How to Install Bolt CMS with Nginx and Let’s Encrypt on FreeBSD 12
Bolt is a sophisticated, lightweight and simple CMS built with PHP. It is released under the open-source MIT-license and source code is hosted as a public repository on Github. A bolt is a tool for Content Management, which strives to be as simple and straightforward as possible. It is quick to set up, easy to configure, uses elegant templates. Bolt is created using modern open-source libraries and is best suited to build sites in HTML5 with modern markup. In this tutorial, we will go through the Bolt CMS installation on FreeBSD 12 system by using Nginx as a web server, MySQL as a database server, and optionally you can secure the transport layer by using acme.sh client and Let’s Encrypt certificate authority to add SSL support.
The system requirements for Bolt are modest, and it should run on any fairly modern web server:
- PHP version 5.5.9 or higher with the following common PHP extensions: pdo, mysqlnd, pgsql, openssl, curl, gd, intl, json, mbstring, opcache, posix, xml, fileinfo, exif, zip.
- Access to SQLite (which comes bundled with PHP), or MySQL or PostgreSQL.
- Apache with
mod_rewrite
enabled (.htaccess
files) or Nginx (virtual host configuration covered below). - A minimum of 32MB of memory allocated to PHP.
- An operating system running FreeBSD 12.
Initial steps
Check your FreeBSD version:
uname -ro
# FreeBSD 12.0-RELEASE
Set up the timezone:
tzsetup
freebsd-update fetch install
pkg update && pkg upgrade -y
Install some essential packages that are necessary for basic administration of FreeBSD 12.0 operating system:
pkg install -y sudo vim unzip wget bash
Step 1 – Install MySQL and create a database for Bolt
Bolt supports MySQL, MariaDB, PostgreSQL and SQLite databases. In this tutorial, we will use MySQL as a database server.
Install MySQL database server:
sudo pkg install -y mysql57-server
Check MySQL version:
mysql --version
# mysql Ver 14.14 Distrib 5.7.27, for FreeBSD12.0 (amd64) using EditLine wrapper
Enable and start MySQL service:
sudo sysrc mysql_enable="yes"
sudo service mysql-server start
Run mysql_secure installation
script to improve MySQL security and set the password for MySQL root
user:
Answer each of the questions:
Would you like to setup VALIDATE PASSWORD plugin? N
Re-enter new password: your_secure_password
Connect to MySQL shell as the root user:
sudo mysql -u root -p
# Enter password
Create an empty MySQL database and user for Bolt and remember the credentials:
CREATE DATABASE dbname;
CREATE USER 'username'@'localhost' IDENTIFIED BY 'password';
FLUSH PRIVILEGES;
Exit from MySQL:
exit
Replace dbname
, username
and password
with your own names.
Step 2 – Install PHP and necessary PHP extensions
sudo pkg install -y php72 php72-ctype php72-curl php72-dom php72-hash php72-iconv php72-gd php72-json php72-mbstring php72-openssl php72-session php72-simplexml php72-xml php72-zip php72-zlib php72-pdo php72-pdo_mysql php72-mysqli php72-filter php72-ftp php72-tokenizer php72-calendar php72-pecl-APCu php72-opcache php72-sqlite3 php72-pdo_sqlite php72-intl php72-posix
Check the PHP version:
php --version
# PHP 7.2.22 (cli) (built: Sep 7 2019 01:12:40) ( NTS )
# with Zend OPcache v7.2.22, Copyright (c) 1999-2018, by Zend Technologies
Enable and start PHP-FPM service:
sudo sysrc php_fpm_enable=yes
sudo service php-fpm start
We can move on to the next step, which is obtaining free SSL certs from Let’s Encrypt CA.
Step 3 – Install acme.sh
client and obtain Let’s Encrypt certificate (optional)
Securing your website with HTTPS is not necessary, but it is a good practice to secure your site traffic. In order to obtain a TLS certificate from Let’s Encrypt we will use Acme.sh client. Acme.sh is a pure UNIX shell software for obtaining TLS certificates from Let’s Encrypt with zero dependencies.
