How to Install Bludit CMS with NGINX on CentOS 7
Bludit is a simple, fast, secure, flat-file CMS that allows you to create your own website or blog in seconds. It’s completely free and open source. You can browse its source code on Github. Bludit uses files in JSON format to store the content, you don’t need to install or configure a database. You only need a web server with PHP support. Bludit incorporates all the SEO tools to improve your ranking in all the search engines and social networks. It has a rich themes and plugins system that you can use to change the look and feel of your site. In this tutorial, we will go through the Bludit CMS installation and setup on CentOS 7 system by using NGINX as a web server.
Make sure your system meets the following requirements:
  • PHP version 5.3 or greater with the following extensions: mbstring, gd, dom and JSON.
  • A web server with PHP support like Nginx, Apache, Lighttpd, H2O. This tutorial will use NGINX.
  • A system running CentOS 7.
Initial steps
Check your CentOS version:
cat /etc/centos-release
# CentOS Linux release 7.6.1810 (Core)
Set up the timezone:
timedatectl list-timezones
sudo yum update -y
Install some essential packages that are necessary for basic administration of the CentOS operating system:
sudo yum install -y curl wget vim git unzip socat bash-completion epel-release
Step 1 – Install PHP
Setup the Webtatic YUM repo:
sudo yum install -y php72w php72w-cli php72w-fpm php72w-common php72w-mbstring php72w-zip php72w-pgsql php72w-sqlite3 php72w-curl php72w-gd php72w-mysql php72w-intl php72w-json php72w-opcache php72w-xml
php -m
ctype
curl
exif
fileinfo
Check the PHP version:
php --version
# PHP 7.2.14 (cli) (built: Jan 12 2019 12:47:33) ( NTS )
# Zend Engine v3.0.0, Copyright (c) 1998-2017 Zend Technologies
# with Zend OPcache v7.2.14, Copyright (c) 1999-2018, by Zend Technologies
Step 2 – Install acme.sh client and obtain Let’s Encrypt certificate (optional)
Securing your website with HTTPS is not necessary, but it is a good practice to secure your site traffic. In order to obtain a TLS certificate from Let’s Encrypt we will use Acme.sh client. Acme.sh is a pure Unix shell software for obtaining TLS certificates from Let’s Encrypt with zero dependencies.
Download and install Acme.sh:
sudo mkdir /etc/letsencrypt
cd acme.sh
sudo ./acme.sh --install --home /etc/letsencrypt --accountemail [email protected]
cd ~
Check Acme.sh version:
/etc/letsencrypt/acme.sh --version
# v2.8.0
# RSA 2048
sudo /etc/letsencrypt/acme.sh --issue --standalone --home /etc/letsencrypt -d example.com --keylength 2048
# ECDSA
sudo /etc/letsencrypt/acme.sh --issue --standalone --home /etc/letsencrypt -d example.com --keylength ec-256
  • For RSA: /etc/letsencrypt/example.com directory.
  • For ECC/ECDSA: /etc/letsencrypt/example.com_ecc directory.
Step 3 – Install and configure NGINX
Download and install Nginx from the CentOS repository:
sudo yum install -y nginx
Check the Nginx version:
nginx -v
# nginx version: nginx/1.12.2
Start and enable Nginx service:
Configure NGINX for Bludit by running:
sudo vim /etc/nginx/conf.d/bludit.conf
listen 443 ssl;
server_name example.com;
root /var/www/bludit;
index index.php;
location ~ .php$ {
fastcgi_pass 127.0.0.1:9000;
fastcgi_index index.php;
include fastcgi.conf;
location ^~ /bl-content/tmp/ { deny all; }
location ^~ /bl-content/pages/ { deny all; }
location ^~ /bl-content/databases/ { deny all; }
Check NGINX configuration for syntax errors:
sudo nginx -t
Reload NGINX service:
Step 4 – Install Bludit
Create a document root directory where Bludit should reside in:
sudo mkdir -p /var/www/bludit
Change ownership of the /var/www/bludit directory to [your_user]:
sudo chown -R [your_user]:[your_user] /var/www/bludit
Navigate to document root:
cd /var/www/bludit
Download the latest version from the official page and extract the zip file:
wget https://www.bludit.com/releases/bludit-3-8-1.zip
unzip bludit-3-8-1.zip
rm bludit-3-8-1.zip
mv bludit-3-8-1/* . && mv bludit-3-8-1/.* .
rmdir bludit-3-8-1
NOTE: Update download URL if there is a newer release.
Provide the appropriate ownership:
sudo chown -R nginx:nginx /var/www/bludit
Run sudo vim /etc/php-fpm.d/www.conf and set the user and group to nginx. Initially, they will be set to apache:
# user = nginx
# group = nginx
Restart PHP-FPM service:
Step 5 – Complete the Bludit installation wizard
Open your site in a web browser. After opening your site in a web browser, you should be redirected to the following page, to choose your language:
Bludit Installer
Next, create a password for the user admin, and click “Install”:
Set Admin password
After creating an admin password, you will be redirected to the Bludit frontend:
Welcome to Bludit
To access Bludit admin area, append /admin to your site IP or URL. This is how Bludit admin looks like:
Bludit CMS Dashboard
Installation is complete. Happy blogging with Bludit CMS.
