElkArte with the following command:
MariaDB [(none)]> GRANT ALL ON elkartedb.* TO 'elkarte'@'localhost' WITH GRANT OPTION;
MariaDB [(none)]> EXIT;
Download ElkArte
First, you will need to download the latest version of ElkArte from the Git repository. To download it, run the following command:
wget https://github.com/elkarte/Elkarte/archive/master.zip
unzip master.zip
Next, move the extracted directory to the Apache web root directory:
mv Elkarte-master /var/www/html/elkarte
Next, change the ownership of the elkarte directory and provide necessary permissions with the following command:
chown -R www-data:www-data /var/www/html/elkarte
chmod -R 755 /var/www/html/elkarte
Create Virtual host for ElkArte
Next, you will need to create an Apache virtual host configuration file to serve ElkArte. You can create it with the following command:
nano /etc/apache2/sites-available/elkarte.conf
DocumentRoot /var/www/html/elkarte
ServerName example.com
<Directory /var/www/html/elkarte/>
Options FollowSymlinks
Require all granted
Save and close the file when you are finished. Then, enable the virtual host file and Apache rewrite module with the following command:
a2ensite elkarte.conf
a2enmod rewrite
Finally, restart the Apache webserver to apply the changes:
Access ElkArte Web Interface
ElkArte is now installed and configured. It’s time to access ElkArte web interface.
Open your web browser and type the URL http://example.com. You will be redirected to the ElkArte welcome page:
ElkArte Installer
Click on the Continue button. You should see the following page:
Database settings
Provide your database name, database username, password and click on the Continue button. You should see the following page:
Forum Settings
Provide your Forum name, Forum URL and click on the Continue button. You should see the following page:
Populating the database
Now, click on the Continue button. You should see the admin creation page:
Create an admin account
Provide your desired administrator name, password, email, database password and click on the Continue button. Once the installation has been finished, you should see the following page:
Finalize installation
Now, click on the “your newly installed forum“. You should see the ElkArte dashboard in the following page:
ElkArte Forum
Secure ElkArte with Let’s Encrypt
First, you will need to install Certbot on your server. Certbot is used to obtain an SSL certificate from the Let’s Encrypt and configure Apache to use this certificate.
By default, the latest version of Certbot is not available in the Debian 10 default repository. So you will need to add Certbot repository on your server.
First, add the Certbot repository with the following command:
add-apt-repository ppa:certbot/certbot
Once the repository is added, update the repository and install Certbot with the following command:
apt-get install certbot python-certbot-apache -y
Certbot is now installed and ready to use.
Run the following command to obtain the SSL certificate for your domain:
certbot --apache -d example.com
First, you will need to provide a valid email address and agree to the terms of service as shown below:
cancel): [email protected]
(A)gree/(C)ancel: A
(Y)es/(N)o: Y
Obtaining a new certificate
http-01 challenge for example.com
Enabled Apache rewrite module
Waiting for verification...
Cleaning up challenges
Created an SSL vhost at /etc/apache2/sites-available/example.com-le-ssl.conf
Deploying Certificate to VirtualHost /etc/apache2/sites-available/example.com-le-ssl.conf
Enabling available site: /etc/apache2/sites-available/example.com-le-ssl.conf
Next, choose option 2 to download and install free SSL certificate for your domain. Once the installation has been completed successfully. You should get the following output:
Redirecting vhost in /etc/apache2/sites-enabled/example.com.conf to ssl vhost in /etc/apache2/sites-available/
Congratulations! You have successfully enabled https://example.com
https://www.ssllabs.com/ssltest/analyze.html?d=example.com
IMPORTANT NOTES:
/etc/letsencrypt/live/example.com/fullchain.pem
/etc/letsencrypt/live/example.com/privkey.pem
Your cert will expire on 2019-10-22. To obtain a new or tweaked
Congratulations! your ElkArte is now secured with SSL certificate. You can now access it securely by visiting the URL https://example.com.