Download and install Acme.sh:
sudo pkg install -y acme.sh
Check Acme.sh version:
acme.sh --version
# v2.8.2
# RSA
sudo acme.sh --issue --standalone --home /etc/letsencrypt -d example.com --keylength 2048
# ECDSA
sudo acme.sh --issue --standalone --home /etc/letsencrypt -d example.com --keylength ec-256
- For RSA:
/etc/letsencrypt/example.com
directory. - For ECC/ECDSA:
/etc/letsencrypt/example.com_ecc
directory.
Step 3 – Install NGINX and configure NGINX for Bolt CMS
Bolt CMS can work fine with many popular web server software. In this tutorial, we selected Nginx.
Download and install the latest mainline release of Nginx from the FreeBSD repository:
sudo pkg install -y nginx-devel
Check the Nginx version:
nginx -v
# nginx version: nginx/1.17.1
Enable and start Nginx:
sudo sysrc nginx_enable=yes
sudo service nginx start
Configure Nginx for Bolt by running:
sudo vim /usr/local/etc/nginx/bolt.conf
listen 443 ssl;
server_name example.com;
root /usr/local/www/bolt/public;
index index.php;
# RSA
# ECC
location = /bolt {
try_files $uri /index.php?$query_string;
location ^~ /bolt/ {
location ~ /index.php/(.*) {
rewrite ^/index.php/(.*) /$1 permanent;
location ~ /. { deny all; }
location ~ /.(htaccess|htpasswd)$ { deny all; }
location ~ /.(?:db)$ { deny all; }
location ~* /(.*).(?:markdown|md|twig|yaml|yml)$ { deny all; }
location ~ [^/].php(/|$) {
include fastcgi_params;
fastcgi_split_path_info ^(.+?.php)(/.*)$;
fastcgi_param HTTP_PROXY "";
fastcgi_param HTTPS $https if_not_empty;
fastcgi_pass 127.0.0.1:9000;
NOTE: For complete and production-ready Nginx config for Bolt CMS check out https://docs.bolt.cm/3.6/installation/webserver/nginx.
Run sudo vim /usr/local/etc/nginx/nginx.conf
and add the below line to http {}
block to include Bolt config.
include bolt.conf;
Check Nginx configuration for syntax errors:
sudo nginx -t
Reload Nginx service:
sudo service nginx reload
Step 5 – Install Bolt CMS
Create /usr/local/www
directory:
sudo mkdir -p /usr/local/www
Navigate to /usr/local/www
directory:
cd /usr/local/www
Download the latest release Bolt CMS via wget and unzip it:
sudo wget https://bolt.cm/distribution/bolt-latest.zip && sudo unzip bolt-latest.zip
Remove downloaded bolt-latest.zip
file:
sudo rm bolt-latest.zip
Rename the bolt-v3.6.10 directory to just bolt:
sudo mv bolt-v3.6.10 bolt
Navigate to /usr/local/www/bolt
directory:
cd /usr/local/www/bolt
To finish the installation you will need to rename the following files:
sudo mv .bolt.yml.dist .bolt.yml
sudo mv composer.json.dist composer.json
sudo mv composer.lock.dist composer.lock
sudo mv src/Site/CustomisationExtension.php.dist src/Site/CustomisationExtension.php
Change ownership of the /usr/local/www/bolt
directory to www
user:
sudo chown -R www:www /usr/local/www/bolt
Navigate to the folder where you uploaded Bolt in your web browser and follow the instructions on the screen.
Step 6 – Complete the Bolt CMS Installation and Setup
After opening your site in a web browser, you should be redirected to the following page:
Fill in the required information to create a user and click the “Create the first user” button to continue. After that Bolt CMS admin interface should show up:
Bolt CMS installation is now finished. To access Bolt CMS admin append /bolt
to your site IP or domain.
Links
